Need Help to OC CPU ...
353 (0.06/day)
Nasik,India
System Name Thunder
Processor Intel I5 3570K
Motherboard Asus P8Z77-V Pro
Cooling Thermalright Archon
Memory Gskill Ripjaws X 2*8Gb 1600MHz
Video Card(s) Sapphire HD7950 Vepor X
Storage Seagate 500Gb + WD 3Tb
Display(s) Samsung SyncMaster S22B370
Case Cooler Master HAF 912 Adv.
Power Supply Corsair TX650M
Software Windows 7 64Bit
Hi friends I need ur help to OC my CPU . I have Intel E4500 + Biostar TP I45 mobo (BIOS of this mobo is totally different from others).Transcend DDR2 2Gb 800MHz RAM.
CPUz Screen shot :-
I am really noob about OCing.
Bios settings (All value Default) :-
In Advanced Tab -
CPU Configuration:-
C1E Support - Enable
Hardware prefetcher - Enable
Adjacet Cache Line Prefetch - Enable
Max CPUID Value Limit - Diable
CPU TM Function - Enable
Execute Disable-Bit Capability - Enable
Core-Multi Processing - Enable
Intel(R) C-STATE Tech - Enable
In O.N.E Tab -
Overclocking Navigator -Manual
Intel Speedstep tech - Disable
Ratio CMOS setting - X11.0
CPU Freqency Setting - 200
Overclock Retry Cout - 3
FSB(Bsel) to NorthBridge Latch - Auto
FSB Compesation Finetune - Disable
DRAM Frequency - Auto
Enhance Mode - Auto
DRAM Timing Config. -
DRAM RCOMP Configuration - Auto
Static tREAD Value (PL)-Auto
Cofigure DRAM timing by SPD - Enable
Extra DRAM timing setting - Auto
Clock Gen Config -
PCIE Frequency Setting - 100
CPU clock skew control - Auto
(G) MCH Clock skew control - Auto
CPU Driving control - Auto
Voltage Config -
CPU Voltage - Auto
DDR Voltage -Auto
Chipset Voltage - Auto
FSB voltage - Auto
CPU core 1,2GTL Ref Voltage - 0.63*VTT
CPU core 2 GTL Ref Voltage - 0.67*VTT
MCH GTL Ref Voltage - Auto
CPU PLL Voltage - 1.5V
cpu voltage-1.288v
NB/SB Voltage - 1.096v
DDR Voltage - 1.8172V
FSB Voltage - 1.176v
tbh, it is dual channel ram, so 1 stick is gonna cripple you straight away.
Also go into you ram advanced settings in the BIOS and manually set the figures to 4-4-4-12, the BIOS is setting 6-6-6-15 for some crazy reasons? Have you ever tried the setting the BIOS to optimum defaults on the first page i think it is?
I reset BIOS ,all settings are at Default ...
that image is loading way too slow. please re-upload it at www.techpowerup.org
try raising your FSB from 200Mhz to 266Mhz, and watch your ram speed - make sure it doesnt go above or below 800Mhz (400Mhz in CPU-Z) - this would be the "DRAM Frequency - Auto" option.
Not crazy reason at all, the original Jedec timing for DDR2 800 was something like 6-6-6-18 :p
It has been CL6 for a long time now, just that faster ram have been released doesn't mean the bios is crazy.
actually, so that we know what timings his ram SHOULD be using, he needs to show us a screenshot of the SPD tab in CPU-Z.
telling him to set 4-4-4-12 is just stupid, if his ram cant handle it (or requires higher voltage to run it)
Here is SPD screen shot :-
The easiest way I see it is to set the FSB to 400 and lower the CPU multi to 8x.
Set the FSB:DRAM ratio at 1:2.
Make sure C1E and SpeedStep are all off before you do this.
This should be a good place to start.
Edit: Just in case, make sure you know how to reset your bios if your PC doesn't boot. :p
I know about reset Bios ...
I just need step by step instructions for OCing my CPU ...
In Advanced Tab -
CPU Configuration:-
In O.N.E Tab -
Enhance Mode - Auto
Clock Gen Config -
Voltage Config -
CPU Voltage - Auto
DDR Voltage -Auto
FSB voltage - Auto
cpu voltage-1.288v
Set Ratio CMOS setting to 8.0x
CPU Freqency Setting to 400
DRAM Frequency - makes sure it is 1:2 or something that results in 800Mhz
A conroe should be able to get to at 3.2Ghz @ that stock voltage
Doing that PC wont boot ...
In Advanced Tab -
CPU Configuration:-
In O.N.E Tab -
FSB(Bsel) to NorthBridge Latch - 1333
Enhance Mode - Auto
Clock Gen Config -
Voltage Config -
CPU Voltage - Auto
DDR Voltage -Auto
FSB voltage - Auto
cpu voltage-1.288v
Try this out:
Ratio CMOS setting - x10 bring this down to 9x if you BSOD
CPU Freqency Setting - 333
DRAM Frequency - 667 or 1:1
Enhance Mode - Auto
CPU Voltage - 1.4v
DDR Voltage -1.9v
Chipset Voltage - 1.15v or a small touch above
FSB voltage - 1.2v
C1E Support - Disable
CPU TM Function - Disable
Execute Disable-Bit Capability - Disable
With these settings you should then be able to start working on fine tuning your fsb.
Cofigure DRAM timing by SPD - Disable -Once disabled you should be able to set the following timings
5-5-5-18 tRC-25
I know they are loose right now but we are eliminating the ram out of the equation for the overclock.
CPU Voltage - 1.4v
DDR Voltage -1.9v
FSB voltage - 1.2v
I don't understand how to set this settings ??? In bracket settings are given in Auto,- 0.50v and + 0.700 vformat ...
CPU Voltage - 1.4v
DDR Voltage -1.9v
FSB voltage - 1.2v
Well for example your default CPU voltage is 1.288v, adding 0.12V will give you about 1.4v ;)
Edit:
For that I am sorry, I forgot that the conore is a 65nm chip and require more voltage than 45nm chips that we are used to. :respect:
Unless it's a percentage based like DFI's CPU Special Add. If it is do whatever results in as close to 1.4v as possible.
Ohh now i understand ...
Oh also, FSB to NB Latch set it to 1333 if you can.
Post back your results, right now I am busy wrestling with this. :p
Try this out:
Enhance Mode - Auto
CPU Voltage - 1.4v
DDR Voltage -1.9v
FSB voltage - 1.2v
5-5-5-18 tRC-25
I do settings what u suggest but get some strange problem ,after boot and before OS load i get below msg :
TRAP000030================ Exception ===============================
tr-FFF Cr0-00000 .....
... bla bla bla
like that ...
And i also not found tRC settings ...
FSB to NB Latch -1333
... bla bla bla
like that ...
Ok, BSOD. Have you tried the 9x multi? Same results?
Is it BSOD ??? I don't know bout this .No i Not tried 9x multi . Wait some time i will check and tell u ...
Edit :-
I set Multi to 9x system boot fine,OS loaded.Now i check stability using Orthos ...
Edit :-
9x multi with settings above should give you 3Ghz with 667mhz ram. Want to give us a cpuz screenshot?
also try out tpu capture utility for your screenshots. www.techpowerup.com/tpucapture
