Will there be problem if i paired a RTX 4070 with 600W bronze PSU
62 (0.05/day)
Processor Ryzen 5 5600x
Motherboard Asrock B450M Steel Legend
Cooling Freezer 34 eSports DUO
Memory Kingston HyperX 16GB 3200mhz
Video Card(s) PALIT GeForce RTX 4070 GamingPro 12GB
Storage 1TB Toshiba Hard Disk
Display(s) MSI Optix G27C5 165Hz
Case Cougar DuoFace Pro RGB black
Audio Device(s) Razer BlackShark V2 X
Power Supply FSP GROUP HYDRO G PRO ATX3.0(PCIE5.0) 1000W
Mouse Glorious Model O
Keyboard Razer Huntsman TE
When i was chosing gpus i stopped between RTX 4070 and RX 6800, but the RX 6800 I would need to upgrade my PSU, so the price will be the same of the 4070.
My PSU at the moment is be quiet! System Power 9 Bronze 600W
dgianstefani
TPU Proofreader
4,431 (1.90/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Motherboard ASUS ROG Strix X670E-I, chipset fans removed
Cooling Optimus AMD Raw Copper/Plexi, HWLABS Copper 240/40+240/30, D5, 4x Noctua A12x25, Mayhems Ultra Pure
Memory 32 GB Dominator Platinum 6150 MHz 26-36-36-48, 56.6ns AIDA, 2050 FLCK, 160 ns TRFC
Display(s) 32" 240 Hz 1440p Samsung G7, 31.5" 165 Hz 1440p LG NanoIPS Ultragear
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front panel with pump/res combo
Audio Device(s) Audeze Maxwell Ultraviolet, Razer Nommo Pro
Power Supply SF750 Plat, transparent full custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper Pro V2 Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape
Keyboard Wooting 60HE+ module, TOFU Redux Burgundy w/brass weight, Prismcaps White & Jellykey, lubed/modded
Software Windows 10 IoT Enterprise LTSC 19053.3803
Benchmark Scores Legendary
No problem, as long as it can deliver at least 500 W on the 12 V rail.
435 (0.26/day)
That's a very good pairing. The 4070 gaming power consumption is only on par with a 3060 TI so there should be zero issues in real world situations
3,945 (0.83/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
budget build from a solid OEM (FSP), it will do the job. Probably handle the RX 6800 as well
2,887 (1.01/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Storage Too much
Case Thermaltake Core X9
Mouse G305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
That unit isn't a true 600W unit. It only supports 576W continuous on the 12V rail. It has reviewed poorly as well, particularly for transients and the very low quality 85c bulk cap.
Wattage wise you are fine but I cannot speak to if the PSU would cause crashing due to the extremely poor voltage regulation or if the bulk cap would fail on you.
2,678 (1.39/day)
UK, Leicester
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Video Card(s) 3080 RTX FE 10G
Storage 1TB 980 PRO (OS, games), 2TB SN850X (games), 2TB DC P4600 (work), 2x 3TB WD Red, 2x 4TB WD Red
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
Think you will get away with it, but dont increase GPU power limits, and even consider reducing them for margin. The transient spikes might be what causes problems.
3,945 (0.83/day)
under your (incorrect) definition your seasonic 850w isn't a true 850w
actually the final statement of the review you are looking at states the following
"As for the Pure Power 9 as a line-up, it's fine for mainstream and mid-level systems. The competition is tough though, and there are some offerings close to this price range with Gold-rated efficiency."
while you are allowed your opinion, you are certainly not allowed to change the professional reviewers opinion. Certainly not a glowing review but hardly reviewed "poorly" across the board.
2,887 (1.01/day)
Storage Too much
Mouse G305
VR HMD Valve Index
Software Win 10
My PSU can provide 99.5% of it's rated power continuously via the 12v rail. His provides 96%. There is a significant difference between his PSU's labeled wattage and the amount provided over the 12V whereas mine is within margin of error of the total wattage. Hence why his is not a true 600W.
"Although be quiet! claims that these units have independent regulation on all rails, our test results prove otherwise. So, if you apply full load at +12V and minimum at 5V, the +12V ripple goes out of spec due to some high spikes. With minimum load at +12V and maximum at 5V, ripple suppression might fall within the limits, but load regulation goes haywire with the voltage at +12V reaches close to 13V! Although be quiet! might claim this unit is Haswell-ready, according to Intel's compatibility guidelines for the C6 and C7 sleep states it's not. Granted, Intel's test methodology for Haswell compatibility takes the most extreme scenarios into account. This PSU probably wouldn't have a problem with newer CPUs, and you can always disable C6 and C7 if you did run into any problems."
"More concerning to us is this PSU's low-quality bulk cap. We can't help but wonder why be quiet! chose to offer extra bells and whistles, like the stealth ribbon cables, instead of investing in a higher quality cap in the APFC converter. Even lower-end PSUs have 105 °C bulk caps nowadays."
You read a single line from the summary, not even the whole summary which you omitted, and then declared me incorrect. I'm not sure what the point of your comment is, other than to create unnecessary drama.
The article aligns perfectly with what I said originally:
I actually read more than a single line from the review.
1,884 (1.06/day)
Hungary
Video Card(s) Asus TuF V2 RTX 3060 Ti @1920 MHz Core/950mV Undervolt
Display(s) 29" 2560x1080 75 Hz / LG 29WK600-W
Mouse Canyon Puncher GM-20
Should be fine, as far as I know the 4070 draws about the same power as a FE or 8 pin 3060 Ti and I'm using a 8 pin 3060 Ti with a 500W Seasonic Core GM with no issues at all. 'entire system draws around 280-300W from the wall under heavy gaming load like Cyberpunk'
You could also get away with a RX 6800 most likely especially if you undervolt it.
481 (0.26/day)
Texas
System Name i'm done in
Processor AMD 5950x
Memory GSkil 64gb 3600 cl16
Video Card(s) Power Color R7900xtx Hell Hound oh hell ya
Storage 2x wd sn770 2tb 1-4tb wd- hd 2x8tb wd hd actually 1 fire cuda
Display(s) LG Ultra Gear 1440p 32" 165hz hdr monitor might go oled
Case Corsair 4000D Air Flow
Power Supply EVGA SuperNOVA 1000w G5 80+ Gold
Mouse logitech and roccet wcord
Keyboard logitech
Software W10 forever
700W evga bronze PSU
5800x
6800 Power Color 16gb nailed to the wood.
The last of us hogwarts legacy rdr2 this is the one that uses the vram
LG 1440p 165hz monitor
It never blinks a eye. Never restarts. I don’t think you’ll have a problem
539 (1.23/day)
System Name BarnacleMan
Processor 14700KF
Motherboard Gigabyte B760 Aorus Elite Ax DDR5
Cooling ARCTIC Liquid Freezer II 240 + P12 Max Fans
Memory 32GB Kingston Fury Beast 5600 cl36 Oc'd to 6000 cl32
Video Card(s) Asus Tuf 4090 24GB (non-oc version, undervolted)
Storage 2TB Netac nv7000 + 2TB P5 Plus + 2TB SN850X + 2*(4TB MX500) in raid 0. 14TB Total.
Display(s) Dell 23.5" 1440P IPS panel (P2416D)
Case Lian Li LANCOOL II MESH Performance Mid-Tower
Audio Device(s) Logitech Z623
Power Supply Gigabyte 850w (ud850gm pg5)
Mouse Some piece of shit from China
Keyboard Some piece of shit from China
Software Yes Please?
I ran a 3070 ( which uses more power) on a 600w antec unit... so I think you should be good. It was gold rated..... though I know the significance of that is kind of.... dubious.
21,048 (5.96/day)
Case Fractal Design Define R5
Mouse XTRFY M42
Software W10 x64
Pure is not a fantastic Bequiet line of PSUs, I wouldnt risk it running close to the edge of its spec. Though with a 4070 you are not that close either. I second the advice not to run any OC on this setup, rather, undervolt it.
