[Case Gallery] Max Air Cooling!
supageek
13 (0.00/day)
Processor Intel Core 2 Quad@3.3ghz
Motherboard Asus P5K Deluxe Wifi-AP
Cooling Tuniq Tower 120 / OCZ XTC
Memory G.Skill DDR2 4gb @ 1086mhz
Video Card(s) Gigabyte Radeon 2900XT
Storage Seagate 320gbx2 / Samsung 250gbx2 in RAID0
Display(s) 24inch as primary 17inch as secondary
Case Lian Li PC7B-PLUS
Audio Device(s) Creative SB X-Fi XtremeMusic
Power Supply Enermax Galaxy EGX1000 DXX
Software Windows Vista Ultimate 64
Specs:
Intel Core 2 Quad Q6600@3.3ghz
ASUS P5K Deluxe WiFi-AP
Seagate 2x320gb / Samsung 2x250gb in RAID0
Pioneer DVD Multi
Creative SB X-Fi/5.1 Britz Speakers w 12in subwoofer
Enermax Galaxy EGX1000w DXX PSU
Lian Li PC7B-Plus 3x120mm fans
Tuniq Tower 2x120 fans
OCZ XTC Ram Cooler
Vlsys L.I.S2 Premium front panel display
Zalman 6 channel fan controller
1 blue neon
Mods:
This case was modded at a modding shop as I dont have the time nor the equipment to mod my self. I got a fan hole at the top of the case for a 120mm fan but had to remove the fan because of my PSU. Thats all. The only thing I did mod myself is the Tuniq, painted the fan cover and attached a chrome 120mm fan to the side using wires to hold it in place. Thats about it. Im still a noob at modding:).
There are some pictures of some of the components I used. There is a Hiper psu 580w, ATI 2900xt, Foxconn 8800gts 320mb and the 640mb oc version, enermax galaxy 1000w. The pictures are with a mix of these components installed.
JC316
Knows what makes you tick
9,397 (1.41/day)
System Name Budget Gaming
Processor AMD FX6300
Motherboard Gigabyte 880GMA-USB3
Cooling Coolermaster Hyper 212+
Memory 8GB Ripjaws DDR3 1600
Video Card(s) HD7850 1GB
Storage 1TB Sata2
Display(s) Acer 24" LED
Case Generic black
Audio Device(s) Stock onboard
Power Supply FSP Aurum Gold 650W
Software Windows 7 Home Premium 64bit
Nice system! I would get a better power supply though, that Hiper 580 isn't a whole lot for a 2900XT. 8/10
newtekie1
Semi-Retired Folder
28,472 (4.23/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
He has the Galaxy 1000w.
234 (0.04/day)
Brasil - São Paulo - São Caetano do Sul
System Name NOS
Processor Core Extreme QX6850
Motherboard Maximus Formula
Cooling VANTEC STING RAY CPU Block, 3x120mm fan's with Radiator, Seltz 1200lt/h
Memory 4GB Crucial Ballistix 1066MHz 5-5-5-15
Video Card(s) PCI-express ATI Radeon HD2900XT 1GB DDR4 512bits
Storage 5 HD's 160GB SATAII Seagate ST3860815AS 7200.10
Display(s) LG 22'' model 22LS4R
Case 3Rsystem's R810 with mod's for watercooler system
Audio Device(s) Supreme FX II
Power Supply ULTRA X3 1000W modular PSU
Software WINXP PRO SP3 x86
8/10
Man u go to a shopping and ask for them to built a custom system right? why u dont tried to make u the modding the best thing is build a customized case planning and create
and u can put a snap of the internal with the lights on because the blue leds dosent see nothing inside
see and vote in my case http://www.techpowerup.com/gallery/1034.html
bye ;)
intel igent
4,640 (0.67/day)
Toronto, Canada
System Name old school / new school
Processor 3.0e C0 @ 3.6 / e5200
Motherboard p4p800e-dlx / p5q-DLX
Cooling custom water see sig / air
Memory 2x1g oczPC4000EbPl / 2x2g ocz2rpr1066
Video Card(s) 3850AGP / 4890vaporX
Storage 36g raptor+120g wd / wd 1001fals 1tb
Display(s) BenQ / sharpAQUOS LC-37D64U
Case modded antec plusview / generic
Audio Device(s) audigy 2zs / ASUS Xonar HDAV1.3
Power Supply fan/cable modded powerstream 520 / OCZ 700mxsp
Software Xp pro SP2 / VISTA ultimate OEM
nice rig.
whats the model # on that zalman fan controller thnx
387 (0.06/day)
Los Angeles, CA
Processor Intel i7 4790K
Motherboard ASRock z97 Extreme
Cooling NZST Kraken
Memory 16gb
Video Card(s) 2x EVGA GTX 1080 FTW2
Storage Samsung 950 EVO
Display(s) 28'' Samsung
Case NZXT H700i
Power Supply EVGA 850G2
how much of this computer was built by the shop and how much was built by you?
Did you put computer together with all those components already?
Or was it premade/premodded at the shop?
supageek
13 (0.00/day)
Intel Agent, its a Zalman ZM-MFC1 PLUS.
The only thing I had done at the modding shop was the fan hole on top of the case, and had my side cover cut. I did not get the system prebuilt, I built it myself.
302 (0.05/day)
Israel
System Name ¯\_(ツ)_/¯
Motherboard MSI MEG X670E Ace
Cooling EK Nucleus CR360
Memory 64GB DDR5 Corsair Dominator Titanium 6000Mhz CL30 1.4v
Video Card(s) Asus RTX 4090 ROG Strix OC
Storage Samsung 990 Pro 2TB \ Kingston KC3000 2TB
Display(s) LG GQ950-B 4K 144hz 32"
Case Lian Li Lancool 216
Audio Device(s) Focusrite Scarlett 2i4 Gen2 \ SS Arctis Nova Pro \ DT 770 Pro
Power Supply MSI A1000G 1000W ATX 3.0
Mouse HyperX Pulsefire Haste 2
Keyboard NuPhy Filed75
Nice PSU pick, I had one few days ago changed it for PC Power & Cooling Turbo-Cool 1KW-SR EPS12V 1000W, payed 120$ more for it. U wont be sorry GALAXY rules.
intel igent
4,640 (0.67/day)
Toronto, Canada
2,753 (0.44/day)
louisiana
Processor Intel Core i7-4790 Haswell Quad-Core 3.6GHz LGA 1150 84W
Motherboard GIGABYTE GA-H87-D3H LGA 1150 Intel H87 HDMI
Cooling CPU - Cooler Master Hyper T4 / Case - cooler master 120mm rear case fan (Air cooling)
Memory 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Video Card(s) GTX1060 6GB
Storage Samsung 512 GB 840 PRO SSD Main Drive and Samsung 512 GB 840 EVO SSD Backup Drive
Display(s) ASUS 23" LED Monitor
Case COOLER MASTER Centurion 5 (silver & black)
Audio Device(s) (onboard audio) Realtek ALC892
Power Supply CORSAIR SU-750TX 750W ATX12V / EPS12V
Software Windows 10 Home Premium 64bit Edition
unless you specified exactly where to put the hole i would insist they replace the case they screwed up and reinstall the fan where it belongs, halfway between the psu and the disk drive. any simpleton could check the standard demensions online for a psu and a disk drive to center the fan for proper clearance. that so called mod shop owes you a case.
supageek
13 (0.00/day)
I cant take it back, its been a while since I got this case modded and I asked them to put it there. :) I use to have an Enermax Infinity back when I fist got the case modded and had no problem with the PSU getting in the way. The galaxy is a very large and heavy PSU, bigger then the tagan's. I appreciate your concern Keakar, but it was my fault for not knowing that PSU's came so big. Thanks for the reply all.
T
ThermalTake-FTW!
o_O
Can you tell me why you got such good parts like cpu etc, then bought a cheap foxconn 8800? everything else superb 9/10
supageek
13 (0.00/day)
Well I payed good money for these cards, I got the 8800gts 320mb at the beginning of the year for about $340, and payed $440 for the 640mb onoc. I now have the ATI 2900xt and sold one 8800gts. The other one is in my other rig which is used just for surfing the web and downloading stuff. I couldnt justify going out and getting an 8800ultra because I can buy 2 cards for that money, besides I wanted to try all three cards out myself to see what kind of performance I'd see between the three. Thanks for the vote.
