- Oct 2, 2021
- 24 (0.02/day)
Processor | AMD Ryzen 7 3700x |
Motherboard | ASUS TUF Gaming X570-Plus |
Cooling | Cooler Master Hyper 212 |
Memory | Crucial Ballistix 3600Mhz CL16 |
Video Card(s) | Radeon 6700xt |
Storage | Sabrent SSD 512GB Rocket NVMe |
Display(s) | SAMSUNG C24F390 |
Case | Cooler Master MasterBox TD500 Mesh |
Audio Device(s) | Razer Kraken |
Power Supply | MSI MPG 650W gold plus |
Mouse | G502 Hero |
Keyboard | Logitech G413 |
Good evening,
I'm looking for a feedback/help about performances of my R7 3700x.
This issue showed up during a benchmark in game (Shadow of the tomb raider) with lowest settings to test the performance of the CPU.
As you can see from the screen, average fps are 138 and i saw much higher results for users with the 5600x, which should be pretty similar in performance (in this game more cores should led to more performance, so my 3700x should have much more FPS in average, at least in theory).
In the right-bottom corner of the screen you can see the first table column which has subpar results, meanwhile the other 2 columns have regular results.
I did benchmark with the speed test tool of PC UserBenchmark and no issue showed up. So i'm a bit confused
My specs are in my user description, but i can tell you fast:
- My GPU is 6700xt FE
- RAMs are in dual channel 3600Mhz
- Docp is enabled
- Apparently CPU isnt throttling (temperatures are around 50-60° during the benchmark and in game)
- CPU is pretty new, bought in later august this year
- during the benchmark I used only OCCT to check the temperatures, no others software.
- base CPU clock is 3.6GHz like should be
Thanks you for your time and help if you want to give some advices or suggestions! Have a nice day
- Docp is enabled
