p_o_s_pc
F@H&WCG addict
- May 2, 2007
- 13,010 (1.96/day)
- Newark ohio
System Name | el'lappy|Cruncher | Cruncher 2 |
Processor | intel C2D T6400 | i7 3770k @4.2ghz | AII X2 220 @3.4ghz |
Motherboard | some Acer | Asus P8Z77-V Pro |Gigabyter GA-M61p-S3 |
Cooling | dual 80mm cooling fan | WC'ing ) |cheapo |
Memory | 2x2gb ddr3 | 2x2gb Ripjaws 1600 |4x512mb D9s |
Video Card(s) | onboard | 60 1GB(hd7770 ) |8800GTS |
Storage | Momuntus xt 320gb |Kingston Hyper X 120gb SATA III|500gb WD |
Display(s) | 17in | 42" 1080P HD 3D TV |
Case | lappy case | CM HAF XB |none yet |
Audio Device(s) | onboard | onboard | onboard |
Power Supply | Dell brick w/ acer end end | Antec EW 650w |Antec SP 350w(upg.soon) |
Software | Windows 7 Ult. 64bit---->-------> |
Post your CPU temp Idle and/or load.You can use any software you want. Tell clocks voltage and cooling also CPU type and software used don't forget a SS
here is mine
AMD Athlon 5000+BE @3ghz 214x14@1.35v
Xigmatek 1283
software used -Easy tune 5
15c idle
here is mine
Xigmatek 1283
15c idle
