XFX R9 380 wrong Bios flash
58 (0.09/day)
hi, Yesterday i wanted to flash my gpu but i think i got the wrong version of it and now my xfx r9 380
Dont wanna do anything when i put dat hdmi in it shows blackscreen with small artifacts
and i dont got a backup of my gpu but the gpu is in task manager
UPDATE: i clean my pc with amd utility in safe mode now i got a signal from my gpu as microsoft basic display adapter anyone can help me pls im done
Can you provide the brand/model/part number of your graphics card?
Can you provide the brand/model/model of your graphics card?
that was before amd cleanup i looked at the back of the gpu radeon r9380x oc dd black
Can you provide the part number. Its on a white lable on the back of the graphics card.
Thats a Serial Number which is not usefull.
Likely this is the correct bios R9 380 (NON-X) bios:
Take some good photos with your phone and post them here, that is what they need to help you.
i think it was successfully so i need the latest r9 380 driver
dont have a phone atm
i cant install drivers it shows blackscreen and driver timeout
Here is a sample photo from the internet with the part number underlined.
thx the flash was successfully but i cant install drivers it shows blackkscreen and Windows TDR Failure... is the gpu dead?
Radeon-R9 380x-45
when i try the pcie test in gpuz with R9 380 (microsoft basic adapter now) no blackscreen or artifacts
atiflash dont work anymore subidmissmatch..
I think you are doing a crossflash to a different model since the GPU-Z screenshot from you shows that you have a R9 380 (NON-X model).
Was this screenshot taken before or after the flash?
Can you make pictures of your card and share it with us?
i cant make photos atm its exactly the same as the bios file you sent
i think the card is not dead bc when i put load in it from gpuz the render test was successfull no screen artifact or whatever
GPUZ
Are you certain it is a R9 380X? Does the card really have Hynix memory on it?
You can try the bios provided by Count von Schwalbe with the instruction of eidairaman1 below:
For RX 500 Series (Polaris) and Older:
Get amdvbflash 2.93
Then look for Version 4.68, underneath 4.68 you will see a link to show older version, click that and you should see version 2.93
Follow these steps carefully:
1. Open your "C:" drive in Windows, create a new folder, call it atiflash.
2. Extract the contents of atiflash_293.zip to the "C:\atiflash" folder
3. Find the bios file you downloaded and rename the bios file to 5 digits with .rom on end Example RX 580, change file to rx580.rom (r****.rom)
4. Move r****.rom to the "C:\atiflash" folder
5. Open the start menu, type cmd, when cmd.exe appears right click it and hit "Run as administrator"
6. At the command prompt type in cd\ and press enter until only C:\> is on the screen.
7. Type in cd/atiflash and press enter, you should see C:\atiflash>
8. Type in amdvbflash.exe -i to identify the gpu you want to flash with a 0, 1, or 2)
9. At the C:\atiflash> prompt type in
amdvbflash.exe -unlockrom 0
(there is a space between the e and -unlockrom and 0)(0 is the number zero)
press enter and you will be prompted that the "ROM Unlocked" (or 1, 2)
10. At the C:\atiflash> prompt type in
amdvbflash.exe -f -p 0 r****.rom
(there is a space between the .exe and -f, and a space between -f and -p and 0).
(Or 1, 2)
Press Enter
Follow directions on screen and if flash is successful exit the command prompt and restart, windows should show up on screen
system dont find the path.. im sure the plate say Radeon R9 380x-45
File r9 380x not found its the last step
pc is restarted after flash
after flash
@Cuz29 You didn't follow the guide of eidairaman1 to flash the vbios properly! Read every step!
  1. First download the vbios from https://www.techpowerup.com/vgabios/185754/xfx-r9380x-4096-151204
  2. Then rename file XFX.R9380X.4096.151204.rom to r9380X.rom
  3. Download amdvbflash 2.93 from https://www.techpowerup.com/download/ati-atiflash/
  4. Unzip atiflash_293.zip to c:\atiflash_293
  5. Move or copy R9380X.rom to c:\atiflash_293
  6. Then open cmd line as administrator and execute the following commands:
    • cd c:\atiflash_293
    • amdvbflash.exe -unlockrom 0
    • amdvbflash.exe -f -p 0 R9380X.rom
  7. Reboot system
i followed all the steps and rebooted
  7. Reboot system
what is the next step?
i deactivated igp in bios and still got a signal
@VuurVOS the latest amd driver from website? dont wanna do anything wrong :D
now
Good to hear! The latest driver for your card is already installed (Adrenalin 22.6.1).
my pc shut down after testing furmark
What are your CPU and GPU temperatures during stress testing?
What PSU do you have?
