ShadowFlare
- Sep 20, 2005
- 542 (0.07/day)
Processor | Athlon 64 Venice 3200+ 2.0 GHz, max 2.6 GHz with Zalman CNPS7000B-AlCu |
Motherboard | EpoX 9NPA+Ultra nForce4 Ultra with Zalman ZM-NB47J |
Cooling | All Zalman heatsinks (CNPS7000B-AlCu, ZM-NB47J, VF700-Cu) |
Memory | 1 GB (2x512 MB) DDR400 Corsair XMS C2 series, max 233 MHz @ 2-3-2-9 1T |
Video Card(s) | Sapphire Radeon X800GTO2 256 MB PCIe max 540/600, modded to 16 pipes |
Storage | Seagate 80GB SATA, Maxtor 160GB PATA, Maxtor 200GB PATA |
Display(s) | Dell 17" Trinitron CRT |
Case | Lian Li PC-60B Plus |
Audio Device(s) | Built-in Realtek chip |
Power Supply | Enermax Noisetaker EG495AX-VE, 485 watts, active PFC |
Software | Windows XP Pro SP2, Windows XP Pro x64, Windows Vista RC1 32-bit |
I have no clue. BTW, what do you want to use the X850 XT PE bios for? The only thing that is different from what you can do without it is that ATI Overdrive is available. If you are already using the X850 XT PE bios, just save the default memory timings to a profile, then flash back to your GTO2 bios and use the X850 XT PE clocks and memory timings in ATITool.Alien666 said:Hi,
I want to ask how can I mod the X850XTPE BIOS to controll Sapphire GTO2's Fan: Which rows are for this.Thank you!
BTW, on my X800 GTO2 the only memory timing settings in ATITool that are different are these:
MEM_TRP - default is 6, XT PE uses 5
MEM_REFRESH_RATE - default is 0x3B, XT PE uses 0x1E
Those account for the 15 or 20 point difference in 3dmark 2005 scores when using the X850 XT PE bios.
