Mouse Stuttering while under medium - heavy loads. (Not really heavy at all).
31 (0.02/day)
Canada
System Name Aurora V2
Processor Intel I7-10700k
Motherboard MSI Z490 Gaming Carbon Wifi
Cooling Custom Looped
Memory 32GB HyperX Fury @ 3000Mhz
Video Card(s) Gigabyte 3080 Vision OC
Storage Mish Mash of Storage Drives
Case InWin 303
Power Supply EVGA Supernova 750G
Hey there,
Over the past few months, I have been having an odd issue with my PC. It is specifically with the mouse. During random times, my mouse will begin to stutter. It almost looks like it's teleporting rather than gliding, making it hard to control. This has only been occurring recently, and I assumed it was an issue with my wireless mouse at the time. I assumed my mouse may have been on, or close to the same wireless 2.4G channel as my modem, so I bought a new mouse that utilizes Bluetooth built into my motherboard. After buying this new mouse, the issue still persists, eliminating it out of the equation entirely. This stuttering can happen with something as simple as Netflix running while scrolling Facebook, or Gmail, but it also happens when I am working. By career I am a programmer, and on any given day I can have around 20+ chrome tabs open, VSCode, Netbeans, Putty, FileZilla and so on. 98% during this time under this load, the stuttering does not happen. It seems to come out at random. Sometimes while working, sometimes while just browsing chrome. Sometime I'll go a week or so before it starts stuttering again. It only seems to last in short bursts, no longer than about 5 minutes long before it goes back to normal. My specs are not low-end by any means, as I need to have a pretty beefy computer in order to maintain top efficiency while developing. No wasting time waiting for stuff to load/compile.
Processor: Intel I7-10700K
Motherboard: MSI Z490 MPG Gaming Carbon Wifi
Ram: 32GB HyperX Fury @ 3000MHz
SSD: 2X Samsung 860 Evo 1TB
HDD: 1X Seagate Barracuda 1TB
GPU: Gigabyte 3080 Vision OC
Cooling: All of the cooling is Custom-Looped. Processor rarely climbs above 40C, GPU 50-60C.
I have the latest BIOS, Latest drivers from all the manufacture's websites. Latest Nvidia Drivers. Latest Windows Updates,
Oh, and I forgot to mention, I have wiped windows a month ago or so, issue still persisted across a fresh install.
I am out of ideas as to what is causing this. All I can think is perhaps overclocking? I do have Intel Turbo-Boost enabled. Base Speed is 3.79GHz, but the processor usually runs at about 4.6GHz while still keeping cool.
My processor can be sitting at 3% utilization, GPU 4% Utilization, Memory 32% Utilization, and yet the mouse will periodically and randomly stutter. Heck, it's even stuttering right now as I type this to move my cursor to make edits, and I only have 1 chrome tab open, this page.
Does anybody have the brightest idea as to what is going on here?
Could it be how my tubing is laid out?
Picture:
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
What mouse and how close is the wifi/Bluetooth antenna to the mouse?
9,923 (1.80/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
yeah what mouse? have you tried another usb ports, trying usb 2.0 not usb 3.0
have you checked any usb setting in your bios just incase you miss something?
31 (0.02/day)
Canada
Case InWin 303
First Mouse was a Logitech G305. The Wifi dongle had an extender, so I'd literally have it on my desk not 10CM from where I was moving my mouse. The second one I just bought is a Corsair Harpoon RGB. I am purposely using Bluetooth to try to eliminate my 2.4G modem out of the problem. Still no change.
9,923 (1.80/day)
Jakarta, Indonesia
Case Icute Super 18
what about usb setting on bios?
31 (0.02/day)
Canada
Case InWin 303
Technically as of now, I am not using USB for this new mouse. My motherboard has Bluetooth Built in, so I opted to use that instead to eliminate USB out of the problem as well. Same issues on Bluetooth as well. Perhaps it could be my graphics lagging, making it look like it's my mouse? I played a game once to see if this was the issue, but the game itself didn't lag (150 FPS ish), only the mouse movement did.
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
Are you using the Bluetooth/wifi antenna for the motherboard? In my experience, bt can be wonky if you have something like a router close.
31 (0.02/day)
Canada
Case InWin 303
Yeah, the motherboard came with 2 long antennas, They are spread so 1 faces left, 1 faces right, pointed upwards. My modem is probably about 2 feet away.
Deleted member 202104
Just try turning the router/modem off and see if the problem stops.
31 (0.02/day)
Canada
Case InWin 303
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Just on my own systems this year i've seen similar for a bunch of unrelated causes:
1. Had to move USB receiver for mouse a lot closer
2. Disabled a setting on my TV causing network spam to make games stutter
3. Mechanical disk drives powering up/down (mine had a faulty power cable)
4. probably something i forgot (Oh some mice have issues with polling at 1000Hz in 11)
44,269 (6.80/day)
Cooling Scythe Ashura, 2Ă—BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED
Hey there,
SSD: 3X Samsung 860 Evo 1TB
Picture:
And no power supply specs...
163 (0.13/day)
Processor 6900K @ 4.3Ghz
Motherboard Gigabyte x99 ultra gaming
Cooling H115i pro xt
Memory Tridentz 3200 32gb
Video Card(s) Galax RTX 4070
Storage 970 EVO 500gb
Display(s) AOC g2460pf
Case Non branded shit
Power Supply Corsair Rm550x
Mouse Logitech G603 Double click mode
Keyboard TGK205
Software Win 10
I think that would be a problem, when my psu start to fail, the mouse and some programs start to stutter or freezing. After pch and dram cotroller voltage drop, it only back to normal when system restarts.
Open hwmonitor and leave it behind while you use the pc, if the problems pop out, check the min and max voltages of the whole pc
31 (0.02/day)
Canada
Case InWin 303
I am currently using an EVGA Supernova 750G. I will leave hwmonitor running today and report back.
44,269 (6.80/day)
Get a pic of the label from the psu please (that has the specs)
2,622 (0.53/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Memory 64 GB G.Skill RipJaws V F4-3200C16D-64GVK
Case Corsair 275R
Mouse Logitech G Pro (Hero)
IMX, with 10, Windows is known to have "keep lagging until I reboot" syndrome, clearly a software problem in my case and probably most cases.
If it was an SSD failing, it will feel more like an HDD from 2005 and/or you get new Windows errors in the event log relating to file corruption.
9,800 (3.23/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Mine stutters if it's too far away from the PC or if there is stuff in between it and the mouse.
31 (0.02/day)
Canada
Case InWin 303
Okay. After running HWMonitor, the numbers are interesting. I opened up a game, played it for a while.
Gaming:
+12V:
- Min: 11.56V
- Most of the time: 11.65V
- Max: 11.7V
+3.3V:
- Min: 3.23V
- Most of the time: 3.25V
- Max: 3.32V
Working:
+12V:
- Min: 12.230V
- Most of the time: 12.240V
- Max: 12.250V
+3.3V:
- Min: 3.324V
- Most of the time: 3.325V
- Max: 3.325V
When I closed my game, and opened up my workspace I use for work, my voltages changed.
My +12V increased to 12.240V and my +3.3V went to 3.324V. This is when my mouse started lagging and stuttering.
Here is a picture of the PSU:
It it was an SSD failing, it will feel more like an HDD from 2005 and/or you get new Windows errors in the event log relating to file corruption.
Here is what my drives are looking like:
  • HWMonitor.txt
6 (0.00/day)
Hi Bryce,
About a couple of months ago, I'm experiencing the same behaviour. I have a Logitech G Pro and using the wireless dongle at no more than 10 cms from it. One thing I have tried is that if I switch the mouse to wired mode by plugging in the usb cable when stuttering is happening, it goes away. The stuttering is totally random, there are days which I don't experience the issue at all. When it comes it's usually a 3-4 minutes then goes away.
I have an AMD setup, 5800x and Asus Rog B550-F Wifi. My PSU is almost new (CM V850 Gold v2). What we have in common is the graphic card brand and our motherboards are Wifi, so I'm thinking it could be related with the Wifi antena, I have it plugged in but I'm not using it. I will try unplugging it. Other things I may think of are Windows Updates or any specific software running in the background. I have experienced this mouse stuttering mostly when navigating or at desktop, so the CPU load is very low. I don't think this is related to load.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
i have had 7 or so G502's over the past however long, & the most recent one i bought, i accidentally bought the wireless version. i figured it wasnt a big deal, since ive heard great things about logitech wireless , but i found it laggy & glitchy. ive never had issues with the wired versions, & once i switched off the wireless & plugged in the wire, it worked just as smooth as the past G502's ive had. since i have never used it in wireless mode, which is a pita, since i paid an extra 30% or so for the wireless tech.
disabling windows mouse 'accuracy' or whatever it is never a bad idea ime
hopefully that might help
Mussels
58,412 (7.78/day)
Oystralia
"so I bought a new mouse that utilizes Bluetooth built into my motherboard"
Oh shit how did i miss that
BLUETOOTH IS SHIT FOR MICE. JUST DONT. DONT.
Use the proper USB receiever, or use it wired.
BT is only really good for devices that dont have a choice, like smart TV's, phones and tablets.
31 (0.02/day)
Canada
Case InWin 303
So, update:
I don't believe it's just my mouse that's stuttering. It's difficult to tell, I think it almost acts like an illusion. I don't think my mouse is stuttering, but rather my whole pc, but I only notice it when I am moving my mouse? Does this make sense or am I just losing it over here :rockout:
6 (0.00/day)
So, update:
I'm experiencing the same and I don't think is the whole PC that is stuttering, it's just the mouse cursor. Have you tried to plug it in when the stuttering ocurrs? at least when I plug it in the stuttering stops. I have a Logitech mouse, I believe you have other brand.
Mussels
58,412 (7.78/day)
Oystralia
So, update:
Input latency can do that
Are you guys on windows 11? there was reports of that happening with 1000Hz mice
31 (0.02/day)
Canada
Case InWin 303
Update:
So, I have replaced my old 750W power supply with a brand new EVGA 1000G. I must say, it has stopped stuttering, meaning:
You guys were right! Thank you so much for all the help!
/c
