Win XP install problem
specks
440 (0.09/day)
System Name Spreadsheet powerhouse
Processor Two P4s glued together
Motherboard Asus P5KPL-AM EPU
Cooling CoolerMaster Hyper TX3
Memory 2gb (2x1gb) Kingston Value Ram DDR2 800mhz
Video Card(s) Sapphire HD4670 1gb GDDR3 w/ Arctic Cooling Accelero L7
Storage 500GB Western Digital Caviar Blue
Display(s) Philips 191EL 18.5"
Case Thermaltake V4 Black Edition
Power Supply Thermaltake TR2 600W
Software WinXp
I want to reformat my computer but when i install winxp i get stuck at the "setup is starting windows" screen. I cant restart my pc by ctrl-alt-del though i can do it by pushing the restart button.
What do i do?
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
What do i do?
are you booting from the CD, or trying to install it from within windows?
specks
440 (0.09/day)
Software WinXp
Yes i am booting from a cd. My pc already has winxp installed. Will installing from windows reformat my pc?
Mussels
58,412 (7.78/day)
Oystralia
no it likely wont help, i was going to suggest you boot from the CD if you werent already.
have you tried using the "F6" floppy driver (as they call it) for your SATA drivers?
specks
440 (0.09/day)
Software WinXp
My hdd is still ide..what could be the problem?
qubit
Overclocked quantum bit
17,865 (2.81/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
I know what Mussels is getting at with the SATA driver. Does you BIOS have a "compatibility" option in it? This will allow XP to work with the disc controller and you will be able to complete the installation.
And on formatting: only if you tell it to. It has an option to leave formatting as it is. Generally when installing from new, it's best to do a quick format.
I hope you don't have any data that's not backed up on that hard drive...
3,565 (0.64/day)
By the Channel Tunnel, Kent, England
System Name Benny
Processor Phenom II 1055t @ 3.3GHz; 300x11; 1.380v; NB 2700; HT 2400
Motherboard ASUS Crosshair IV Formula (2002 BIOS)
Cooling Thermalright TRUE 120 Black + 2 Xilence Red Wing PWM 120mm (push/pull) + polycarbonate fan holders
Memory 8GB GeIL Ultra 2133MHZ C9 running at 1600MHz @ 7-7-7-21 1T 1.5v
Video Card(s) MSI Twin Frozr II GTX470 @ Stock w/CPU fan cable-tied on, as one of the GPU fans broke.
Storage 60GB OCZ Agility3 (OS);500GB WDC Grn; 1x1TB WDC Blk (Backup)
Display(s) ASUS PA823Q
Case Silverstone Raven 2 (all cables custom sleeved with velcro mod on side panel...)
Audio Device(s) X-Fi (Onboard) + Harmon Kardon HK6100 amp powering JVC HA-RX700's with Zalman mic
Power Supply Corsair HX650W
Software Win7 Pro x64
Benchmark Scores No benchies so making this space useful! Corsair M90, Logitech G19. Phobya FlexLight LED's (gawjus)
It does that when it can't recognise the HDD. Make sure the problems you had with your HDD are fixed by using one of the HDD diagnostic tools from Hiren's BootCD.
Oh, and it's normal for it to hang on the "setup is starting windows" screen for anything up to minute or two depending on your system.
t_ski
Former Staff
11,941 (1.72/day)
System Name My i7 Beast
Processor Intel Core i7 6800K
Motherboard Asus X99-A II
Cooling Nickel-plated EK Supremacy EVO, D5 with XSPC Bayres & BIX Quad Radiator
Memory 4 x 8GB EVGA SuperSC DDR4-3200
Video Card(s) EVGA 1080 SuperClocked
Storage Samsung 950 Pro 256GB m.2 SSD + 480GB Sandisk storage SSD
Display(s) Three Asus 24" VW246H LCD's
Case Silverstone TJ07
Power Supply Corsair AX1200
Keyboard Corsair K95
Software Windows 10 x64 Pro
If your drive is working and you need to get to the data that is already on the drive, you dan do a "parallel installation." This is where you leave the current installation inplace and install the OS to a different directory that the default (default is C:\Windows, so you would install it to another director like C:\WinXP). However, if you don't need the data that's on the drive (or have it backed up), a fresh format and reinstall would probably be better.
I agree with the others in that you may need a special driver to load at Windows install startup.
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
What flavor of install disc are you using? Is it retail or OEM (like Dell, etc.)?
Depending on what hardware you have in your PC, it could hang if there's something it can't recognise, and that can be dependant on the XP install disc you are using and/or hardware.
When you do an install of XP, it should ask if you want to repair or install, then you have the option of reformatting the HDD or not.
