Throttlestop doesn't show "Disable and lock turbo power limits" option
Mr.Orange66
1 (0.00/day)
Hi everybody,
I'm following a guide trying to tweak my cpu I5-8300H and at some point you should go to FIVR and check the "Disable and Lock Turbo Power Limits feature" but in my throttlesttop it doesn't show up. Anybody know why? Here's a screen
unclewebb
8,348 (1.35/day)
The famous Disable and Lock feature was moved to the TPL window. It was renamed MMIO Lock which is a box you can check near the top right.
This change was documented in the included ReadMe file.
ThrottleStop
Version 9.5
2022 June 15
New Features
- Alder Lake desktop and mobile support added.
- improved performance when using Windows Defender Real-time Protection.
- replaced the Disable and Lock Turbo Power Limits box with the MMIO Lock box.
As the first person to ask this question, you are here by forgiven for not reading the manual.
Welcome to TechPowerUp. :toast:
