Upgrading to i7-875k and 8gb ddr3 1600 - what do you think??
Status
Not open for further replies.
3,016 (0.51/day)
vermont
System Name The wifes worst enemy
Processor i5-9600k
Motherboard Asrock z390 phantom gaming 4
Cooling water
Memory 16gb G.skill ripjaw DDR4 2400 4X4GB 15-15-15-35-2T
Video Card(s) Asrock 5600xt phantom gaming 6gb 14gb/s
Storage crucial M500 120GB SSD, Pny 256GB SSD, seagate 750GB, seagate 2TB HDD, WD blue 1TB 2.5" HDD
Display(s) 27 inch samsung @ 1080p but capable of much more ;)
Case Corsair AIR 540 Cube Mid tower
Power Supply EVGA GQ1000W MODULAR
Mouse generic for now
Keyboard generic for now
Software gotta love steam, origin etc etc
Benchmark Scores http://hwbot.org/user/philbrown_23/
so within the next weeks, im upgrading to i7-875k and 8gb ddr3 1600. is this a good upgrade for me?? also thinking maybe a better ssd??
EDIT: due to the i7-875k being virtually unavailable except for in package deals or at insane prices, I am going to grab a 870 for now till availablity gets better (if it does, some say yes some say no) and another 4gb of mushkin radioactive set (timings match mine, and they dont sell my redlines anymore) and an ASUS P7P55WS Super computer with the nf200 chip, for future tri sli
30 gb is a bit low so i'd upgrade the ssd but do you really need to buy the k edition - i though it was more expensive then the standard addition and by your username i would assume you have no problems with overclocking
I wouldn't bother with more than 4gb of ram...
But the chip I like :)
I want the K cpu because they have MUCH better memory dividers due to being unlocked. i have a 655k now it it has 10 mem dividers whereas the 650 only has like 4-6 and it makes stability and memory tweaking much more possible. its worth the extra to me. the unlocked multi is nice but not a huge deal to me. I was thinking like a 128gb ssd but I dont want to spend a ton, maybe even 60gb/80gb
well I use 4gb now and have realy problems with it I run out of ram while playing games, 8gb feels like the most necessary of upgrades after all the headaches I've had
A memory shortage while gaming? Now that doesnt sound right. Id still suggest on getting a bigger/better ssd than another kit of ram.
you either have a lot of background programs or your memory shortages are caused by the 2gb memory caps a lot of non native 64 bit games run on
its weird , ill probably get all 3 things. suggestions on ssd??
also is the coolermaster haf full tower decent??
It has an industrial look, but I really liked mine. Excellent layout, and solid airflow. Lot's of room to work inside the case.
question to oc101: are you planning 2gb x 4 or 4gb x 2?
@OC101
If you hold off on that SSD, I may have something that you might like if you don't mind going RAID. Just awaiting for some parts to come in for end user feedback, see how well my new stuff pans out.
question to oc101: are you planing 2gb x 4 or 4gb x 2?
Knowing him; 2x4gb
my rocketfish is falling apart
isnt the 875k a sandy bridge? why hasnt anyone mentioned the whole sata controller fiasco going on atm...
because my sata controller works fine :P P55 chipset
At this point in time I've got to ask why?
Sandy Bridge will be back in about a month or two and we should be on the verge of Bulldozer launch at that time too. In either case upgrading 1156 now seems like a setup for a disappointment to me.
Wait.
I'd say spend the extra to get the unlocked cpu, and 8GB (2x4GB) ram.
Processor = good upgrade.
Ram = so-so upgrade tho` Tom`s are now recommending that 8gb is the sweet spot for ram.
What ssd are you looking at ?
Honestly, coming from an 875K user, the 875K is not worth the money one bit. The memory divider thing is a non-issue, I just built a machine with an i5 760 and it offers the same memory dividers as my 875K. And unless you are using extreme cooling, they all overclock about the same, unlocked multiplier or not.
Save the cash and go with the 870, it offers the same memory dividers. Or even better, ditch hyperthreading and just go with an i5 760. My clocked to 4GHz is a total beast.
I think that's all that needs to be said.
Sata 2 controller fiasco or not, why even bother with older technology. I remember when bulding my first P4 while DualCore has already been around. I was head banging some time then.
In my book Sandy Bridge offers some much more comparing to first generation i7, i5 or i3. Buy yourself P67P8 Pro board from Asus with four Sata 3 ports which are unaffected by this Cougar Point flaw. Gigabyte is offering money back or board replacement in April. I doubt any will have problems till then.
Other than that comparing first gen 4 core i7 cpu to second gen is like day and night. I would go for Sandy Bridge if I were you.
Because he already has the rest of the setup, a simple processor upgrade is much easier than a whole plaform upgrade. Especially when upgrading to sandybridge wouldn't really give that much of a performance difference over an i7 800.
The 760 can run 1600mhz ram @ 133bclk? I do not think so! 870 just as good as 875k, I DO think so, here's mine on AIR:
If you don't care so much about using a lot of SATA ports, you could actually ash in on the Sandy Bridge fiasco and pick up a combo cheap.
Status
