- May 18, 2011
- 1,075 (0.23/day)
Processor | 7800X3D |
Motherboard | ASRock X670E Lightening PG |
Cooling | Thermalright Phantom Spirit 120SE CPU cooler, 3x 140mm, 1x 120mm case fan |
Memory | 32GB G.SKILL Flare X5 DDR5 6000 (PC5 48000) F5-6000J3038F16GX2-FX5 |
Video Card(s) | ASUS RTX 4070 |
Storage | 2TB Sandisk SSD, 2TB P31 SK Hynix, 4TB WD SN850X, WD Black 6TB, WD Red Plus 12TB |
Case | Fractal Design Definse S |
Power Supply | Seasonic Focus 750 |
Mouse | Logitech Pro |
Keyboard | Corsair Strafe Cherry MX Silent w/red LED |
VR HMD | HTC Vive |
Software | Win 10 Pro |
I am looking to improve the cooling in my PC a bit. There is not a whole lot I can do with my current case, but I am wondering if I can improve my air flow at the front of the case. I am using a Corsair 550D:
In the front of the two HDD/SSD bays there are two included 120mm fans which I have installed. On the back of each bay I have two older Antec tri cool 120mm fans. They're set to a medium setting, which is roughly similar in terms of noise and air flow as far as I can tell.
Although the designs and CFM are obviously not exact. My question is, does a proper push/pull setup require both the front and rear fan to be of the same RPM and design for optimal results? I can always remove one Corsair fan from the front, one Antec from the back, and make the top bay be Corsair and bottom be Antec only for symmetrical front/rear fans.
I do pop off the side panel on the hotter days which does bring down the temps by a good bit. The rest of the year I keep it on and the PC stays very cool and quiet (I like quiet designs).
