Water cooling an Antec 300
5,106 (0.83/day)
Kansas
Processor Core i5 3570K
Motherboard AsRock z77 Pro4
Cooling Zalman CNPS10X Extreme
Memory 2x4GB GSkill Sniper
Video Card(s) MSI GTX970 Gaming
Storage 240GB OCZ ARC 100, Samsung Spinpoint F3 1TB
Display(s) LG 23" 1920x1080
Case Antec P100
Power Supply Antec Edge 750W
Software Windows 8.1 Pro 64
Oh. Well, I'm a big fan of heckling if it's understood. :laugh: Carry on then. :p
p_o_s_pc
F@H&WCG addict
13,006 (2.10/day)
Newark ohio
System Name el'lappy|Cruncher | Cruncher 2
Processor intel C2D T6400 | i7 3770k @4.2ghz | AII X2 220 @3.4ghz
Motherboard some Acer | Asus P8Z77-V Pro |Gigabyter GA-M61p-S3
Cooling dual 80mm cooling fan | WC'ing ) |cheapo
Memory 2x2gb ddr3 | 2x2gb Ripjaws 1600 |4x512mb D9s
Video Card(s) onboard | 60 1GB(hd7770 ) |8800GTS
Storage Momuntus xt 320gb |Kingston Hyper X 120gb SATA III|500gb WD
Display(s) 17in | 42" 1080P HD 3D TV
Case lappy case | CM HAF XB |none yet
Audio Device(s) onboard | onboard | onboard
Power Supply Dell brick w/ acer end end | Antec EW 650w |Antec SP 350w(upg.soon)
Software Windows 7 Ult. 64bit---->------->
haha well WM With Tubing Is A Whole New Level Of WM
You know how big of a bitch WM was in a 300 when it was stock so just think of how much worse it is now that the bays are removed,rads are mounted and have to deal with tube.
p_o_s_pc
F@H&WCG addict
13,006 (2.10/day)
Newark ohio
You Must Be Going Insane.
slap the side on it and forget about it for as long as possible :shadedshu seems to work...
I am going to go i think i am going to puke and got to bed :banghead:
28,823 (4.81/day)
Miami, Florida
Motherboard ASUS ROG Crosshair X670E Hero
Cooling ARCTIC Liquid Freezer III 360 A-RGB // X12 Phanteks D30-120 D-RGB Fans
Memory G.SKILL Trident Z5 Neo RGB Series (AMD Expo) DDR5 RAM 32GB (2x16GB) 6000MT/s CL30
Video Card(s) ZOTAC Gaming GeForce RTX 4090 AMP Extreme AIRO
Storage Samsung Pro 980 2TB NVMe (OS and Games) // WD Black 10TB HDD (Storage)
Display(s) SAMSUNG 34-Inch SJ55W Ultrawide Gaming Monitor (LS34J550WQNXZA) – 75Hz Refresh WQHD Computer Monitor
Case Phanteks NV7
Power Supply Seasonic Vertex GX-1200, 1200W 80+ Gold, ATX 3.0
Looks good Tim, give it that final coat or two and it'll look even better :D
p_o_s_pc
F@H&WCG addict
13,006 (2.10/day)
Newark ohio
today i gave the block a much needed cleaning inside and out. I didn't get any pics of the inside but here is the bottom after cleaning with ketchup and then spending ~30mins with some rubbing compound then cleaned with some good ol' alcohol.I also did the copper parts of the sides. the block looks much better all around. Maybe temps will be alittle better now that it looks like new all around.
p_o_s_pc
F@H&WCG addict
13,006 (2.10/day)
Newark ohio
did alittle more work on the WM i think its looking better. Seeing the case without the rads in it shows that i really need to do some cleaning and give it another paint job.
the water cooling will be out till i get the new pump sometime next week i hope.
p_o_s_pc
F@H&WCG addict
13,006 (2.10/day)
Newark ohio
did alittle work on my block
lets just get down to the good stuff no point in listing all of the prepping i had to do. I painted(yes painted) the top of the block with automotive matlic paint at a buddy's shop.The finish was getting scratched and was chipping so i thought it may look better
then after that was done i lapped the base and finished it off with rubbing compound/polish
28,823 (4.81/day)
Miami, Florida
Case Phanteks NV7
Love what you did with the block, the lapping job looks mighty good bro :respect:
p_o_s_pc
F@H&WCG addict
13,006 (2.10/day)
Newark ohio
I spent 7 hours from start to finish to get what you see above.(the painting and lapping)
28,823 (4.81/day)
Miami, Florida
Case Phanteks NV7
Very good job bro. I would love to see that thing installed already :)
6,823 (1.27/day)
Viking Land
System Name Ivy Biatch
Processor i5 3570K
Motherboard ASSRockzz z77TOTHEEXTREME!!!!
Cooling bleh
Memory 2x4gb crucial 1866
Video Card(s) HD7770, yes it does BF3
Storage 120gb Vertex
Display(s) 226BW
Case whats that, oh my table
Audio Device(s) stock onboard thing
Power Supply HX850W
Software 7
i hate the lapping part(to do it) but when youre done you get happy:D
28,823 (4.81/day)
Miami, Florida
Case Phanteks NV7
6,823 (1.27/day)
Viking Land
Processor i5 3570K
Cooling bleh
Display(s) 226BW
Power Supply HX850W
Software 7
:d
p_o_s_pc
F@H&WCG addict
13,006 (2.10/day)
Newark ohio
once i get my pump i will get it put on.I don't want to wait for the new barbs so i am just going to have to drain the loop again when i get them.
[Ion]
WCG Team Assistant
13,391 (2.51/day)
Raleigh, North Carolina, United States
System Name Niedersachsen / Ribe / Minsk
Processor i3 3240 / i7-3520M / 4x Opteron 6376 @ 2.86GHz
Motherboard BIOSTAR H61M / HP Q77 / Supermicro H8QG7
Cooling Stock / Stock / 4x 1U G34
Memory 1x8GB / 2x4GB / 4x4GB
Video Card(s) GTX260 / Intel HD 4000 / nVidia GT310
Storage 80GB Intel SSD / 256GB Intel SSD / 2x 60GB SSD (RAID1)
Display(s) Dell 3007 + HP 2245w / 12.1" 1366x768 / None
Case Antec NSK3480 / HP / Supermicro 1U
Power Supply Enermax 500W / HP 130W / Supermicro Gold 1400W
Keyboard IBM Model M
Software Windows 7 (Niedersachsen/Ribe) / Linux Mint 17.2 (Minsk)
That looks great :)
It really is a lot cleaner without the WCing, surprisingly cleaner actually.
I'm actually surprised that you can get the cables that clean, even in the stock A300 I had my cables looked a lot worse :eek:
p_o_s_pc
F@H&WCG addict
13,006 (2.10/day)
Newark ohio
That looks great :)
its because i am kinda OCD and the cables make me go insane if they aren't "clean" so i can wake up in the middle of the night and start doing WM.:ohwell:
[Ion]
WCG Team Assistant
13,391 (2.51/day)
I'm the same way (well, not quite), cables bother me if they aren't perfect. The SATA power cable i nmy computer is too short to make it do what I want to, as is the mobo cable. I'm thinking of getting the NZXT single-sleeved 24-pin extension because I could do some cool things with that. And maybe the 6-pin one for the GTX260
p_o_s_pc
F@H&WCG addict
13,006 (2.10/day)
Newark ohio
i am thinking about getting one of the 8pin ones for the CPU power so i can cut some small holes in the case and run it behind the mobo tray and have it come in on the top side of the mobo that would help things out. but i don't think i can get much better without cutting
[Ion]
WCG Team Assistant
13,391 (2.51/day)
My 8-pin is in straight sight running along the bottom of the case from the PSU to the mobo, but it looks pretty good IMO. An extender would probably make it look worse because there would be the plug between the cable from the PSU and extender.
p_o_s_pc
F@H&WCG addict
13,006 (2.10/day)
Newark ohio
i think the best thing for me to do would be to cut a hole in the bottom of the case (air holes) for the PSU to suck some cool air in so i could flip the PSU. If i didn't want to cut all of it out i'm sure i could drill some holes and that should work (but not look the best)
[Ion]
WCG Team Assistant
13,391 (2.51/day)
Yeah, that would be good :)
In my PC-A05S there's about 3/4 of an inch before the solid aluminum, which, while not ideal, is good enough
p_o_s_pc
F@H&WCG addict
13,006 (2.10/day)
Newark ohio
As you know the 300 doesn't leave hardly any room to work with. When i used lower power stuff and didn't crunch and fold i had no problem running the PSU flipped the other way. It gets way too hot if i try that now that i have the i7 and always have a CPU and GPU load.
[Ion]
WCG Team Assistant
13,391 (2.51/day)
Yeah, with my A300 I was running a C2D and an 8600GTS on a Corsair CX400w, so I had it flipped upside down. Total power draw was under 150w folding/crunching, so I wasn't afraid of damaging the PSU (it wasn't even warm to the touch).
My XFX PSU is pretty warm to the touch, is this bad? I don't want to mess with it, but I will if I have to
