- Jun 7, 2024
- 160 (0.48/day)
System Name | [ JUNE_2024 ] |
Processor | LGA1700 i5-12600K / 3.7Ghz / 10 cores |
Motherboard | Asus Prime Z790Mplus D4 |
Cooling | Abysm Snow 4 Duo120mm |
Memory | Kingston Fury Beast 32Gb DDR4-3600 |
Video Card(s) | Asus RTX 4070 Dual 12Gb |
Storage | M2 Corsair MP600 CoreXT 1Tb |
Display(s) | Asus 32" VG1A |
Case | Cooler Master Q300L ATX |
Power Supply | Corsair RM 750w Modular |
Hello Power Techies, i've recently upgraded to these following PC components:
- [CPU] i5-12600k 3.7ghz 10 Cores GLA1700
- [COOLER] Abysm Snow 4 Black 2 fans
- [MOBO] Asus Prime Z790M-plus D4
- [RAM] Kingston fury beast RGB 2x16gb ddr4-3600
- [SSD] M2 NVme Corsair MP600 core XT 1Tb
...the only components i've kept are: - [PSU] Seasonic Focus Plus 550W full modular / - [GPU] Gigabyte Geforce GTX 1660 super OC 6Gb Vram mini-ITX and all these inside a mini ATX tower - Cooler Master Q300L.
As the title says, i want to upgrade my GPU (while keeping my PSU as is) with a budget of 500$ and i've looked at Nvidia RTX 4060 of 8Gb Vram or even the Ti version if i can stretch the bills and afford myself 16Gb Vram.
The problem this noob is facing in ignorance, is how it is all connected between GPU and PSU ??? ...my MOBO has 1 slot Pci-e 5.0 x16 where the old GPU is slotted into (although its Interface is Pci-e 3.0 x16) but my PC works fine and i can play many games, so yay !!! Either the problem i come across is from the MOBO Pci-e slots or the GPU plugs.
QUESTION: --- what modern GPU requires only 550W and a 8-pins power connector (ASUS power supplies chart attached) ??? i've spend 3 days watching GPU Reviews, comparing Listings and reading Specs and many GPU force me to change my PSU - either because the GPU needs more than 550W or it doesn't accept a 8-pins plug because of the latest security-norms on PSU cables.
Basically, i want to keep my PSU cable-management in green sleeve and just plug&play a new GPU. (picture of my rig attached)
Thanks a bunch for any info on my dilemma.
Regards, Alexa.
PS: Nvidia first and Radeon second, in priority choice + Asus GPU brand to match MOBO, if possible...
Regards, Alexa.
