Will Cold Room Temperature Damage Component
Jokes
10 (0.01/day)
Hello Guys, i've searched about room temperature between 16c to 20c will cause damage to the component and I find it miss to my related question.
I have a non complete build yet, processor attach to the MB along with m.2 nvme stored in box of the MB with ram stored in the package beneath the MB.
Will it cause the damage to the component cause I have not boot up for like 4 months since then.
Should I add some food grade silica gel to prevent moisture ?
Thank you for the answer
185 (0.13/day)
The Netherlands
System Name C₂H₅OH
Processor AMD Ryzen 7 9800X3D 5,45GHz Alphacool Core 1 Black
Motherboard ASUS ROG Crosshair X670E GENE
Cooling Custom loop - MO-RA3 420 & 360 Pro - Heatkiller 200 & 150 D5 pump/res combo
Memory G.Skill Trident Z5 RGB F5-8000J4048F24GX2 8GHz 36-44-44
Video Card(s) MSI RTX 4090 Suprim X Alphacool block
Storage Samsung 980 Pro 1TB - Intel 660 Pro 2TB
Display(s) Asus PG27AQDM 240Hz OLED
Case Streacom BC1 Silver
Audio Device(s) Topping DX7Pro - Topping A90 - Hifiman Ananda - Focal Elear - Focal Radiance - Adam A5X & Adam Sub 7
Power Supply Corsair HX1200
Mouse Logitech G Pro Wireless
Keyboard Ducky One 2 SF White MX Speed Silver / Logitech MX Mechanical
That is not an issue. Just look at my profile picture, I took one of my FX-9370's to -77 and it is still fine. Heat kills hardware. Ooh and moisture can be a bitch but it depends on the humidity, people in Florida generally have humid air but their computers still work. It's really not something to worry about.
EDIT: I even dunk my GPU's, motherboards and other PCB's in demineralised water or an ultrasonic cleaner. Hell, I've used dishwashers for it. As long as they are dried properly it's fine.
Jokes
10 (0.01/day)
first thank you your answer,
just in case, next I am gonna use it. Will it be better to put it out and let it cool to the room temperature 28c - 32c before boot it up ?
2,759 (0.66/day)
Alabama
Processor Ryzen 2600
Memory C.R.S.
Video Card(s) GTX 970
Software Linux Peppermint 10
Works the same way as a glass of water with ice does.
Think of the glass as your system, if it's around the same temp as the ambient temp in the room or warmer, you will not have condensation forming.
If the system gets colder than ambient there is a chance of it forming - If it gets much colder it will form.
Since the system will be the same temp as the ambient temp around the system and then get warmer as it runs, it's a non-issue to worry about.
30,519 (7.07/day)
As a general rule, as long as you're above freezing, cooler temps will never be a bad thing for electronics & computers. Build with confidence.
2,276 (0.97/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
The cooler the better untill you start dropping to -5ish then you can start getting ice but that isnt a prob till it melts. i run a 9900k in my obsy to run my telliscope kit and it can get -10 in the winter and i havnt had a prob yet "touch wood".
185 (0.13/day)
The Netherlands
System Name C₂H₅OH
It really doesn't matter. Unless you store the CPU close to 10c-5c then there could be condensation but I really doubt that. It's not a baby, it's a stupid hunk of various metals and crystals.
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
There is dew point so not really zero risk 16c/ 60.8dF isn't that bad but will get nipples hard
Looking for borders lol
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
These are all well within normal operating temperatures. Absolutely no concern needed.
13,953 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
^^^ This^^^ And note the 4th line in my signature.
If you think about it for a second, look at all the sophisticated electronics that operates out in the cold. Our cars are full of computers and they sit out in sub-freezing weather (and extreme heat) and still work fine. Street/traffic light control panels are outside, along with all sorts of other electronics. Obviously avoiding exposure to direct sunlight in the hot summer, and wet conditions is necessary. Beyond that, electronics can tolerate a pretty wide-range of operating "temperatures".
Humidity in the air, even at 100% is not a problem either. As long as the electronics are not "wet" that's fine. In fact, the advantage of humid air is a less or even impossible chance for ESD (static discharge) issues (except from Mother Nature).
A rapid change in temperature is your greater concern.
Cool to the room? That suggests it is currently hot. Is that what you meant to say? Or did you mean to let it warm up to the room temperature?
Either way, it is always best to let any electronics "acclimate" to the ambient (room) environment before applying power - particularly when going from extreme cold to warm, such as when coming from the very cold outside in the winter to a warm room indoors. This is to avoid condensation, as mentioned earlier. But seriously, 16°C (60.8°F) is not "cold". Some would consider that barely cool. And it is unlikely your ambient (room) temperature would even be considered "warm" by most people.
And besides, you said this device has been stored under the motherboard. So that suggests it is already acclimated to rest of the equipment.
No. Never!
5,486 (3.66/day)
Colorado, U.S.A.
Software Windows 11 Home
The manual for my computer says
  • Operating: 10° to 35° C
13,953 (2.04/day)
Nebraska, USA
Mouse Logitech M190
2,622 (0.53/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Memory 64 GB G.Skill RipJaws V F4-3200C16D-64GVK
Case Corsair 275R
Mouse Logitech G Pro (Hero)
I also suggest that you have an air conditioner for the room to take away that humidity!
2,452 (1.17/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
run a dehumidifier in your room,get all that moisture out :)
1,234 (0.63/day)
Loose in space
System Name "The black one in the dining room" / "The Latest One"
Processor Intel Xeon E5 2699 V4 22c/44t / i9 14900K @6GHz
Motherboard Asus X99 Deluxe / ASRock Z790 Taichi
Cooling Arctic Liquid Freezer II 240 w/4 Silverstone FM121 fans / Arctic LF II 280 w 4 Silverstone FHP141's
Memory 64GB G.Skill Ripjaws V DDR4 2400 (8x8) / 96GB G.Skill Trident Z5 DDR5 6800
Video Card(s) EVGA RTX 1080 Ti FTW3 / Asus Tuff OC 4090 24GB
Storage Samsung 970 Evo Plus, 1TB Samsung 860, 4 Western Digital 2TB / 2TB Solidigm P44 Pro & more.
Display(s) 43" Samsung 8000 series 4K / 65" Hisense U8N 4K
Case Modded Corsair Carbide 500R / Modded Corsair Graphite 780 T
Audio Device(s) Asus Xonar Essence STX/ Asus Xonar Essence STX II
Mouse Logitech Performance MX, Microsoft Intellimouse Explorer 3.0
Keyboard Logitech K750 Solar, Logitech K800
Software Win 10 IoT Enterprise LTSC 2021 / Win 11 IoT Enterprise IoT LTSC 24H2
Benchmark Scores https://www.passmark.com/baselines/V11/display.php?id=202122048229 (before upgrades)
I have central air conditioning and keep my house cool on purpose. 62 degrees F in the winter saves a lot of money on heating bills and my PC's run nice and cool. I spend all of that saved money during the summers when the A/C is on. I keep my PC's as close to the floor outlets as possible plus make sure that the return vents are all unobstructed. I also change the furnace & A/C filters every 90 days to keep the dust as low as possible. I still have a few older mobos that have a built-in dehumidifying feature (ASRock) but I've never used it.
2,759 (0.66/day)
Alabama
Memory C.R.S.
No.
Very low humidity is just as bad as high humidity.
If the air gets too dry you start having problems with static building up in the room.
That's just as, if not more dangerous than condensation in some ways.
The air needs a certain amount of it to help prevent the buildup of static, that's why server rooms always maintain a given amount of humidity at all times.
1,234 (0.63/day)
Loose in space
13,953 (2.04/day)
Nebraska, USA
Mouse Logitech M190
While dehumidifiers are great at removing moisture out of the air, they pump a lot of heat back into the room as part of the process. That's fine in the winter, but probably not good in the summer. That will either put too much heat in the room, or cause the AC to work harder.
High humidity typically does not hurt electronics (again, as long as the electronics is not "wet"). And it should never get wet if indoors out of the rain, regardless how humid it is. But condensation can form if very cold electronics is brought inside from outdoors. So in that event, simply let the electronics "acclimate" and get up to "room temperature" before applying power.
That said, in very high humidity environments, corrosion and/or mold might be a problem if there is no ventilation.
So the facts are very low humidity is bad - for the exact reason Bones noted; static. For this reason a humidifier is often used to put moisture back in the air. When I worked in Phoenix and Albuquerque, we kept our "equipment" rooms around 45% humidity.
If you live in a dry environment, and have carpeting or rugs that generate a lot of static, a simple temporary solution is to have a spray bottle with clean water handy (filtered may be best if you have hard tap water). You don't want to soak the carpet - just a couple spritzes of water every so often where you typically walk is enough to keep the static at bay.
5,486 (3.66/day)
Colorado, U.S.A.
I thought a dehumidifier works by cooling; the air conditioning is automatically selected in my car when I select the window defogger
I recall a farm where they pass cooled air through their silos to reduce humidity; the idea is that by first cooling the air below the dew point, the water is extracted.
I guess if those dehumidifiers are dumping the heat back in the room and not outside (like an air-conditioner) that would be an issue.
Not sure filtering is going to help with hard water.
3,871 (0.74/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
No.
Humidity is actually more of a problem at that low of an ambient which that posters point was succinct and on point. Your's not so much. I've never freaking run a humidifier nor needed one for my comps, ever. PPL generally live in the environment their home comps are in. You don't live in a Datacenter do you where humidity can get dangerously low? Whatever needs for a server room don't apply here nor for most ppl. What works in a Datacenter doesn't mean it applies to everyone nor outside of the datacenter.
13,953 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Huh? Remember, Google is your friend. You don't have to have a water "softener" to remove many of the unwanted minerals and other particulates that make water "hard" that also stain rugs and leave unwanted deposits. A simple water filter is good enough to make hard tap water drinkable, and safe to spray lightly on carpets.
Ummm, no its not. 16°C is almost 61°F. That's almost an ideal temperature for operating electronics. It is not so cold that it squeezes out all moisture content (raising static concerns), and it is not so warm that it can hold tons of water (raising corrosion or mold concerns).
We don't even know where the OP lives. Is it the Amazon rain forests or Death Valley desert?
5,486 (3.66/day)
Colorado, U.S.A.
Still confused, the limescale is dissolved and so cannot be filtered out; now maybe you mean a water purifier or reverse osmosis?
The alternative of an ultrasonic humidifier is probably a terrible way to go as one ends up with a dust covering of limescale and one breaths in the minerals.
13,953 (2.04/day)
Nebraska, USA
Mouse Logitech M190
freeagent
10,388 (4.30/day)
Winnipeg, Canada
Cooling Thermalright Phantom Spirit 120 EVO, 2x T30
Memory 2x 16GB Lexar Ares @ 6400 28-36-36-68 1.55v
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
15-20c is fine. In the winter my computer room is about 16-20c. In the summer with the air on it can be 18-20c, about 22-25 if the air is off. My computer loves it lol.. not the heat but the nice low ambient. I wrap myself in a sleeping bag when I come down to my computer lol. Right now just a t shirt air hasn't come on yet.. but I did just close the windows so..
My computer is plugged into a spare tv and my desk is a coffee table that I am hunched over while sitting on a couch. Basement htpc :D
I do miss my desk and monitor though. Kids got it thanks to homeschooling through a pandemic. 5-10 is a bit cool I think..
