Would a aftermarket cooler keep your room cooler or not? *poll*
  • Total voters
    139
CAPSLOCKSTUCK
Spaced Out Lunar Tick
8,578 (2.10/day)
llaregguB...WALES
System Name Party On
Processor Xeon w 3520
Motherboard DFI Lanparty
Cooling Big tower thing
Memory 6 gb Ballistix Tracer
Video Card(s) HD 7970
Case a plank of wood
Audio Device(s) seperate amp and 6 big speakers
Power Supply Corsair
Mouse cheap
Keyboard under going restoration
100 % of climate scientists agree that 9.2 % of the voters in this thread are wrong.
Air
203 (0.06/day)
Processor AMD Ryzen 5600X
Motherboard B550i AORUS PRO AX
Cooling Noctua NH-D9L
Memory 2 x 16Gb G.Skill Trident Z Neo 3600 MHz C16
Video Card(s) EVGA GTX 1070 SC
Storage Samsung 980 Pro 1 Tb
Case Ncase M1 V3
Power Supply Corsair SF600 Gold
Benchmark Scores CPU-Z: 655.8 single, 4999.7 multi Cinebench R23: 1563 single, 11275 multi
I'm as close as you're likely to get and frankly, no, this is high school level science. It's really sad.
Its not that bad actually. It seems most people forget everything they learn in high school, and even though this is a long thread, 90% of the audience chose the right answer. There were just a few misconceptions here and there...
20,787 (3.41/day)
System Name Pioneer
Processor Ryzen R9 7950X
Case Thermaltake Core X31
Software Gentoo Linux x64
Yes, I suppose that is correct.
110 (0.03/day)
Charleston, SC
System Name EchelonV
Processor AMD Ryzen 5 2600X
Motherboard Asus Prime X470-Pro
Cooling Corsair H115i
Memory G.Skill Flare X 2x8GB (F4-3200C16-8GFX)
Video Card(s) Sapphire Radeon 5700XT
Storage Intel 660P 2TB NVMe; 6xWD5000HHTZ RAID-0
Display(s) Dell U3415W
Case Corsair Carbide 678c
Audio Device(s) SteelSeries Siberia 800
Power Supply Corsair RM650X; CyberPower CP1500PFCLCD
Mouse SteelSeries Rival 100
Keyboard Cooler Master CK550
Software Windows 10 Professional 1903
Benchmark Scores Cinebench R15 3.9GHz = 1404
You're right, it is sad. If all CPU coolers were created equal, why would there even be a market?
May I ask your qualifications to make that first claim?
6,443 (1.44/day)
Florida
System Name natr0n-PC
Processor Ryzen 5950x/5600x
Motherboard B450 AORUS M
Cooling EK AIO 360 - 6 fan action
Memory Patriot - Viper Steel DDR4 (B-Die)(4x8GB)
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) PIXIO IPS 240Hz 1080P
Case Thermaltake Level 20 VT
Power Supply Super Flower Leadex III ARGB 80+ Gold 650W
Software XP/7/8.1/10
Lets say you have a giant cooler and your rooms window open with your case dissipating/directing all heat outside the fucking window.
Yes, your room will stay cooler.
  • Like
Reactions: Air
2,323 (0.52/day)
System Name msdos
Processor 8086
Motherboard mainboard
Cooling passive
Memory 640KB + 384KB extended
Video Card(s) EGA
Storage 5.25"
Display(s) 80x25
Case plastic
Audio Device(s) modchip
Power Supply 45 watts
Mouse serial
Keyboard yes
Software disk commander
Total heat won't change (excluding delta in fan wattage), but it's not so simple in the real world. A very high cfm system may tend towards evenly heating a room. A very low cfm system could cause very hot air to rise to the ceiling, which may actually keep the room cooler down where you are, if there's little circulation, and the ceiling insulation is poor, effectively heatsinking the concentrated heat at the top of the room. As soon as you turn on a ceiling fan, the effect would be lost, and the heat would be evenly distributed again. However undoubtedly the two HSF setups in question are similar. Ah, post #70 has a nice graph, showing the "better cooler" is causing room temp to rise more rapidly, as heat is more evenly distributed in the room initially. Though I feel that the post's reasoning implies the wrong thing.
861 (0.25/day)
CPU coolers are for keeping the CPU cool. Not to keep your room cool.
I'm not the guy you were asking but I have an mechanical engineering degree and specialty in heat transfer.
Air
203 (0.06/day)
Case Ncase M1 V3
This is the only thing of interest regarding this question. If the CPU is dissipating the same power, then that heat is going into the room one way or another.
But... if the CPU produces less heat if it's cooler, that may result in slightly lower room temperatures, provided that the cooler itself doesn't generate so much heat that it negates the savings. Power draw is a good measure. If your cooling system draws 20W more than your original, and the CPU draws 20W less, then nothing changed as far as the amount of heat dumped into the room.
It think its safe to assume it wont make a difference anyway. 20 W is more than I anticipated (for both increase in power consumption and pump power), but even if its +/- 20 W, still wont have a noticeable impact on the room.
719 (0.23/day)
Earth's Troposphere
Mouse various/various/various
VR HMD -
861 (0.25/day)
I'll give you a hint: the room temperature is raising at a varying rate. It doesn't instantaneously warm up the moment the PC is powered on. The rate that the room warms is directly effected by the efficiency of the CPU cooler.
Who the eff cares what the final room temperature is going to be? It could take 24, 48 or 1000 hours to reach it's maximum temperature. What I am arguing, and have been arguing since my first reply, is that at ANY given time interval between 0 and X hours, the room will be warmer with the aftermarket cooler.
What does "efficiency of the CPU cooler" mean? Efficiency normally implies that you get more output for the input. In this case that would mean the aftermarket cooler requires less watts to cool the CPU, which would put less watts into the room.
If you want to look at the effect of thermal capacity, here is a chart: http://www2.ucdsb.on.ca/tiss/stretton/database/specific_heat_capacity_table.html
1 watt is 1 J/s. Aluminum is .9 J/g-K. dt=M*dT*Cp/P. For example if you had your processor attached to an insulated 200g hunk of aluminum, and your processor ran at 100W, a 50C temperature rise would take 200*50*.9/100 = 90 seconds. I wouldn't count on your heat sink making an appreciable difference.
719 (0.23/day)
Earth's Troposphere
VR HMD -
one can bother himself searching testing what have you it depends if you timeframe or not. overall =
407 (0.14/day)
UK
System Name it needs a name?
Processor Xeon E3-1241 v3 @3.5GHz- standard clock
Motherboard Asus Z97A 3.1
Cooling Bequiet! Dark Rock 3 CPU cooler, 2 x 140mm intake and 1 x 120mm exhaust PWM fans in the case
Memory 16 GB Crucial DDR3 1600MHz CL9 Ballistix Sport 2 x 8 GB
Video Card(s) Palit 980ti Super Jetscream
Storage Sandisk X110 256GB SSD, Sandisk Ultra II 960GB SSD, 640GB WD Blue, 12TB Ultrastar
Display(s) Acer XB270HU
Case Lian Li PC 7H
Audio Device(s) Focusrite Scarlett 6i6 USB interface
Power Supply Seasonic P660
Mouse cheapo logitech wireless
Keyboard some keyboard from the 90's
Software Win10pro 64bit
I am disappointed in humanity at this point. This is high school science stuff people...
The fact that almost 10% of people of a technology forum don't understand basic physics does not bode well for the future of our species.
I feel quite positive about the results of this poll.
I get a warm glow just from being a participant in a forum where 9/10ths of voters understand basic thermodynamics.
dorsetknob
9,105 (1.30/day)
You could also attribute that to diapers being full of Brown..................:)
407 (0.14/day)
UK
Case Lian Li PC 7H
11,691 (1.73/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Storage Samsung 990 2TB, 2 SP 2TB SSDs and over 10TB spinning
Display(s) 56" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
Your first question is NOT the same as the question asked in the poll. The question in the poll is more of a, which is heavier a ton of feathers, or a ton of bricks?
The first is a question about the total room, NOT the CPU. If a ROOM is 70F and a CPU cooler can manage to keep the CPU at 100F under full load 125W (for example), we would say the cooler was able to remove 125W of heat at 30 T delta. If you got an after market cooler and it kept the CPU at 90F, 125W under full loaded all else being equal, the after market cooler would be better, it would have a 20 T Delta.
The same 125W is being dissipated irregardless of a better cooler. Lets agree on that.
The room will remain at 70F AVERAGE irregardless of what cooler is used as 125W is being dissipated. Lets agree on that.
The CPU temperature will be the ONLY change, but heat flow (flux) will remain the same.
When controlling for all other variables, the same total heat will be entering the room, the only difference is the Thermal Flux Delta (thermal conductive/capacitance) of how well the cooler can move heat from point A to point B.
That is why and how we use better coolers, their TDelta is better, and that is why people review coolers in the same environment.
Lets do a thought experiment, if you have bottle of champagne to cool ( for V day) and you wanted to cool it, whats the most efficient way cause bae is showing up wearing a garter, thigh highs, and a trench coat in 15 minutes and we forgot the champagne in the trunk and its 90F
We can cool it with water that has a Tdelta of 40F lower than the champagne.
We have air in the fridge that has a Tdelta of 70F lower than the champagne.
We have ice that has a Tdelta of 90F lower than the champagne.
We have salt.
The answer is to add salt to the ice, and a little water to cover as much of the bottle as possible.
Does the salt make ice colder? Nope. It increases the thermal flux of the water, allowing the water to remain liquid water even in below freezing conditions, which increases the chance of the champagne being ice cold and bubbly. Without making this a full physics lesson, you will always have the same amount out as you put in when dealing with heat, the only thing we can change is the amount of transfer to make everything closer to equal.
dorsetknob
9,105 (1.30/day)
In this thought game :)
I'll Play :)
Bucket and a CO2 Fire Extinguisher put bottle in bucket spray with CO2 Fire Extinguisher Instant cold bottle/bucket
Plenty of time to rip that Trench coat off with your teeth
11,691 (1.73/day)
Motherboard Asus
Keyboard Razer
Software A lot.
I'll Play :)
Next time we get our fire extinguishers refilled at work I will nab one and see how cold it actually gets with the CO2, it may be warmer than you think due to the fire suppression chemicals.
dorsetknob
9,105 (1.30/day)
Rest Assured it gets Damm Cold.
Cold enough to give you FROST BURNS, if you fail to read the Safety warnings about holding the CO2 extinguisher nozzle or Horn while using one,
and it also blasts cold enough to cold shatter Steel padlock shanks with a hammer
Air
203 (0.06/day)
Case Ncase M1 V3
Wow. Thread out of control. This complex topic was too much for TPU to handle. Our brains reached critical temperature.
dorsetknob
9,105 (1.30/day)
Prescribes cold Beer
4,213 (0.75/day)
Vietnam
System Name Gaming System / HTPC-Server
Processor i7 8700K (@4.8 Ghz All-Core) / R7 5900X
Motherboard Z370 Aorus Ultra Gaming / MSI B450 Mortar Max
Cooling CM ML360 / CM ML240L
Memory 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz
Video Card(s) Zotac 3080 / Colorful 1060
Storage 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe
Display(s) LG 27GN800-B 27'' 2K 144Hz / Sony TV
Case Xigmatek Aquarius Plus / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum
Mouse Logitech G502 Hero / K400+
Keyboard Wooting Two / K400+
Benchmark Scores Cinebench R15 = 1542 3D Mark Timespy = 9758
No. The CPU produces exactly the same amount of heat. That heat is just over a larger surface area CAUSING a lower temperature.
Temperature does not cause heat change. Heat causes temperature.change. Heat and temperature are 2 different things.
They are no created equal. Some can dissipate larger amounts of heat resulting in lower temperatures on the CPU. But the CPU is the sole source of said heat. When that heat is dumped into another system (the room) it will cause a different temperature change to that system. If the amount of heat being dumped into that system is the same, the temperature change will be the same.
The zero's law might help some to understand better. I don;t have time to explain now, but basically, the CPU in both cases, is trying to reach thermal equilibrium with the air in the room.
20,787 (3.41/day)
System Name Pioneer
I ran my own bitcoin farm and helped with a large scale op, hot/cold aisle arrangement.
I was mistaken though, more qualified people are here. :)
861 (0.25/day)
A couple of people commented that the CPU will draw less power doing the same task if it's cooler (ie it will be more efficient). I figure they measured it?
