Thermal Paste for Laptop. I need your help!
201 (0.03/day)
Finally mx-5 arrive.
Opened the laptop.
Unscrew all torqs
Disconnect the cable that go to mainboard.
Clean.
Put mx-5 pt.. Awesome paste..
Screw all. Torqs.
Connected the cable to MB and suddenly
Sparkles and smell to burn plástic. A little black smoke come to me.
I burn and kill my laptop
Not turning on
Battery was connected.. A big big mistake
Come from technical store. A waiting for the resume of damages.
Damn...
Damn..
Damn.
What "cable connected to motherboard' are you talking about?
The battery cable?! Or a different cable?
The only cables that have to be disconnected when repasting a laptop is:
1) AC power cable (first, before you take the laptop apart).
2) Battery internal connector cable.
When re-assembling connect:
1) Battery internal connector cable, right before chassis plastic panel attachment (make sure proper connection and insertion fit!)--battery cable is the very last cable to plug in before you put the "case" cover on.
2) AC Power cable (After chassis fully assembled and screwed only).
So what happened?
3,601 (1.17/day)
Processor 9800X3D
Cooling DeepCool AK620
Storage 4TB Samsung 990 Pro
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX1200
Mouse Razor Death Adder v3
Software win11
Holy crap that sounds like bad news.
2,407 (1.17/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
oh man, i pray for you that the damage is minor....
44 (0.03/day)
Best choice, but most expensive; TFX (Or Thermagic ZF-EX, which is its clone). Aliexpress is perfectly safe, it has a money back guarantee. You just have to deal with the slow boat shipping.
For sanity purposes, TFX if you can get it on amazon but it's expensive. If you want to save money, you can buy 6.2g of TFX on aliexpress for about $28 or so.
ZF-EX is the same paste as TFX (might explain why it's so expensive), but if you're lucky you can buy it for 2 grams / $7 if there's a sale or discount.
This is the best paste because of how thick it is, and thick is good for laptops.
TFX / ZF-EX is *thick* and very difficult to spread. But spreading it gives the best results on a laptop. Suggest you follow these posts here.
If you have access to amazon USA, SYY-157 is extremely good paste, it's basically a wetter, easier to spread TFX. On a laptop, make sure you spread a thick layer of it. (spreading it too thin gives worse results).
Read here: And you can see how well it does vs TFX.
FuzeIce Plus is basically the same paste as SYY-157 (all those factories in Guangdong seem to be next to each other so that explains that; some may come from the same factory or multiple factories may be using the same composition), but is a bit more expensive.
SYY-157 is basically the most bang for the buck, with how much you get per gram (8 grams is $13 dollars) and its performance being right up there with TFX. The 15% off coupon is apparently up once again.
Thank you so much for your in-depth answer! Very easy to understand! May I ask which paste are you currently using for your laptop? Thanks once again!
44 (0.03/day)
Opened the laptop.
Unscrew all torqs
Clean.
Screw all. Torqs.
Not turning on
Damn...
Damn..
Damn.
Sorry for your loss! I hope everything gets sorted out without any more hassle!
3,601 (1.17/day)
Processor 9800X3D
Software win11
I use Thermalright TF-X on my Triton 500 (10875H + 2070 Super) and the thermal has been fantastic after 1 year of usage
That's 93C max when the CPU is pulling over 100W :D
201 (0.03/day)
Liquid metal (Galinstan homemade) on the CPU (still good after a year)
SYY-157 on the GPU (GTX 1070)
TFX (Thermagic ZF-EX) on desktop (RTX 3090 FE and i9 11900k)
3,601 (1.17/day)
Processor 9800X3D
Software win11
Wow! Amazing Sir! No thermal throttling whatsoever? Since I see it is close to PROCHOT. Where did you purchase this paste from? Please state the method of application?
Do you use this method?
I use the 5 dots methods on the GPU and just 1 line on the CPU, warmed up the paste with hairdryer so that it can spread easier (TFX is very thick and will not spread very well at ambient temp) then mount the cooler.
TFX and Thermagic ZF-EX are readily available in my country, maybe you can buy them off aliexpress?
juanldeaza
9 (0.01/day)
So what happened?
Here in the picture i mark the cable that burns when i reconnect
2,271 (0.98/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
that looks like the display cable.
2,715 (0.57/day)
System Name MSI GP76
Processor intel i7 11800h
Cooling 2 laptop fans
Memory 32gb of 3000mhz DDR4
Video Card(s) Nvidia 3070
Mouse Logitech m705
Keyboard laptop keyboard
I have the MSI ge75 model laptop, I use cool labtory liquid ultra
14,507 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
2,271 (0.98/day)
south wales uk
i think the op has a short on the 12v rail i dont think he messed up on the putting the cable in as you say its hard to mess up attaching it.
pretty hard to stuff that up.
juanldeaza
9 (0.01/day)
Some capacitors burned.... Waiting a final report.
My new mantra:
Always disconnect the battery!
LastSilmaril
2 (0.00/day)
Best paste for Laptop are: Thermalright TF-X, SYY or Thermagic ZF-EX. These pastes should last a long time under high temperature.
How to apply new thermal paste
1. clean off the previous TIM with 90% isopropyl alcohol
2. Put the X pattern on GPU (4 small dots in the quadrant) and 1 line on the CPU
3. Use a hair dryer to warm up the TIM before mounting the cooler
4. Tighten the screws in the X order to evenly distribute the mounting pressure (1 rotation then switch to the opposite screw)
5. Keep using the hairdryer to heat up to heatsink
6. Tighten the screws until it stop completely using only the fingers to hold the screw drivers (do not use your palm as you can over-tighten)
Thanks for this. Ended up using SYY with these instructions and my trusty ten-year-old Sandy Bridge i7 X220 is usable again instead of hitting 90+ deg C on 20% cpu usage while having the fan screaming. (It still hits 90 deg when near 100% sustained, but this is a rare situation, and the fan doesn't run quite as loudly as it did.) It was remarkable to see what happened there, almost all the paste was shunted off.
It actually got under the black protective tape on the heatsink--you could see it bulging. Here's a closer look fwiw.
I ended up removing this black protective cover from the bottom of the heatsink entirely, cleaning off the thermal paste and adhesive, and then putting kapton tape on the exposed contacts atop the CPU to avoid a short from the heatsink. Appears to have had no adverse effect so far.
Not pictured: incredible amount of dust in the fan, about four years worth, last time I repasted, when I likely used NT-H1 (lesson being: don't...)
Thanks again!
juanldeaza
9 (0.01/day)
Mi Laptop finally dies. I burned the MB, Screen, only RAM survive and Nvme. MSI dont have parts available. And today was a sad day, i throw my beloved laptop to the garbage. All this horror, because i dont unpluged the battery. Now i need to buy a new PC, i choose now Desktop. More easy to fix. A minute of silence for this warrior, my beloved Laptop:(:(:(
5,417 (3.67/day)
Colorado, U.S.A.
Software Windows 11 Home
It was a hard way to learn; I feel your pain.
A sound decision to move to a desktop; laptops are hard to work on, run hot, ...
LastSilmaril
2 (0.00/day)
oof, sorry it didn't work out dude :(
RIP your laptop, but good luck with the new PC!
44 (0.03/day)
Sorry for your loss my dear fellow. I share your grief, and know exactly what it feels like to lose something so beloved. Really sorry once again for your loss. RIP your beloved laptop. May you have enough courage to bear this loss. Hope your data is safe! :(:(
Also, good luck with the new PC!
9,922 (1.81/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
sorry to hear that, but that's something to learn, always check then recheck, if you are not sure just ask someone or just browsing it
but if there's a chance for err there will always be
nex86
1 (0.00/day)
I was also looking for a good paste to use for my new Acer Nitro 5.
The CPU is always getting up to 95°C, for now I used MX-5, but I barely see a difference compared to the stock paste. But I even see a spike to 97°C now.
For now I throttled the CPU TDP with XTU because I'm too worried of it getting too hot.
So you guys say Syy 157 and thermalright TF-8 are good pastes to go with?
which one of the two would you recommend?
