- Jul 25, 2006
- 14,311 (2.06/day)
- Nebraska, USA
System Name | Brightworks Systems BWS-6 E-IV |
Processor | Intel Core i5-6600 @ 3.9GHz |
Motherboard | Gigabyte GA-Z170-HD3 Rev 1.0 |
Cooling | Quality Fractal Design Define R4 case, 2 x FD 140mm fans, CM Hyper 212 EVO HSF |
Memory | 32GB (4 x 8GB) DDR4 3000 Corsair Vengeance |
Video Card(s) | EVGA GEForce GTX 1050Ti 4Gb GDDR5 |
Storage | Samsung 850 Pro 256GB SSD, Samsung 860 Evo 500GB SSD |
Display(s) | Samsung S24E650BW LED x 2 |
Case | Fractal Design Define R4 |
Power Supply | EVGA Supernova 550W G2 Gold |
Mouse | Logitech M190 |
Keyboard | Microsoft Wireless Comfort 5050 |
Software | W10 Pro 64-bit |
We are going around in circles. It is not about the merits of your concerns. It is that you don't want to, or can't (because you don't own the place) accept any of the suggestions given. And that is due, in part, because you don't want to accept that this is no more than an annoyance.Anyhow, it feels like we keep going around in circles here. I figured someone might have something to suggest, but if it's just going to be me trying to argue the merits of my concern, maybe this thread is done.
Your printer is NOT faulty. So there is nothing to fix there. You checked your outlets and they are all wired correctly. You don't own the place so you cannot add more circuits.
I realize your UPS are not switching over to battery. But they apparently are detecting the anomaly (likely a low voltage event or sag), but its duration is too quick to flip to battery. But they are still alarming. Perhaps you can silence their alarms. I can via the software menus, or UPS front panel displays. Or temporarily connect a computer and change the sensitivity.
If you don't want to do any of that - then yes, we are back full circle and it is time for you to move to a new place.
