Project WaterFall -- A water cooling project log by Phenom
43,587 (6.71/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
kinda fast. It's good to have a small funnel. Fill slowly, but not too slow.
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | Asus 24" IPS (portrait mode)
Mouse Razer Viper v2 Pro
Keyboard Razer Huntsman Tournament Edition
Yeah ill fill it about about the speed that I feel my race bike with coolant.
4,013 (0.75/day)
Yup, pretty damn fast. I usually end up cycling the power switch on the pump's psu, it's damn hard to fill and leave the pump running, I let a 655 suck air for a few seconds that way. Anymore, I usually fill the res and then tip the case some, and try to get a bit of water into the rad and lines. Then I fill the res, cycle the pump till the res gets low, fill the res....on and on.
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
Well this should be interesting. With my luck lately, ill fuck something up. Ill probalby use the small funnel i use for changing oil in my bikes. Ill run it through the dish washer before hand to get all the oil cleaned off.
4,158 (0.80/day)
USA
System Name ASUS ROG Zephrus M15
Processor AMD Rhyzen 7 4800HS
Memory 16GB
Video Card(s) Geforce RTX 2060
Storage 1TB
Now that is awesome ... Now that ODD's are not needing too much anymore, that is a great idea by that person!
Yours WC setup looks pretty good so far, keep it up! :toast:
cadaveca
My name is Dave
17,232 (2.61/day)
You took so long you should have just bought like 8 jugs of water, filled the kitchen sink, and stuff the block, the hose, the rad, all of it in the sink, and filled it that way. :p
Would been dry by now, ready to rock.
:roll:
At the same time, I'm glad you are not rushing it.
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
:roll:
Thats the thing, especially with doing something like this, I don't rush stuff when it comes to my own computer, well computers in general, unless someone needs a computer built quickly.
Im in no rush to have the system up and running right now either so. might as well take that time to do this the right way.
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
I want the guys cabling he has for the PSU.
t_ski
Former Staff
11,960 (1.81/day)
System Name My i7 Beast
Processor Intel Core i7 6800K
Motherboard Asus X99-A II
Cooling Nickel-plated EK Supremacy EVO, D5 with XSPC Bayres & BIX Quad Radiator
Memory 4 x 8GB EVGA SuperSC DDR4-3200
Video Card(s) EVGA 1080 SuperClocked
Storage Samsung 950 Pro 256GB m.2 SSD + 480GB Sandisk storage SSD
Display(s) Three Asus 24" VW246H LCD's
Case Silverstone TJ07
Power Supply Corsair AX1200
Keyboard Corsair K95
Software Windows 10 x64 Pro
Probably custom
1,770 (0.38/day)
Cussing desert
System Name Torquey Vulture
Processor Ryzen 5 2600
Motherboard Gigabyte B450 MiniITX
Cooling DDC water loop, EK block
Memory 16GB Patriot Viper RGB
Video Card(s) EVGA 1070
Storage 500gb NVME; some Phat HDDs
Display(s) Achieva Shimian 27" 2560x1440
Case Thermaltake V1 MiniITX
Power Supply EVGA supernova 850 G2
Mouse Corsair Harpoon
Keyboard Possibly the cheapest you can buy. Shift key broke recently. Space sounds like I'm kicking a ham
Just looks like regular single sleeved
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
I wish there was someone I knew that you could send the PSU to them to have it sleeved. I don't trust myself trying to do the 24 pin.
1,770 (0.38/day)
Cussing desert
I've never sleeved myself; you pull the wires out and slide the sleeving on and then heat shrink them right? For the 24 pin are you just afraid of getting the wires mixed up when youre done, or what?
manofthem
WCG-TPU Team All-Star!
10,960 (2.26/day)
Florida
Processor 3900X @ 4.0
Cooling DeepCool Castle 360EX
Storage Sabrent Rocket Q 1TB
Display(s) LG 34UC88
Case Thermaltake P3
Mouse Logitech G900
I did my own sleeving, having never attempted before, and it wasn't that bad. I really could have used a tool to get the pins out instead of a staple lol (that was the hardest part), but I used what I had. The 24pin was fun, just do 1 at a time. I do wish I has opened the PSU to bring the sleeving into the casing, as oppose stopping it right outside. Eh. Don't use a hair dryer, use a heat gun!
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
Yeah Sleeving is pretty easy. I sleeve my fans, other cables, Just haven't done PSU cables before.
43,587 (6.71/day)
Storage WD m.2
Keyboard Tester84
Loop running yet?
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
Wrigleyvillain
PTFO or GTFO
7,702 (1.27/day)
Chicago
System Name DarkStar
Processor i5 3570K 4.4Ghz
Motherboard Asrock Z77 Extreme 3
Cooling Apogee HD White/XSPC Razer blocks
Memory 8GB Samsung Green 1600
Video Card(s) 2 x GTX 670 4GB
Storage 2 x 120GB Samsung 830
Display(s) 27" QNIX
Case Enthoo Pro
Power Supply Seasonic Platinum 760
Mouse Steelseries Sensei
Keyboard Ducky Pro MX Black
Software Windows 8.1 x64
That's why I don't do build logs.
TheMailMan78
Big Member
22,599 (3.66/day)
'Merica. The Great SOUTH!
The way I build computers it would take longer to take pictures and post them. :laugh:
Of course I don't do anything fancy like this. :toast:
1,770 (0.38/day)
Cussing desert
With my other case, i decided I wanted to paint it so I gutted it painted it and had it back together running in less than 4 hours. I usually like to get my build done and over with quick; but I suppose I can appreciate wanting to take your time
brandonwh64
19,542 (3.65/day)
Ahhh cant wait to see this thing shine! I remember P4 water loop! This thing OCed nicely!
Wrigleyvillain
PTFO or GTFO
7,702 (1.27/day)
Chicago
Display(s) 27" QNIX
Case Enthoo Pro
My Prodigy build is probably worth one (even though they are so common) but, yeah, I need to do things in my own time and got this other project too delaying things further. Can always just post finished pics.
TheMailMan78
Big Member
22,599 (3.66/day)
My Prodigy build is probably worth one (even though they are so common) but, yeah, I need to do things on my own time and got this other project too delaying things. Can always just post finished pics.
Like I said I don't do anything fancy. Im looking forward to seeing Young Shavers build.
Wrigleyvillain
PTFO or GTFO
7,702 (1.27/day)
Chicago
Display(s) 27" QNIX
Case Enthoo Pro
Well one of mine was that I usually don't either.
MxPhenom 216
ASIC Engineer
12,945 (2.59/day)
Loveland, CO
My target is to have it done tonight. Just have the 2 hoses left, and leak testing to do. I hope to got I dont have leaks!
If this allows me to clock my 680 from 1275 to near 1400. Ill be happy. Right now the only thing stopping me is temps.
43,587 (6.71/day)
Storage WD m.2
Keyboard Tester84
Are people getting their 680's that high under water?! I think you'll find that heat won't be your limiting factor.
