- Feb 15, 2009
- 685 (0.11/day)
- Norway, which means Amazon is not available...
System Name | Winter v3.2024 |
Processor | Intel i7 12700K (since november 2021) |
Motherboard | Gigabyte Z690 Gaming X (since november 2021) |
Cooling | Air Liquid Freezer II 360 with LGA1700 kit (since november 2021) |
Memory | Crucial Ballistix 2x16gb 3600mhz C16 (since november 2021) |
Video Card(s) | Gigabyte RTX 3060 Ti Gaming OC Pro LHR - Rev3.0 (since july 2022) |
Storage | 1x Kingston NV2 2 TB m.2 nVMe (since december 2024), 1x Seagate 4TB SATA |
Display(s) | 1x 55" LG C1 4k OLED, 1x Gigabyte 32" M32Q and 2x AOC 27" CG1 |
Case | Fractal Design Define R6 (since 2018 and still working like a charm!) |
Power Supply | Corsair RM850x black (since august 2022) |
Mouse | Razor Deathadder v2 (since december 2021) |
Keyboard | Varmilo VEA109 v2 MX Silent Red (since august 2022) |
Software | Windows 11 Pro |
Youi could take a look at the Asrock Fatal1ty B450 Gaming K4 and Asrock B450 Pro4.
I haven't done any research on those but I do know they both have decent VRMs.
So I'd recommend you check reviews of them to see how well (or not) they were rated.
And possibly the Gigabyte B450 Aorus Elite, which again I have NOT researched at all.
Those were well enough my budget, but by the looks of reviews and specs, it doesn't quite match up to the likes of B450 Tomahawk Max and Strix B450-F Gaming that you've previously listed, which are both nicely within my budget line. So yeah, it will most likely be either of those 2... but which one, that is what i need to decide on, but there's still time. I am not upgrading until END of november...
some 1660 super leaks show it's worth waiting for,just like 5500xt
if this ends up 10% faster at same/reduced price it's gonna be really good for the money.
may wanna wait for 5600xt too,might be an absolute price/performance killer,though if you're looking for a card for streaming turing might be better thanks to its very good encoder.
@minstreless list a couple of b450 boards that are within your budget,we'll pcik the best one.
god damn this build is turning out to be really nice for the money.
2700x and 1660 super are gonna do a fantastic job for 1080p streaming both for now and well into the future and it won't cost you that much.
Wohaa! That 1660 Super sounds like a rock solid deal, for sure. Especially if it will end up costing about the same as the 1660 cards you have previously mentioned.
When it comes to the B450 mobos, i can afford B450 Tomahawk Max and Strix B450-F Gaming. Not sure if there are other mobos that cost the same or are in the same class, but according to @NoJuan999 they seem to be pretty nice with good specs and that will work well with the 2700X.
Yes, i believe it is starting to look like a proper build that is well within my budget. THANKS a bunch for them advises!
