GPU Fan Spins Up and Down when Idle
13 (0.00/day)
System Name Custom
Processor Intel Xeon E3-1230 v3
Motherboard MSI B85M-E45
Cooling Stock
Memory ADATA DDR3 1333MHz 4Gb x 2
Video Card(s) ASUS GTX 750 OC 1Gb
Storage Seagate 2Tb
Display(s) BenQ EW2440
Case Xigmatek Mini Tower
Audio Device(s) None
Power Supply Antec NeoECO 520C
Mouse Steelseries Kinzu V3
Keyboard Cherry G80-3800
I have an ASUS GTX 750 OC 1Gb video card, BIOS version 82.07.32.00.31.
The GPU fan spins up and down approximately every 10 seconds even when the video card is completely idle. In GPU-Z, the Fan Speed (RPM) reading goes from 0 to 3000 RPM every 10 seconds even when the Fan Speed (%) is constant at 22%. When the RPM reading is over 3000 RPM, the GPU fan becomes extremely loud.
If I boot to the BIOS instead of Windows, the GPU Fan does not spin up and down periodically.
This same problem exists in both Windows 7 Ultimate and Windows 10 Pro.
Nvidia driver version is 361.43.
Please help and let me know what I need to do to stop the fan from spinning up and down when the video card is idle.
Mussels
Freshwater Moderator
58,412 (7.77/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
whys it showing as 1050MHz? thats not idle
rtwjunkie
PC Gaming Enthusiast
14,034 (2.29/day)
Louisiana
Processor Core i9-9900k
It looks to me as if 30celcius is the diving line for your fan to kick on and off, since J see the fan spimes, and also 30C strsight through.
Have you considered a fan profile, using say, Afterburner, or Precision? It's worth trying a 6 to 8 point fan profile and see if it fixes it.
18,584 (2.63/day)
System Name AlderLake
Do you have a browser open?
13 (0.00/day)
System Name Custom
Cooling Stock
Storage Seagate 2Tb
13 (0.00/day)
System Name Custom
Cooling Stock
Storage Seagate 2Tb
Tried both MSI Afterburner and Asus GPU Tweak 2. Defined a custom fan curve but for some reason the video card spins up and down the fan and ignores settings in the fan curve.
Mussels
58,412 (7.77/day)
Oystralia
This is a factory overclocked version of the GTX 750 video card.
at idle shouldnt it drop below those clocks? could be causing more heat, and therefore the fan spinups.
13 (0.00/day)
System Name Custom
Cooling Stock
Storage Seagate 2Tb
13 (0.00/day)
System Name Custom
Cooling Stock
Storage Seagate 2Tb
The strange thing is when I am playing a game eg Far Cry 4, the GPU fan stops spinning up and down.
Normally I don't mind the GPU fan spins but it's quite annoying to hear the loud fan noise every 10 seconds.
1,079 (0.22/day)
Indonesia
Processor AMD Ryzen 9 7900
Motherboard Gigabyte B650M AORUS PRO AX
Cooling THERMALRIGHT Phantom Spirit 120 EVO
Memory G.SKILL Flare X5 DDR5-6000 64GB (2x32GB)
Video Card(s) Manli RTX 5070 Ti NEBULA
Storage 2 TB WD Black SN850X | 2 TB WD Blue SN570 | 10 TB WD Purple Pro
Display(s) Xiaomi G27Qi 27" 2K QHD IPS 180Hz
Case Fractal Design Define R5 Black
Power Supply SEASONIC FOCUS PLATINUM PX-850 850W
Mouse Fantech Helios II Pro S
Keyboard KIRA EXS
Try to force a constant RPM via Afterburner, try 40% or 50%. Does the fan still revving up and down?
13 (0.00/day)
System Name Custom
Cooling Stock
Storage Seagate 2Tb
Yes it does.
1,079 (0.22/day)
Indonesia
Keyboard KIRA EXS
Yes it does.
Hmm.. that's strange.
Try to increase the speed bit by bit starting from 50% until it reach 100% fan speed. Maybe using 10% increment.
Does it still revving up and down? If not, at what speed does the fan stop revving up and down?
1,013 (0.14/day)
Processor 2500K @ 4.5GHz 1.28V
Motherboard ASUS P8P67 Deluxe
Cooling Corsair A70
Memory 8GB (2x4GB) Corsair Vengeance 1600 9-9-9-24 1T
Video Card(s) eVGA GTX 470
Storage Crucial m4 128GB + Seagate RAID 1 (1TB x 2)
Display(s) Dell 22" 1680x1050 nothing special
Case Antec 300
Power Supply PC Power & Cooling 750W
Software Windows 7 64bit Pro
Since it doesn't do it in BIOS and you said forcing constant fan % still has spin ups and downs... can you try completely removing the drivers and reinstalling them? For completeness, try a fresh install of windows on the system. I saw you mentioned it does it in both Win 7 and 10 but I'm not sure how Win 10 was installed (if you updated the Win 7 install to 10 or did a fresh install).
The strange part to me is that the fan % is not shown as increasing and decreasing yet the fan RPMs report exactly what you are saying is happening.
13 (0.00/day)
System Name Custom
Cooling Stock
Storage Seagate 2Tb
Windows 10 Pro was installed fresh. Also tried using DDU in Windows 7 to completely reinstall the NVIDIA driver. The problem still exists.
13 (0.00/day)
System Name Custom
Cooling Stock
Storage Seagate 2Tb
It does for fan speed below 70%. If I set the fan speed to 70% (manual control), the GPU fan does not spin up and down.
4,543 (0.80/day)
Denmark
System Name The work PC /2700x/5950x
Processor 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V
Motherboard Gigabyte AORUS Master X570/2xMSI X470 M7 AC
Cooling Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE
Memory 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400
Video Card(s) 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI
Storage 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Lian test bench/NZXT 500
Power Supply AX 850 Titanium/AX 860i/AX 760
Software Dual boot/Win 10 / Linux / Win 10+Linux
Does it ever change temperature? Your first GPU-Z shows a constant 30 C. The sensor could be broken.
13 (0.00/day)
System Name Custom
Cooling Stock
Storage Seagate 2Tb
Yes the temperature does change in GPU-Z.
8,570 (1.81/day)
Ovronnaz, Wallis, Switzerland
System Name main/SFFHTPCARGH!(tm)/Xiaomi Mi TV Stick/Samsung Galaxy S25/Ally
Processor Ryzen 7 5800X3D/i7-3770/S905X/Snapdragon 8 Elite/Ryzen Z1 Extreme
Memory 64gb DDR4 3600/8gb DDR3 1600/2gbLPDDR3/12gbLPDDR5x/16gb(10 sys)LPDDR5 6400
Video Card(s) Hellhound Spectral White RX 7900 XTX 24gb/GT 730/Mali 450MP5/Adreno 830/Radeon 780M 6gb LPDDR5
Storage 250gb870EVO/500gb860EVO/2tbSandisk/NVMe2tb+1tb/4tbextreme V2/1TB Arion/500gb/8gb/512gb/4tb SN850X
Display(s) X58222 32" 2880x1620/32"FHDTV/273E3LHSB 27" 1920x1080/6.67"/LTPO AMOLED panel FHD+120hz/7" FHD 120hz
Audio Device(s) Logi Z333/SB Audigy RX/HDMI/HDMI/Dolby Atmos/CVJ NightElf/Moondrop Chu II+BT20S/Nekocake GfL QBZ-191
VR HMD Medion Erazer
btw... 1050mhz indicate a load not that it's a factory OC ... i.e: my 980 off load is at 639mhz idle and it's clocked 1279mhz off boost and goes round 1415+ on boost ... you have something running that use the GPU probably, oh and try to edit your post rather than double post
so yes normally
it would do that
1,079 (0.22/day)
Indonesia
Keyboard KIRA EXS
It could be power delivery from PCI-E slot that causing this, have you tried forcing the PCI-E to always run at performance mode?
NVIDIA Control Panel > Manage 3D Settings > Global Settings > Power Management Mode > Prefer Maximum Performance
8,570 (1.81/day)
oh... and can you list your system specs just in case (and fill your sys specs also in your user control panel at the same time )
also non idle :
can't shot a idle now but even the vRAM lower speed on idle, your's show it does not.
13 (0.00/day)
System Name Custom
Cooling Stock
Storage Seagate 2Tb
Already set... same problem though.
13 (0.00/day)
System Name Custom
Cooling Stock
Storage Seagate 2Tb
also non idle :
This is taken from Windows 10 Pro:
8,570 (1.81/day)
now that's idle, altho don't double post: there is an edit function on the bottom left of your post, thanks.
you might want to consider a RMA if the card is still under warranty and nothing else do.
2,695 (0.41/day)
System Name panda
Processor 6700k
Motherboard sabertooth s
Cooling raystorm block<black ice stealth 240 rad<ek dcc 18w 140 xres
Memory 32gb ripjaw v
Video Card(s) 290x gamer<ntzx g10<antec 920
Storage 950 pro 250gb boot 850 evo pr0n
Display(s) QX2710LED@110hz lg 27ud68p
Case 540 Air
Audio Device(s) nope
Power Supply 750w superflower
Mouse g502
Keyboard shine 3 with grey, black and red caps
Software win 10
Benchmark Scores http://hwbot.org/user/marsey99/
go speak to asus, might need a better bios.
95Viper
Super Moderator
13,313 (2.20/day)
^This^
Try the card in another system for a while to test... if you have no way of doing this then try running it under a Linux version (this will eliminate windows as a problem).
See if your fan on the card spins easily while off. Make sure it is not binding in any way.
Also, this post in this thread may be of interest: FANS going nuts (GAINWARD GTX 770 Phantom 4GB) - SOLVED
Quote from the post:
Okay - I think the case is solved - just got an email from GAINWARD Support:
This sounds you have a card with a defective chipset fan control.
The fans are controlled from the chipset after the driver installation because the 770 card has GPU Boost 2.0.
A defective chipset fan control is not repairable.
You will get an exchange card.
Please contact your reseller Komplett to start the rma procedure.
Thanks all fo trying to help :)
Your card, too, seems to have GPU Boost 2.0 according to the ASUS site.
