Water block advice...
brandonwh64
19,542 (3.64/day)
I have a Swiftech Apogee GT CPU Cooler Block and i have it mounted on a I7-920/Asus Rampage II Gene board that has 775 and 1366 mounting holes. is this a proper block for a 17-920 @ 4.2ghz and beyond? Is there another one out there that i could get that would cool better?
Idle temps are about 35deg cel
Full load is about 63deg cel.
Vcore 1.275v
3,614 (0.51/day)
System Name TheReactor / HTPC
Processor AMD 7800x3d 5050Mhz / Intel 10700kf (5.1ghz All Core)
Motherboard ASrock x670e Taichi / ROG Strix z490-e gaming
Cooling HeatKiller VI CPU/GPU Block -2xBlackIce GTX 360 Radiators - Swiftech MCP655 Pump
Memory 32GB G.Skill 6000Mhz DDR5 / 32GB G.Skill 3400Mhz DDR4
Video Card(s) Nvidia 3090ti / Nvidia 2080ti
Storage Crucial T700 2TB Gen 5 / Samsung Evo 2Tb
Display(s) Acer Predator xb271hu - 2560x1440 @144hz
Case Corsiar 550
Audio Device(s) on board
Power Supply Antec Quattro 1000W
Keyboard Corsair Gaming k70
brandonwh64
19,542 (3.64/day)
yea im using antec formula 5 (same thing as AC5). what if i lapped the block and used MX3?
1,528 (0.28/day)
UK
System Name Betty The Dirty Dragon
Processor AMD 8350 @4.8
Motherboard ASUS sabertooth rev 2
Cooling Watercooling - Swiftech GTZ - XSPC RS360 - XSPC RX120
Memory 8GB corsair vengeance cas 9
Video Card(s) 280x 1100core 1600 mem
Storage 240 gb ssd- 2 tb Storage
Display(s) Samsung 24" 2433BW
Case Corsair 650d
Audio Device(s) Xfi Fatality Titanium Pro
Power Supply XFX 850 fully modular
that will maybe only drop temps by one or two degrees at the most (lapping). Those I7's just run dam hot!
brandonwh64
19,542 (3.64/day)
ok thats cool. i got bored earlier and filled a bowl full of ice and water and ran it through my loop LOL it got down to like 15deg cel LOLOL! wished that could be perm
Binge
Overclocking Surrealism
6,979 (1.22/day)
PA, USA
System Name Molly
Processor i5 3570K
Motherboard Z77 ASRock
Cooling CooliT Eco
Memory 2x4GB Mushkin Redline Ridgebacks
Video Card(s) Gigabyte GTX 680
Case Coolermaster CM690 II Advanced
Power Supply Corsair HX-1000
This is currently one of the top waterblocks on the market. Latest reviews placed it in first place, even beating the HeatKiller 3.0.
http://www.frozencpu.com/products/9...ock_Sockets_775_1156_1366.html?tl=g30c323s835
http://www.madshrimps.be/?action=getarticle&articID=979
I just picked one up a few days ago and upgraded my system from the same block you have. My temps dropped a good 5c-6c at load. Also switch to MX3 thermal compound.
You are on drugs sir. That block does not beat the HK 3.0, but even so a new king has arisen. EK Supreme HF.
http://www.sidewindercomputers.com/ekhfac.html
Binge
6,979 (1.22/day)
PA, USA
System Name Molly
Processor i5 3570K
Cooling CooliT Eco
brandonwh64
19,542 (3.64/day)
i will have to buy one of those. i hate having my PC not fully put together. when my reservoir gets here i will have it fully put together.
43,588 (6.69/day)
Motherboard ASUS TUF x670e
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
What is the rest of your loop like? Radiators especially. I don't think you'll see much of a change if the loop is pretty saturated already.
brandonwh64
19,542 (3.64/day)
i have a swifttech dual 120mm rad and i will soon add another single 120mm rad that will go on the back of the case :)
now fans is my main concern. should i do a push/pull or just a push?
Wrigleyvillain
PTFO or GTFO
7,702 (1.27/day)
Chicago
System Name DarkStar
Processor i5 3570K 4.4Ghz
Motherboard Asrock Z77 Extreme 3
Cooling Apogee HD White/XSPC Razer blocks
Memory 8GB Samsung Green 1600
Video Card(s) 2 x GTX 670 4GB
Storage 2 x 120GB Samsung 830
Display(s) 27" QNIX
Case Enthoo Pro
Power Supply Seasonic Platinum 760
Mouse Steelseries Sensei
Keyboard Ducky Pro MX Black
Software Windows 8.1 x64
Push Vs Pull - This depends on fan speed/power. The high speed fans at 2000RPM with a 38mm fan thickness provided the best performance in a push condition. The slow speed fans with 1350RPM with a 25mm fan thickness provided the best performance in a pull condition. I would estimate that performance line is likely to cross in the 1500-1700RPM range where they are equal. So.... slow speed = pull, high speed = push, medium speed = it doesn't really matter.
http://www.clunk.org.uk/martins-liquid-lab-articles/radiator-fan-orientation-and-shroud-testing.html
kinozawa
20 (0.00/day)
Malaysia
System Name Studi0w0rks 4337
Processor Intel Core i7 920 D0 (4.4ghz)
Motherboard DFI LanParty DK X58-T3eH6
Cooling Custom WC (Swiftech XT, MCW-60R, TFC X-changer 360 & 240), Swiftech MCP655)
Memory Corsair Dominator 1600Mhz CL8 DDR3-RAM
Video Card(s) Sapphire ATI HD3870 crossfire-X
Storage Western Digital Caviar Black 1TB + Western Digital SE 250 GB
Display(s) LG Flatron W2253TQ 22" Widescreen LCD Monitor
Case CoolerMaster Cosmos S w/transparent panel
Audio Device(s) Creative X-FI FPS
Power Supply CoolerMaster Real Power Modular 1000W
Software Microsoft Windows 7 Ultimate 32-bit
i've been reading a german review that Swiftech XT is still the king against Supreme HF, but on Xtremesystems forum some said that Supreme HF can do even better against the Swiftech XT and Heatkiller 3.0 if silicone mod on it :)
As far as i know, that Swiftech XT also will get a better temp doing a silicone mod.
Naekuh
503 (0.09/day)
Miko Fox? Fire Miko? Its FireFox-Tan!
System Name Nadeshiko
Processor i7 980X @ 4.2ghz /w HT ON 24/7
Motherboard eVGA Classified E759
Cooling Custom H2o
Memory Corsair Dominators 6 x 2GB
Video Card(s) 2 x HD4870X2 in Xfire
Storage 3 x X-25V in Raid 0 (OS) + 3 x Raptors in Raid 0 (Game)
Display(s) Dual Gateway 2485
Case MM U2
Power Supply Ultra 1.6KW
Software Win7
the waterblock is only as good as your radiator can dissipate the heat.
Anyone who told you that a new block would improve temps without knowing the rest of your values are jumping the gun here.
Also u listed motherboard values, im guessing, the cpu value listed on your motherboard.
This temp probe is taken directly under your cpu, and has very little reflection on how well the block is holding up.
Can you use a real temp monitor program such as CoreTemp, or RealTemp, and get Tjunct. Temps.
These should have 4 numbers if your cpu is quadcore, and 2 if its a dual.
I dont think your running a hex yet, so you dont require RealTemp GT.
But if your lacking component is your rad, buying better fans, would be a cheaper and greater benefit over a fairly decent cpu block your holding onto.
Yes fans will net you a great deal, however the price is noise.
As i said, we needed to know the rest of your eq and values to help you determine what would net you the most gain.
brandonwh64
19,542 (3.64/day)
Thanks Naekuh! thats some usefull info! i have a swiftech dual rad and a unknown brand single rad. what is a good rad brand?
Naekuh
503 (0.09/day)
Cooling Custom H2o
Case MM U2
Software Win7
are u after quiet?
The XSPC rads are right now the top dog.
Full copper rad, excellent FPI for low noise fans.
Are you deaf like i am? :nutkick:
Nothing will beat a GTX series rad with san ace screamers.... :rolleyes:
Did you ever think about stacking 2 MCR's together to keep the foot print smaller?
Stacking works, (IF you have a good fan to push enough air though the rear rad).
Hehe.. u guys see why i was called the ZipTie God on XS. :p
12,453 (1.98/day)
Yankee lost in the Mountains of East TN
Processor 5800x(2)/5700g/5600x/5600g/2700x/1700x/1700
Motherboard MSI B550 Carbon (2)/ MSI z490 Unify/Asus Strix B550-F/MSI B450 Tomahawk (3)
Cooling EK AIO 360 (2)/EK AIO 240, Arctic Cooling Freezer II 280/EVGA CLC 280/Noctua D15/Cryorig M9(2)
Memory 32 GB Ballistix Elite/32 GB TridentZ/16GB Mushkin Redline Black/16 GB Dominator
Video Card(s) Asus Strix RTX3060/EVGA 970(2)/Asus 750 ti/Old Quadros
Storage Samsung 970 EVO M.2 NVMe 500GB/WD Black M.2 NVMe 500GB/Adata 500gb NVMe
Display(s) Acer 1080p 22"/ (3) Samsung 22" 1080p
Case (2) Lian Li Lancool II Mesh/Corsair 4000D /Phanteks Eclipse 500a/Be Quiet Pure Base 500/Bones of HAF
Power Supply EVGA Supernova 850G(2)/EVGA Supernova GT 650w/Phantek Amps 750w/Seasonic Focus 750w
Mouse Generic Black wireless (5)
Keyboard Generic Black wireless (5)
Software Win 10/Ubuntu
are u after quiet?
http://i125.photobucket.com/albums/p73/aigomorla/Haruhi/IMG_1311.jpg
I don't want to hijack this thread, but what's the best quiet pump right now? I have a D4, and it is too damn noisy.
brandonwh64
19,542 (3.64/day)
i didnt think if using zipties to hold down my fans :(
43,588 (6.69/day)
Storage WD m.2
Keyboard Tester84
Of the pumps I've used
D4 & MCP350 are noisier
D5 (MCP655) & MCP355 were quiet.
brandonwh64
19,542 (3.64/day)
i have a off brand pump and its really quiet. its a 234GPH
Naekuh
503 (0.09/day)
Cooling Custom H2o
Case MM U2
Software Win7
Whats your time frame paul?
Gabe is releasing a DDC thats PWM, but its under testing conditions right now.
Its a 4 pin DDC which works on PWM.
You wont beat that even on a D5.
After that it would be a downvolted D5... the vario.
Anything below setting 3 is very quiet.
Then if you really dont care about temps that much, id say Ehiem is about as quiet as you can get with a shoggy kit.
http://www.sidewindercomputers.com/shsacokitor.html
12,453 (1.98/day)
I need it next week, and it really needs to be "plug and play". I'd rather not have to do any mods etc. I'm so damn busy that I barely have time for the loop itself.
Naekuh
503 (0.09/day)
Cooling Custom H2o
Case MM U2
Software Win7
You cant go wrong with a vario D5.
Its the most expensive pump out there, but its vario.
So if u want / need the flow, you can crank it to 5, and if u want whisper quiet, you can dial it down to 3.
There also tanks... Vario D5 have one of the best service history out of all the H2O pumps out there.
Wait.. Ehiem beats it, but you could honestly piss further then a ehiem pump. :X
12,453 (1.98/day)
I figured that's what you'd suggest, though I'm hoping for a bit cheaper :eek:
