1440p 27" vs 1080p 24" looks basically the same.
3,102 (2.01/day)
Germany
Processor AMD Ryzen 9 9950X3D
Motherboard ASRock B850M PRO-A
Cooling Corsair Nautilus 360 RS
Memory 2x32GB Kingston Fury Beast 6000 CL30
Video Card(s) PowerColor Hellhound RX 9070 XT
Storage 1TB Samsung 990 Pro, 2TB Samsung 990 Pro, 4TB WD SN850X
Display(s) LG 27GS95QE-B, MSI G272QPF E2
Case Lian Li DAN Case A3 Black Wood Edition
Power Supply Corsair RM1000X ATX 3.1
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
my current Monitor since around 10 months is the LG GL850B.. basically "THE" 27" 1440p 144Hz Monitor.
my friend recently bought an Acer XF3 (or as it's sold with the name: "xf243y pbmiipx")
it's a 1080p 24" 165Hz IPS Monitor for around 60% less money than my GL850.
side by side (except of the actual space due to the resolution) the picture quality in games is basically the same.
textures are almost identical, overall sharpness and clarity is barely noticeable... (except aliasing in games with awful AA implementations like CoD Warzone)
and when actually playing a game i can not tell any difference except when i hold my face literally 10cm infront of the screen and cherry pick some minor differences.
after having two decent Panels side by side my opinion has changed. 1080p or 4K. 1440p feels like a 1080p replacement for 27" and above.
486 (0.15/day)
Processor Intel i7 4770k
Motherboard ASUS Sabertooth Z87
Cooling BeQuiet! Shadow Rock 3
Memory Patriot Viper 3 RedD 16 GB @ 1866 MHz
Video Card(s) XFX RX 480 GTR 8GB
Storage 1x SSD Samsung EVO 250 GB 1x HDD Seagate Barracuda 3 TB 1x HDD Seagate Barracuda 4 TB
Display(s) AOC Q27G2U QHD, Dell S2415H FHD
Case Cooler Master HAF XM
Audio Device(s) Magnat LZR 980, Razer BlackShark V2, Altec Lansing 251
Power Supply Corsair AX860
Mouse Razer DeathAdder V2
Keyboard Razer Huntsman Tournament Edition
It's been known for a while that 27" is ideal for 1440p, while up to 24" is ideal for 1080p. 1080p should look less sharp on 27". I think I read somewhere that 4K makes sense above 32".
18,584 (2.64/day)
System Name AlderLake
My 1440p dell monitor is just 23.8" and got 123dpi, so very sharp.
17,900 (4.66/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710
yep, I wish they made high end IPS panels at this size and rez, to my knowledge only TN exists and even then it doesn't exist anymore.
agree with all.
You are 90% correct - 1080p 23.8" high end IPS that came out within last 6 months or so, it a bit of a different beast than 1080p of the past. Not sure what they did, but I can also tell the difference. It's still not as sharp as 1440p, but it has improved somehow, which I know doesn't sound possible... but I understand exactly what you mean oddly enough. I really love my 1080p IPS 0.5 ms panel, it's really gorgeous in game and no FPS hits like the higher rez's.
this is my monitor. I highly recommend it. I also plan to have a dual monitor setup with a 1440p someday. I do expect text and such to be a little sharper. but not by much... in-game, when you have game settings maxed out - you are correct, its getting harder to tell. websites and text and game icons I can tell a little. but its not as bad as a 25" 1080p.
3,102 (2.01/day)
Germany
you mean this one? :)
1,928 (0.40/day)
Romania
It's a subjective thing.
At work i sit about an arms length from the monitors. At home i sit more than one meter from my 32" 1440p display. That is the ideal size and resolution for me. I also have a 32" 1080p display that is ok if you sit more than a meter away and you only do multimedia and gaming.
Eye sight is also a factor, i keep the text size to 125% for 1440p as that is most comfortable for reading for me. 27" 1440p is too small for me, i used to have a Dell and an Asus 27" 1440p at home that i kept at 125% display scaling. At work i have an Apple display and the text size is uncomfortable small in some applications i use.
For me, monitors are a try and buy thing, specs alone are not enough.
7,477 (1.04/day)
Video Card(s) Sapphire PURE AMD Radeon™ RX 9070 Gaming OC 16GB | Intel® Iris® Xe Graphics
My old 23,8inch was 1440p and my 27inch is 4K.
I feel 1080p is blurry at 23,8inch and more but 1440p is a sweet spot and 4K at 27inch can be small but I enjoy a big desktop and so on :D
18,584 (2.64/day)
24" 1080p = 92dpi
27" 1440p = 108dpi
2,094 (0.54/day)
Calabash, NC
System Name The Captain (2.0)
Processor Ryzen 7 7700X
Motherboard Asus ROG Strix X670E-A
Memory 32GB (2x16) Kingston Fury Beast CL30 6000MT/s
Display(s) Asus ROG Swift PG32UCDM (main); Asus ROG Swift PG27AQDM (secondary)
Keyboard Varies based on mood; currently Razer Deathstalker V2 Pro TKL
My monitor is 1080p, 27" . 27" is my sweet spot. It's big enough to where I don't have to strain my eyes, but small enough to still fit on my desk, lol.
23,826 (6.15/day)
Correct.
The calculation here is Pixels Per Inch, or PPI.
A 1080/24in model has 92 PPI or so
A 1440/27in has just over a hundred.
You can check any size/res here. Ppi relates to the ability of the human eye to discern detail and around 100 is suited for ergonomic viewing distance with mainstream diagonals/ office work use case while not being butt ugly.
Going higher in PPI will increase your tendency to 'crawl into your screen' as you work harder to distinguish detail.
Frick
Fishfaced Nincompoop
20,040 (2.86/day)
norr
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
The programs you run are also very important. A very common bussiness software used by many, many companies in the Nordic countries doesn't do scaling at all; it all becomes blurry.
1,374 (0.35/day)
Processor 3900X 4.425
Motherboard X570 Tomahawk
Cooling Galahad 360 push-pull
Storage Optane 280gb PCI-E
Display(s) PG348Q
Case Core X71
Power Supply AX1500i
I'm personally in the trend of horizontally increasing things aka ultrawide, Xiaomi and LG have come up with cheaper but still seemingly decent VA options there, high refresh rate. Wider than 27, not as power hungry as UHD. Best of both worlds IMO.
4,928 (0.97/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
My two 27" monitors look the same for gaming picture quality ( LG 27GL83A-B & Dell - SE2717H 27") even though one is 1440p and one 1080p. Actual picture quality (real photos) is a different story. Comparing PPI is great in panels that are of relative quality otherwise I don't find it telling me much. From Tom's review of my Dell monitor;
"We’ve said time and time again that resolution does not matter nearly as much as motion quality, contrast, and color accuracy. When the gaming planets are aligned, the extra pixel density provided by a QHD or UHD screen just doesn’t have much additional impact."
3,418 (1.02/day)
Buenos Aires
System Name Ryzen Monster
Processor Ryzen 7 5700X3D
Software Windows 11 Start 11
I definitely noticed a big difference when I moved up from a Samsung CF591 27" 1080p to an LG GK650F Ultra Gear 32" 1440p 144Hz.
There could be numerous factors at play, with no more tearing, I can't even see the pixels and gaming is ultra smooth. Of course, it may also be a case of favourable perception on my part, but the extra size certainly makes games much more immersive.
las
1,693 (0.37/day)
System Name Meh
Case Fractal Design North XL
Audio Device(s) FiiO DAC
1440p on a 27" is by far better than 1080p at 24"
No comparison if you ask me. 1080p needs massive AA to look decent. 1440p does not. 80% more pixels. Way better image quality and much better for work outside of games too.
I could never live with a 1080p monitor today. If I _only_ played games? Maybe. Still not sure, 1080p sucks badly for browsing - you are scrolling all the time.
r9
3,300 (0.54/day)
System Name Primary|Secondary|Poweredge r410|Dell XPS|SteamDeck
Processor i7 11700k|i7 9700k|2 x E5620 |i5 5500U|Zen 2 4c/8t
Memory 32GB DDR4|16GB DDR4|16GB DDR4|32GB ECC DDR3|8GB DDR4|16GB LPDDR5
Video Card(s) RX 7800xt|RX 6700xt |On-Board|On-Board|8 RDNA 2 CUs
Storage 2TB m.2|512GB SSD+1TB SSD|2x256GBSSD 2x2TBGB|256GB sata|512GB nvme
Display(s) 50" 4k TV | Dell 27" |22" |3.3"|7"
VR HMD Samsung Odyssey+ | Oculus Quest 2
Software Windows 11 Pro|Windows 10 Pro|Windows 10 Home| Server 2012 r2|Windows 10 Pro
To add to the topic IMO I would rather play on 50" FullHD TV @ 1080p than on 50" 4K TV @ 1440p.
It's just the way 1080p is natively rendered pixel by pixel on FullHD panel looks better to me than 1440p blurred on 4k panel.
las
1,693 (0.37/day)
System Name Meh
Depends on the TV I guess. My LG C9 OLED renders 1440p perfectly fine. Looks clearly better than 1080p (less jaggies)
1,859 (0.53/day)
North Dakota
System Name Office
Processor Core i7 10700K
Motherboard Gigabyte Z590 Aourus Ultra
Video Card(s) Intel ARC A750
Display(s) Dell S2719DGF
Case Fractal Define 7 Compact
Power Supply EVGA 550 G3
Mouse Logitech M705 Marthon
Keyboard Logitech G410
Software Windows 10 Pro 22H2
For me, it depends on what's happening. Watching stuff: wide. Doing stuff: tall. I miss 4:3 for CAD, and they're also better for portrait mode.
1,110 (0.58/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Philips
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
1,374 (0.35/day)
Display(s) PG348Q
Case Core X71
I'd side towards TVs for watching stuff, like at least 49 or so as long as you have a decently sized room. Netflix and such experiences are certainly better there.
3,079 (1.15/day)
System Name System V
Processor AMD Ryzen 7 9700X
Case NZXT Source 210
Me using Visual Basic 5.0 apps that don't work at all if you have a touchscreen. And don't do scaling at all.
1,260 (0.29/day)
Artem S. Tashkinov
Not in my experience.
I've upgraded just recently and the pixel density for a 27" QHD monitor is quite higher than for my previous FHD 24" panel.
In Windows I've enabled 125% scaling for UI, in Linux I had to either increase fonts, or increase scaling in my web browsers because everything became quite smaller.
My vision is not 20/20 though.
2,540 (0.47/day)
I went nuts over full screen antialiasing a while ago. It turned out that was pretty much planned obsolescence. If I were to develop it, I wouldn't base the resolution on "helper pixel" unfiltered image. The stupidest filters did ironically more to alleviate it.
If it was available, analytical filters on 2xRGSSAA final blend target would do best. However the analytical filter didn't target the final frame buffer, so the downscale filter didn't do its low-pass filtering like I wanted to.
If games used advanced filters like MadVR I would replicate it with something like a 25/150 double/quad super-xbr luma scaler, just something to upscale after staircase effect artifact filtering.
