Need help with my brother's CPU
1,745 (0.25/day)
The Nevada Wasteland
System Name 9th Level
Processor AMD Ryzen 5 5600X
Motherboard MSI X570 Carbon wifi
Cooling EK Basic 360, x2 250mm, x1 140mm, x1 120mm fans.
Memory 32GB Corsair Vengeance 3200mhz.
Video Card(s) EVGA RTX 3080 12GB FTW3
Storage 500gb ssd, 2tb ssd, 6tb HD.
Display(s) MSI 27" Curved 1440p@165hz
Case HAF 932
Power Supply Corsair HX850W
Software Windows 10 64bit
So wait....you're facepalming because me and my brother have both used free programs and been burned? HEAVEN FORBID DIFFERENT PEOPLE WITH DIFFERENT PC'S HAVE DIFFERENT EXPERIENCES. I'm not here to ask if Norton is the cause, or what you think is the best anti virus. I'm asking what I can do to check what the cause is. I'll see if he's willing to try disabling it without internet on later. I'll check GPU temps later, and I've got CPU-z ready for whatever info, if any, is useful. I'm not here to argue on what's the best option.
What are you guys afraid of? That your computer is going to get infected by just being connected to the internet? Your computer cant get a virus from ONLY being connected to the internet(your DNS server), you would have to goto a bad website.
I don't have any antivirus's installed on my computer. You wont get a virus if you only goto trusted sites. This computer(one in my specs) has never had a virus. The reality is that you will still get virus's even with an antivirus installed when you goto bad websites and its still the best option to reinstall the OS when a virus gets into a computer because you can never get it out, you may cripple it but it will likely take parts of the OS with it and make the system unstable.
Whats the power supply in you brothers comp? It might be the PSU not giving enough power or dying.
145 (0.03/day)
System Name Aurora MK III
Processor AMD Phenom II X4 925 Processor @ 2.8GHz
Motherboard MA785GMT-UD2H
Cooling Stock
Memory 2x2GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Video Card(s) Radeon HD 5770
Storage 2 500 GB, 320 GB & 160 GB HDDs
Display(s) H19W Envision 19'' @ 60 Hz 5ms
Case Case from Microcenter with a multitude of vent holes and ROM slots.
Audio Device(s) Realtek HD Audio output
Power Supply OCZ StealthXStream OCZ700SXS 700W ATX12V
Software Windows 7 Ultimate
No manufacturer listed for mine. Only NVidia. Now, how do I remove the driver? Cause it's not showing up on Add/Remove programs, even with 'updates' checked....
1,745 (0.25/day)
Case HAF 932
1,539 (0.27/day)
Canada/Québec/Montreal
System Name Main PC
Processor PII 925 x4 @3.724GHz (266x14) 1.525v NB 2660 1.425v
Motherboard Gigabyte AM3 GA-890XA-UD3 (790x+SB850)
Cooling Scythe Mugen 2 rev.B
Memory Hyperx 8GB (2x4) 1600@1418 8-7-7-20-27-1t
Video Card(s) GTX 680
Storage 256GB SSD / 2TB HDD
Display(s) LCD Samsung 24" 16:9
Case Cooler Master HAF 912
Audio Device(s) On-Board HD
Power Supply CM 750w GX |3.3v@25a|5v@25a|12v@60a
Software Kubuntu dual boot /Windows 7 Ultimate 64bit
Benchmark Scores later...
I think he got one of these 2 problems (or both) heat & lots of shits in his computer as for psu i doubt it but then again could be the psu because it's overheat for having to much dusts in it...
I clean up lots of computers & some repares & you wouldn't believe how much dusts i can get out of the PSU alone :eek:
145 (0.03/day)
Cooling Stock
Actually, it just says it'll remove em when I restart, and reinstall the new ones...so....Plus my bro wants on so...I gotta go. I'll just hope it worked. Push comes to shove, I'll do what you do, or do system recovery....
1,745 (0.25/day)
Case HAF 932
I tend to agree with your point Bro that it kills computers! Seen it happen on several of my friends' laptops that came preinstalled with Norton 360. Was'nt sure at first with the cause of hang ups and lagging till I saw that Norton eats up a lot of CPU and Memory resources in the Task manager!:eek: What I did was uninstalled Norton and installed Kaspersky IS instead! Problem fixed for my friend and laptop runs faster! :) Im just not quite sure why Norton runs that way though! :confused:
It runs that way because of crappy programming.
1,539 (0.27/day)
System Name Main PC
Me like you & others are telling him how much crap Norton is ...but hey! if they want to keep it they'll be the only 2 guys in the world still using Norton...:laugh:
295 (0.05/day)
Las Islas Filipinas
System Name SynChron
Processor Intel Core i7 3820
Motherboard ASROCK X79 Extreme 9
Cooling CoolerMaster Hyper 212X with 2 Noctua NF-F12 fans in push/pull
Memory 4x2gb Corsair Vengeance LP 1600 CL9
Video Card(s) Asus GTX 770 DCu2
Storage Samsung 830 128gb SSD, 1TB Western Digital Velociraptor, Seagate Barracuda 320gb 7200rpm SATAIII
Display(s) HP x2301 LED
Case Corsair Obsidian 750d
Audio Device(s) Asus Xonar Essence STX
Power Supply Seasonic X - 660Watt Gold
Software Windows 7 Home Premium 64-bit
Amen to that! And its really different strokes for different folks!:)
1,539 (0.27/day)
System Name Main PC
System restore is another shitty crap but this one from M$ , i always disable this in windows most of the time it's doesn't even work & you're back to square one...:rolleyes:
Simple for me If i ever got any kind of problem(s) or virus that can't be fix then... i simply format & reinstall all , that does a much better job than M$ shitty system restore :D
2,894 (0.47/day)
South Carolina
System Name KILLER
Processor Intel Core i7 4790K
Motherboard MSI Z87 G45 Gaming
Cooling Water Cooling
Memory 2x8GB Gskill 2400mhz
Video Card(s) EVGA GTX 980
Storage SSD Samsung 500GB
Display(s) 24" Asus 144hz
Audio Device(s) X-Fi Platinum
Power Supply Antec 1200 Watt Modular
Software Windows 10 64 Bit
Benchmark Scores 3DMark Vantage 51342
If it doesnt list it then just install the correct driver.
Shouldnt cause you any problems.
Bo_Fox
480 (0.08/day)
Barack Hussein Obama-Biden's Nation
System Name Flame Vortec Fatal1ty (rig1), UV Tourmaline Confexia (rig2)
Processor 2 x Core i7's 4+Gigahertzzies
Motherboard BL00DR4G3 and DFI UT-X58 T3eH8
Cooling Thermalright IFX-14 (better than TRUE) 2x push-push, Customized TT Big Typhoon
Memory 6GB OCZ DDR3-1600 CAS7-7-7-1T, 6GB for 2nd rig
Video Card(s) 8800GTX for "free" S3D (mtbs3d.com), 4870 1GB, HDTV Wonder (DRM-free)
Storage WD RE3 1TB, Caviar Black 1TB 7.2k, 500GB 7.2k, Raptor X 10k
Display(s) Sony GDM-FW900 24" CRT oc'ed to 2560x1600@68Hz, Dell 2405FPW 24" PVA (HDCP-free)
Case custom gutted-out painted black case, silver UV case, lots of aesthetics-souped stuff
Audio Device(s) Sonar X-Fi MB, Bernstein audio riser.. what??
Power Supply OCZ Fatal1ty 700W, Iceberg 680W, Fortron Booster X3 300W for GPU
Software 2 partitions WinXP-32 on 2 drives per rig, 2 of Vista64 on 2 drives per rig
Benchmark Scores 5.9 Vista Experience Index... yay!!! What??? :)
No offense, but I think this is bad advice.
Formatting and reinstalling is usually not the better option for most people. Sometimes, a system restore magically fixes everything. (At least try system restore to different dates, as far back as possible before formatting.) If there's a virus, it could usually be fixed with an anti-virus program or spyware program (there is amazing help on the internet from a couple sites.. Majorgeeks is one of the, I think). All of those volunteers are true, humble geniuses and dedicate so much time helping out with these problems.
145 (0.03/day)
Cooling Stock
Mobo driver installed. Don't really see a difference. Now, I have CPU-Z.
I believe I have GPU-Z as well. WHAT info should I list to see if anythings not working right? Because Im tired of this CPU running at 10-20 FPS on a game it should have at least 30-40 on....
troyrae360
1,129 (0.19/day)
Christchurch New Zealand
System Name My Computer!
Processor AMD 6400+ Black @ 3.5
Motherboard Gigabyte AM2+ GA-MA790X DS4
Cooling Gigabyte G-Power 2 pro
Memory 2x2 gig Adata 800
Video Card(s) HD3870x2 @ 900gpu and 999mem
Storage 2x wd raid edition 120gig + 1 samsung 320 + samsung 250
Display(s) Samsung 40inch series6 full HD 1080p
Case NZXT Lexa
Audio Device(s) ALC889A HD audio with Enables a Superior Audio Experience (on board)
Power Supply Vantec ION2+ 550w
Software Vista Home pream 64
Norton 360 is most probley a factor in his poor gaming experince, I would Uninstall it stright away, Heres the link youll need it to remove your norton product http://service1.symantec.com/Support/tsgeninfo.nsf/docid/2005033108162039
It really is a shame that you won't take our advice on 'free products' as we here at tpu know our stuff our computers are our pride and joy, we would never point you in the wrong direction, I know for a fact that Superantispyware is a bloody good program and definitley wont screw with your computer!!
in short Norton 360 if CRAP!!!! Having this program on his computer makes me wonder what other crap loading on startup on his pc?
What operating system is he using XP 32 bit or 64bit?
Molignar
30 (0.01/day)
System Name Main Rig
Processor Intel i5 2500k @ 4.0Ghz
Motherboard Gigabyte P67-UD4 B3 F2 BIOS
Cooling 8 x 120mm Scythe S-Flex 1900rpm (HAF932 Case), 1 x 120mm Scythe S-Flex 1900rpm (on Noctua NH-U12P)
Memory 8Gb GSkill RipJaw XL DDR3 1600 9-9-9-24 1.5v
Video Card(s) 2 x MSI 460GTX Cyclone OC
Storage 1 x OCZ Vertex2 Extended 60Gb, 1 x WD 80Gb Blue, 2 x WD 2.0Tb Black
Display(s) Dell UltraSharp 2209WA
Case CoolerMaster HAF 932
Audio Device(s) Creative X-Fi XtremeGamer PCI
Power Supply Thermaltake ToughPower 1200w Modular
Software Windows 7 Professional x64
Benchmark Scores CPU-Z Validation - http://valid.canardpc.com/show_oc.php?id=1684402
I have to agree. People around here are pretty knowledgable. SuperAntispyware is a very solid program. There's many others that are good too. Comodo is rated #1 at www.matousec.com as a complete security solution (Firewall + Antivirus). Best of all, it's also free. There's also PC Tools Firewall, it's free aswell and rated very high. Outpost Security provides a free version of they're firewall again highly rated. There's far better choices for you that are less resource heavy and lighter on the wallet. Cheers!
Edit - I should also add all of these programs outside of SuperAntispyware have both 32 and 64bit flavours. Not entirely sure if SuperAntispyware has gotten around to a 64bit exe yet.
145 (0.03/day)
Cooling Stock
XP so 32 bit. And it's not my choice, it's his. I also dont generally have many issues. But I seriously doubt Norton alone would drag it down that much. Is there anything else I can check with CPU-Z or GPU-Z or w/e? I'm not saying you guys don't know...but he refuses.
1,539 (0.27/day)
System Name Main PC
Yes! it works on 64bit OS no problem got it as always on my Win7 Ultimate 64bit
You would be surprise some times... just uninstall Norton & do a good clean up ,restart & try the games again if no differences reinstall Norton ....simple enough.
Yeah start GPU-z & see what it give you as clock speed & pci-e & most important the temps click on Sensors tab & check Log to file & continue refreshing this screen...(see pic)
After playing/exit the game go in your documents & find the GPU-z sensor log & open it up & see what max temp you card is reaching...
troyrae360
1,129 (0.19/day)
Case NZXT Lexa
You have gone out of your way to help your brother get his computer up to speed, you came to the right place to find that advise. :D
However if your brother is too ignorant to listin let him suffer, he should take our/your advise and if he dosn't its his own fault that his computer runs games like a rotten apple!!!!!
Deleted member 67555
Sometimes it is easier just to type "dxdiag" into the Run Dialog
and you will get a screen like this
it will tell us your memory MOBO maker and Cpu info
What they are trying to tell you and your brother that Norton 360 is simply a draw on your PC specially when playing online It alone can add +25 to your ping
Norton registry tools do not work as well as cCleaner IMHO
Just because you defrag once a month does not always mean it's done all the way sometimes you may need to run it a few times to get everything
If the PC is 2 years old you most likely need to replace the CPU TIM and dust
you could also download CPU-Z HW Monitor so we could see all of your temps
http://www.cpuid.com/hwmonitor.php
OH and he is some good software for screen captures
http://www.techpowerup.com/tpucapture/
Plus once you allow spyware Norton will never ask you again SO... sometimes it's better to get a second opinion such as use another program to hunt them down for you..
there is no harm in checking you can always use another program to check and uninstall it and reinstall norton
145 (0.03/day)
Cooling Stock
By Clock speed, do you mean GPU/Default Clock? Both are 675.
Is the PCI-E info the 'Bus interface' info?
GPU Core Clock - 675.0 MHz
GPU Memory Clock - 915.0 MHz
GPU Shader Clock - 1700.0 MHz
GPU Temperature - 58.0*C
Fan Speed - 35 %
Memory Used - 29 MB
GPU Load - 0%
Memory Controller Load - 0%
Video Engine Load - 0%
That's without me going on one of the games. My bro was on Megaman X8 earlier though...
Here's the info from the DXDiag
OS: Windows XP Professional (5.1, Build 2600)
System Manufacturer: NVIDIA
System Model: AWRDACPI
BIOS: Phoenix - AwardBIOS V6.00PG
CPU: Intel Pentium D CPU 2.80 GHz (2 CPUs)
Memory: 3328 MB RAM
Page File: 687MB Used, 4528MB available
Small page file.......
I would increase that to 2048 and see if that helps
145 (0.03/day)
Cooling Stock
Isnt page file VRAM?
EDIT: And to answer; Highest was 62*C. Im telling you, it's not the GPU. If a low requirement game like HL2 is on low and lags...the issue isn't the GPU, especially since its a 9600 GT. It's either the CPU, Mobo, or something inbetween.
1,539 (0.27/day)
System Name Main PC
Fan Speed - 35 %
Memory Used - 29 MB
GPU Load - 0%
58c at idle so it may go near ~90c if not more at full
Start GPU-z & let it run in the background Then play the game for 5-10 minutes after exit the game stop GPU-z & go in to your document & open up the GPU-z sensor log & see what max temp you got there.
EDIT: Just saw your edit...
62c in games (3D) when your card does 58c in ilde?
Something not right there... either you didn't look at all the sensor log (scroll down list) or your 9600GT doesn't bump in to 3D speed get stock at 2D speed..unlikely
Sure drivers are correctly install?
145 (0.03/day)
Cooling Stock
Read my edited post. It was 62 at the highest. And that was after playing L4D2 on a multiplayer versus of the first level of Dead Center at all low settings, 2X MSAA, Bilinear, and Multicore Rendering. I'm telling you, it's probably not GPU. I honestly think it's CPU or something regarding the CPU....
troyrae360
1,129 (0.19/day)
Case NZXT Lexa
Did you try uninstalling Nortin360?
Install HW monitor if it works
run a game windowed so you can observe the CPU temps while playing
