checksum error
paulmars
6 (0.00/day)
4 year old foxconn diy box.
flashed bios successfully 3.5 years ago and everything was fine.
I have wiped HDD and reinstalled xp pro sp3 several times over the years. I decided that it was time again. Unplugged everything and air compressor blew out the box. plugged everything back in. On boot:
cmos checksum error
f1 run setup
f2 load defaults and continue
Ive never seen this before.
f2 usually lets it boot into xp
f1 I make changes, but on reboot it gives me the same error. On entering f1 again I see that no changes that I make stick.
moved jumper to reset. Put jumper back and still have this issue. Battery was 3.08 volts. Still I tried a new battery. Still have the issue.
old install of xp getting slower and more buggy, so decided to reinstall despite this issue. Reinstalled xp pro sp3 and my other programs early last month. Its much faster now and not buggy anymore, however I still have the checksum error, not that I expected this to fix it.
ideas to fix checksum error??
tks,
pa
44,267 (6.80/day)
check the bios jumper, also you might need a new bios chip...
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
Or a new hard drive
95Viper
Super Moderator
13,301 (2.20/day)
4 years old and won't save changes... Replace your CMOS battery.
Or, make sure you didn't blow it loose or anything.
cdawall
where the hell are my stars
27,683 (4.04/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
Reseat the memory, change the battery and try again.
Aquinus
Resident Wat-man
13,198 (2.73/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 15.3.1
This. Make sure your CMOS and clock batteries aren't dead.
44,267 (6.80/day)
Did you change battery or you not listening?
paulmars
6 (0.00/day)
Did you read my post or are you not comprehending? "Battery was 3.08 volts. Still I tried a new battery"
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
I wouldn't act like a dick while asking for help. Tends to turn people off of your case.
Bios could be corrupt have you tried updating it?
1,349 (0.21/day)
Milwaukee, Wisconsin, USA
Processor i7-3770K
Motherboard Biostar Hi-Fi Z77
Cooling Swiftech H20 (w/Custom External Rad Enclosure)
Memory 16GB DDR3-2400Mhz
Video Card(s) Alienware GTX 1070
Storage 1TB Samsung 850 EVO
Display(s) 32" LG 1440p
Case Cooler Master 690 (w/Mods)
Audio Device(s) Creative X-Fi Titanium
Power Supply Corsair 750-TX
Mouse Logitech G5
Keyboard G. Skill Mechanical
Software Windows 10 (X64)
I agree, it sounds like the bios chip is shot, if you've tried all of the suggestions in this thread and it still doesn't work properly. Since it's a 4 year old board you might just be best off replacing it. My first thought would be a possible bad flash too, but if you've used it for 3.5 years since the last flash that can't be it.
12,340 (2.21/day)
Oregon
Its the same message you get when you use a generic BIOS to save a board. Buy a new BIOS and Hotflash it
paulmars
6 (0.00/day)
"Did you change battery or you not listening?"
not yet since that one time 3.5 years ago.
paulmars
6 (0.00/day)
something else:
when I hit F1 and make any changes and save and exit, it looses the changes and hangs up on the bad checksum screen again. Also, if i hit f1 and make no changes and save and exit, it does the same. HOWEVER, if I hit f1, then make no changes and discard changes and exit, it boots to windows. That is ODD!
OneMoar
There is Always Moar
8,834 (1.61/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
try these
1. inspect the battery socket for corrosion or damage make sure the contacts aren't broken or bent out of place
2. pull the battery and ac power press the power button once after removing ac power and allow it to sit overnight
3. ensure that the date and time is set in the bios
else you may need to reflash the bios or your use of the compressor damaged/shorted something
finally the voltage doesn't mean shit the battery may register 3.0V and still be crappy enough to not keep the RTC running ESPECIALLY on older systems
397 (0.08/day)
System Name potato
Processor Ryzen 9 5950X
Cooling Custom WC Loop
Memory 2x16GB G.Skill Trident Z Neo 3600
Video Card(s) RTX3090
Storage 512GB, 2TB NVMe + 2TB SATA || 32TB spinning rust
Display(s) XIAOMI Curved 34" 144Hz UWQHD
Case be quiet dark base pro 900
Audio Device(s) Edifier R1800T, Logitech G733
Power Supply Corsair HX1000
Mouse Logitech G Pro
Keyboard Logitech G913
Software win 11 amd64
try to reprogram the eeprom (flash the BIOS)
i came across few similar cases with old motherboards, some were fixed with reprogramming eeprom chip, the rest require new chip.
44,267 (6.80/day)
Perhaps if you pull the bios chip out and plug it into your wazoo itll start working right or youll realize the battery or chip is bad itself. Checksum errors come from the battery not holding the info or the chip has reached its storage limit.
4,378 (0.92/day)
St. Paul, MN
System Name Bay2- Lowerbay/ HP 3770/T3500-2+T3500-3+T3500-4/ Opti-Con/Orange/White/Grey
Processor i3 2120's/ i7 3770/ x5670's/ i5 2400/Ryzen 2700/Ryzen 2700/R7 3700x
Motherboard HP UltraSlim's/ HP mid size/ Dell T3500 workstation's/ Dell 390/B450 AorusM/B450 AorusM/B550 AorusM
Cooling All stock coolers/Grey has an H-60
Memory 2GB/ 4GB/ 12 GB 3 chan/ 4GB sammy/T-Force 16GB 3200/XPG 16GB 3000/Ballistic 3600 16GB
Video Card(s) HD2000's/ HD 2000/ 1 MSI GT710,2x MSI R7 240's/ HD4000/ Red Dragon 580/Sapphire 580/Sapphire 580
Storage ?HDD's/ 500 GB-er's/ 500 GB/2.5 Samsung 500GB HDD+WD Black 1TB/ WD Black 500GB M.2/Corsair MP600 M.2
Display(s) 1920x1080/ ViewSonic VX24568 between the rest/1080p TV-Grey
Case HP 8200 UltraSlim's/ HP 8200 mid tower/Dell T3500's/ Dell 390/SilverStone Kublai KL06/NZXT H510 W x2
Audio Device(s) Sonic Master/ onboard's/ Beeper's!
Power Supply 19.5 volt bricks/ Dell PSU/ 525W sumptin/ same/Seasonic 750 80+Gold/EVGA 500 80+/Antec 650 80+Gold
Mouse cheap GigaWire930, CMStorm Havoc + Logitech M510 wireless/iGear usb x2/MX 900 wireless kit 4 Grey
Keyboard Dynex, 2 no name, SYX and a Logitech. All full sized and USB. MX900 kit for Grey
Software Mint 18 Sylvia/ Opti-Con Mint KDE/ T3500's on Kubuntu/HP 3770 is Win 10/Win 10 Pro/Win 10 Pro/Win10
Benchmark Scores World Community Grid is my benchmark!!
ha,ha he said "wazoo!!" huhuh...;)
Solaris17
Super Dainty Moderator
27,590 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Video Card(s) MSI SUPRIM Liquid 5090
VR HMD Quest 3
95Viper
Super Moderator
13,301 (2.20/day)
What cards do you have plugged in the motherboard?
Unplug them and try booting.
Does the CMOS save the correct time and date, when you change it?
Look for the CLR CMOS pins and make sure the jumper is in the correct position; if there is no jumper,,, make sure that there is not supposed to be one.
If there is suppose to be one it may have been dislodged or blown off during the cleaning.
Check the MB and see if any caps look bulged or leaking.
Yep, Try a BIOS flashing, like was stated in a previous post.
I am of the feeling that the writable portion (CMOS) of that chip is given up the ghost.
Hopefully you have a chip that is replaceable (plug/unplug). You should be able to find on online...
paulmars
6 (0.00/day)
try these
1 already done. making good contact.
2 done
3 time was 00:01;03, year 2010
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
Have you tried reflashing the bios
