Which CPU Cooler should I choose?
casper250c
195 (0.03/day)
System Name Money Pit
Processor Core2Duo E6600 @ 3.2
Motherboard Asus P5E
Cooling Zerotherm Nivana NV 120
Memory 4 gigs Corsair Dominator PC8500
Video Card(s) GeCube 3870--860/1350 & MSI 3870--860/1350 in CF
Storage 1- 250gig Western Dig.Caviar RE Sata and 1-160 gig Western Digital IDE
Display(s) Mag inovision 19"
Case NZXT Tempest ( IT ROCKS :D )
Audio Device(s) Creative X-Fi xtreme music
Power Supply Ultra X Pro 750 watt
Software Vista Home Premium with SP 1
I'm looking to replace my ThermalTake Polo but I am unsure which cooler to choose..
I've narrowed it down to these 3 choices,
1- XIGMATEK HDT-S1283
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
2- ZALMAN 9700
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118019
3- ZEROtherm Nirvana NV120
http://www.newegg.com/Product/Product.aspx?Item=N82E16835887011
Thanks in advance
Also space is not an issue as I am now in an NZXT Tempest so I have plenty of room the only stipulation is that I want the fan to blow at the rear of the case..
id go with your first choice, the Xigmatek.
I love my Xigmatek!! 40-45c @ 3.2ghz, but then again its really hot where I am so im sure its alot better.
easy XIGMATEK HDT-S1283
is one of the best coolers.
I would definitely get the Xigmatek. They tend to do alot better then other coolers. I have used them and never had a problem. Also in reviews i have seen them beet the TRUE!
+1 for Xigmatech. I have an OCZ Vendetta which is a relabeled Xigmatech. The direct contact heatpipes are fantastic. But be sure to get advice on how to apply the thermal paste properly. It makes a big difference.
yeah. You will want to put a vary small line of TIM on each side of the heat pipe then put the TIM on the CPU like you would any other HSF.I did it that way and i got the best temps using it like that.
