- May 2, 2017
- 7,762 (2.59/day)
- Back in Norway
System Name | Hotbox |
Processor | AMD Ryzen 7 5800X, 110/95/110, PBO +150Mhz, CO -7,-7,-20(x6), |
Motherboard | ASRock Phantom Gaming B550 ITX/ax |
Cooling | LOBO + Laing DDC 1T Plus PWM + Corsair XR5 280mm + 2x Arctic P14 |
Memory | 32GB G.Skill FlareX 3200c14 @3800c15 |
Video Card(s) | PowerColor Radeon 6900XT Liquid Devil Ultimate, UC@2250MHz max @~200W |
Storage | 2TB Adata SX8200 Pro |
Display(s) | Dell U2711 main, AOC 24P2C secondary |
Case | SSUPD Meshlicious |
Audio Device(s) | Optoma Nuforce μDAC 3 |
Power Supply | Corsair SF750 Platinum |
Mouse | Logitech G603 |
Keyboard | Keychron K3/Cooler Master MasterKeys Pro M w/DSA profile caps |
Software | Windows 10 Pro |
It's sounds like they tested the GPU with their old motherboard and CPU though? If that's the case, I would cross it off the list of potential issues.Cannot speak for others but I am not speculating it "IS" anything!
I am simply trying to isolate the problem to a single component instead of your apparent attempt to essentially tossing in a whole new computer into your case! You want to replace both the motherboard (which alone constitutes a new computer when it comes to software licensing) and a new CPU - both because you don't know what is bad.
But hey! Its your money. Good luck.
Still, OP, some questions: are your parts still under warranty? Do you have the money to pay (even temporarily) for replacements for testing? For one component, or both? If I were you and had the money, I'd order replacements for both, test each combination, and then return the unnecessary part. Then, if the faulty part is still under warranty, RMA it, and choose whether you want to sell it after your RMA goes through or return the new one right away and use your RMA unit.
