- Jan 22, 2020
- 1,150 (0.59/day)
- Turkey
System Name | MSI-MEG |
Processor | AMD Ryzen 9 3900X |
Motherboard | MSI MEG X570S ACE MAX |
Cooling | AMD Wraith Prism + Thermal Grizzly |
Memory | 32 GB |
Video Card(s) | MSI Suprim X RTX 3080 |
Storage | 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD |
Display(s) | 27" LG 144HZ 2K ULTRAGEAR |
Case | MSI MPG Velox Airflow 100P |
Audio Device(s) | Philips |
Power Supply | Seasonic 750W 80+ Gold |
Mouse | HP OMEN REACTOR |
Keyboard | Corsair K68 |
Software | Windows10 LTSC 64 bit |
I've bought 4 identical Corsair Rams from amazon for my desktop system. I purposedly choosed the same brand for compatibility. But when I look at ram specs, I see that 2 of sticks are made from Samsung, and the other 2 is from Hynix. While the timings and frequencies are exactly the same, I suspect different manufacturer can hinder the performance or pave to way for incompatibility? Or is there any quality difference between those two chip makers? Should I return 2 of the sticks? What do you think?
This is the products I bought:
www.corsair.com
And here is what it looks like when looking with Cpu-z
VENGEANCE® LPX 16GB (2 x 8GB) DDR4 DRAM 3600MHz C18 AMD Ryzen Memory Kit - Black
VENGEANCE LPX memory is designed for high-performance overclocking. The heatspreader is made of pure aluminum for faster heat dissipation, and the eight-layer PCB helps manage heat and provides superior overclocking headroom.
