5800x (and other Zen 3 chips) PBO settings/Temperature fix
20 (0.03/day)
Germany
System Name sadness
Processor 5800x 4.4 1.2V
Motherboard MSI B450M Mortar Max
Cooling NZXT Kraken V53
Memory 2x 8GB G.SKILL TridentZ 3200 not B-Die
Video Card(s) Zotac RTX 2070 Mini 2050MHz OC
Storage 1x Samsung 970 Evo Plus 2x Seagate 2TB HDD 7200RPM
Display(s) 1x BENQ 60hz 1x 144hz AOC C24G1
Case idk some rando Corsair one
Audio Device(s) DT 770 Pro 250Ohm on Fiio DAC
Power Supply China-D Boeller
Mouse Glorious Model D White
Keyboard custom built
I would say thats pretty good, im running it -20 on few cores and -26 on the others with AutoOC +200, you should check for WHEA errors too (if you are running high IF).
Edit: Try testing with CoreCycler too ,it detects per core instability, sometimes it worked fine for me with OCCT but not in CC and had to change to CO for the respective core.
0 WHEA Errors in 8 hours of testing (not fully 8hours full test but ive been testing since 12pm)
Core Cycler i have the Usage bug and turning the Flag on for the fix just makes it work regardless
weird.
Ihave now run this for 20mins about 5 times now in a row. Nothing.
Is it stable? What do you guys think.
I testedwith Auto Voltage and Clocks and im now gonna limit it back to 4.6Ghz and 1.25V. Will it still work? Im daily driving -20 on all of em.
Yep MW2 just froze on me after about an Hour of gameplay.
  • Like
Reactions: izy
65 (0.31/day)
Processor Amd 5800x
Motherboard MSI MAG X570 TOMAHAWK WIFI Motherboard
Cooling Corsair h100i
Memory 32gb
Video Card(s) 3070ti
Storage Nve, SSD,
Display(s) 27 inch
Power Supply 850 watt
Can someone explain what putting co at -20 on few cores and -26 on the others and AutoOC +200 does on games and overall!?
You can be GPU limited , check your GPU usage at the same time.
What MB you have? On MSI you can find it under OC - Advanced CPU configuration.
I'm limited by a 3070ti lol.. I have a MSI MAG X570 Tomahawk mobo
izy
662 (1.47/day)
I'm limited by a 3070ti lol.. I have a MSI X570 Tomahawk mobo
CO aka curve optimizer is a option to undervolt your CPU , the idea behind it is that your CPU will run cooler with less voltage but not all CPUs / cores are the same, some can work with lower values than others.
AutoOC will increase your maximum boost clocks by up to 200mhz if your CPU is capable and thermals are low enough.
One thing to know is that CO will take different values with and without AutoOC or if you change autooc value, higher autooc values can lead to less undervolt and higher thermals, you need to find the sweet spot for your CPU.
With those settings my CPU is boosting to 4800 4850 in games and 4600 4650 cinebench allcore on air cooling (depending on the room temp) , i dont play many games so i cant tell you if there is an important difference or not in performance.
Mussels
Freshwater Moderator
58,123 (8.39/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Where do you enable c states in bios?
they're on by default, you have to disable them manually.
It could change nothing, make things faster, slower, or unstable. No one can answer questions like this.
Well yes, you could easily be GPU limited by that in certain games, especially anything with RTX.
And try and state the full motherboard name and not something that covers an entire series of boards post your full system specs so people helping dont have to hunt through your post history to help you
918 (0.51/day)
Uttar Pradesh, India
Processor AMD R7 1700X @ 4100Mhz
Motherboard MSI B450M MORTAR MAX (MS-7B89)
Cooling Phanteks PH-TC14PE
Memory Crucial Technology 16GB DR (DDR4-3600) - C9BLM:045M:E BL16G36C16U4W.M16FE1 X2 @ CL14
Video Card(s) XFX RX480 GTR 8GB @ 1408Mhz (AMD Auto OC)
Storage Samsung SSD 850 EVO 250GB
Display(s) Acer KG271 1080p @ 81Hz
Power Supply SuperFlower Leadex II 750W 80+ Gold
Keyboard Redragon Devarajas RGB
Software Microsoft Windows 10 (10.0) Professional 64-bit
Benchmark Scores https://valid.x86.fr/mvvj3a
Try with AVX2 instruction set instead of SSE. Similar to the pic below. 30 min to 1 hour test. If it passes this OCCT stress test and Y-cruncher 2.5B then I would say that system is stable. This OCCT test automatically detects WHEA errors as well.
Mussels
58,123 (8.39/day)
Oystralia
Used this thread to fix a randoms issues from FB
He'd used curve optimiser because The Internet(TM) said to, but that enabled PBO and ran 140W through a board that chokes at 100W
Copied the efficient settings from the OP for a 5800x onto his 5950x, and tada no more thermal throttles with 90C VRM's and all game stuttering is gone
65 (0.31/day)
Processor Amd 5800x
Memory 32gb
Storage Nve, SSD,
Display(s) 27 inch
Sorry but uhh that's the full name of mobo lol MSI MAG X570 TOMAHAWK WIFI Motherboard
izy
662 (1.47/day)
Do you have SVM on or off?
Your CPU hits 90C and VR MOS 80 .. damn!
Here is mine , the clocks are 4600- 4650 during the test, didnt had patients to let it run for 1 hour now but my temps are lower.
20 (0.03/day)
Germany
System Name sadness
Weird.Anyone have an idea what might crash Photoshop for me here?
Im using Object Selection tool and it randomly crashes sometimes when selecting it.
Using a B450 Mortar Max with as above -20 all core atm, 4.6 locked with 1.25V locked.
Below are my PBO Settings
OneMoar
There is Always Moar
8,681 (1.77/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Cooling Enermax ETX-T50RGB
Storage ADATA SX8200PRO NVME 512GB, Intel 545s 500GBSSD, ADATA SU800 SSD, 3TB Spinner
Mouse Kone burst Pro
Keyboard EVGA Z15
this thread is for discussing temps/efficiency related to pbo settings
not for general overclocking stablity
please start a new thread
918 (0.51/day)
Notice my system temp is 45C and yours is 31C. Under normal everyday usage my VRM barely go over 60 under load. Also I was running Vcore @ 1.41V average during the test for 1 hour straight.
Ambient temp was around 42 degrees C and my setup was out of the case with 0 airflow. temps are fine. Also can't compare your test with mines when you ran it for 12 minutes under cooler conditions.
izy
662 (1.47/day)
I didnt post it as a competition i thought you missed something or you have a cooling problem having this high temps when mine are like 10c lower on air.
918 (0.51/day)
Not sure what that reply about competition has to do with anything. I pointed out facts why my temps cant be compared to yours and why it is on the high side, I am also running an aircooler as well.
Has stated previously temps are fine as well had my CPU performance.
You have seen my benchmarks posted all over this forum if there was a problem then I would know. Thanks for the concern. Sweet :)
izy
662 (1.47/day)
I felt that you got annoyed by my post, i wasnt concerned i only made an observation.
918 (0.51/day)
5 mins test system temp around 40C. CPU Stock PBO on aircooler. I could probably do with some fresh thermal paste but as I said temps are fine. :)
Ambient air temps plays an import role when running an aircooler. Considering I am probably in a much warmer climate than you its not directly comparable.
  • Like
Reactions: izy
65 (0.31/day)
Processor Amd 5800x
Memory 32gb
Storage Nve, SSD,
Display(s) 27 inch
I'm running the CO optimizer in Ryzen master. What do yall think? Looks like core 7 was running 18 the others were all in the mid 70s
Looks like I got a dud...
65 (0.31/day)
Processor Amd 5800x
Memory 32gb
Storage Nve, SSD,
Display(s) 27 inch
Bump anyone!? How are my numbers looking is there anything I should change? I just ran the CO test in Ryzen master to get these values
izy
662 (1.47/day)
You should run OCCT avx2 extreme or CoreCycler and test for stability.
65 (0.31/day)
Processor Amd 5800x
Memory 32gb
Storage Nve, SSD,
Display(s) 27 inch
Is that really necessary if Ryzen master was run for one hr to determine these settings? How do they look? Should I change any of the pbo settings or add any boost 200hz? I was thinking when using Ryzen master to find best settings it also balances for stability?
izy
662 (1.47/day)
If you want higher boosts you can add up to 200mhz but the CO values wont be the same , cores will need more voltage to achieve higher clocks , you have to find right balance of PBO / CO / AutoOC and temps for your setup, sometimes lower AutoOC can have better result because of the lower temps and so on.
The CO values found by Ryzen Master seem OK , every chip has its own stable values depending on the silicon quality, if you want to push better values that those you should check with OCCT and CoreCycler they tend to be more accurate about stability than Ryzen Master in my opinion and they can tell you which core is not stable and needs to be adjusted.
65 (0.31/day)
Processor Amd 5800x
Memory 32gb
Storage Nve, SSD,
Display(s) 27 inch
Does core cycler also adjust pbo values or just the curve op values? It looks like Ryzen also adjusted the pbo values bc these were not the same ones I had... By adding boost to 200mhz what does that do in games? If none of this adds anything significant in gaming then I don't really care to change from what Ryzen has put as values. I do notice with these values Ryzen master has set that my temps are much lower bc I hardly ever hear my fans ramp up like they were doing before is that due to the curve optimizer settings that were adjusted by Ryzen master?
izy
662 (1.47/day)
Core Cycler is just a tool to test if your cores are fully stable and shows an error on the respective core if its not, you cant change any settings with it and anyway its best if you set up the curve in the BIOS after you tested and its OK.
Adding 200mhz gives you a 200mhz boost if you have good cooling and your CPU is stable with good values on CO, for me after adjusting the curve mostly to max of what my CPU can handle with +200mhz AutoOC the CPU is boosting 4800mhz 4850mhz in games and temp up to 65C - 72C depending on the game and a max temp of 78C-83C in stress testing. (on air in a small case with ID-COOLING SE-224-XT)
I didnt check before and after in games but Cinebench scores are higher , im getting sc ~1600 / mc ~16000 points, you just have to test it yourself.
65 (0.31/day)
Processor Amd 5800x
Memory 32gb
Storage Nve, SSD,
Display(s) 27 inch
Got my first crash today in ghost song of all games lol could have been a game pass issue that made it crash though... Ugh
65 (0.31/day)
Processor Amd 5800x
Memory 32gb
Storage Nve, SSD,
Display(s) 27 inch
Bump how do yall setup your fan curve on 5800x cpu?
47 (0.08/day)
UK - Sheffield
System Name Maddogg Custom Build
Processor Ryzen 9 5900X PBO 4.95Ghz (UnderVolted Curve Optimizer)
Motherboard MSI MAG x570 Tomahawk WiFi
Cooling Fractal 360mm AIO
Memory 32GB G.SKILL Trident Z Neo 3600mhz (b-die)
Video Card(s) MSI RTX 3080 Gaming X (running STRIX 450W OC Bios)
Storage Samsung 970 EVO NVME
Display(s) Gigabyte G32QC 31.5" 165hz 1440p
Case Corsair 4000D Airflow (White)
Audio Device(s) Corsair Virtuoso 7.1 Headset
Power Supply Corsair HX1200
Mouse Corsair M65 ELITE Gaming Mouse
Keyboard Corsair K70 RGB mk2 SE
Software Windows 11 Pro (Ghost Spectre)
Benchmark Scores 3DMark Timespy - 18652 https://www.3dmark.com/spy/38309113
This guide should help you. Depends how agressive you want the curve. But set up as per guide then adjust to your personal preference. Theres so many varying factors with fan curves depending on types of fan static case pressure, pull vs push. Location of the PC itself. Room Temp's etc etc. list goes on. But main thing is finding the most audible bearable fan speed the doesnt make your ears bleed, and that can actually cool your pc during load for me.
