Problem with RAM ddr2 1066 help
blackbird307
106 (0.02/day)
System Name Idk
Processor Athlon II x4 Propus 620 @3.6ghz ~ 2.6ghz Stock
Motherboard MSI 890FXA-GD70
Cooling Cooler Master V8 with Arctic Silver 5 thermo paste
Memory 4gb DDR3 1600 ADATA
Video Card(s) Sapphire Radeon HD 5770 1GB GDDR5 128-bit
Storage 1tb SATA Seagate ST31000340AS
Display(s) ht09 28" lcd 1080p 16:10 t.v
Case Antec 902
Audio Device(s) AC'97 hd
Power Supply Corsair 650TX
Software Windows 7
I got a new cpu lately and for some reason im having problems when running ram at 1066.
I went into the bios and set the mem multiplier to 5.something. I also raised the memory voltage from 1.8 to 2.1.
Windows runs normal but when I play games like gta 4 it crashes after a while. It seems to work fine at 800 however. Is there a way to fix this? Or do I have to work around this issue and fool around with the cpu clock and reference clock leaving the mem clock at default?
It's a shame because this ram is meant for 1066 and I can't even get it to work properly.
2,894 (0.47/day)
South Carolina
System Name KILLER
Processor Intel Core i7 4790K
Motherboard MSI Z87 G45 Gaming
Cooling Water Cooling
Memory 2x8GB Gskill 2400mhz
Video Card(s) EVGA GTX 980
Storage SSD Samsung 500GB
Display(s) 24" Asus 144hz
Case Cooler Master HAF
Audio Device(s) X-Fi Platinum
Power Supply Antec 1200 Watt Modular
Software Windows 10 64 Bit
Benchmark Scores 3DMark Vantage 51342
Post a screen shot of CPU-Z with cpu and memory tab and ill take a look.
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
you'll likely need to manually set the timings for the ram, not just the MHz and voltage. use CPU-Z to see what its currently running at.
Problems with 1066Mhz DDR2 are very common - its one of the reasons i'm sticking with 800Mhz, until i go DDR3
brandonwh64
19,542 (3.42/day)
yea i had a set of DDR2-800 (still do) and they ran great on all setups i have installed them in
1,539 (0.27/day)
Canada/Québec/Montreal
System Name Main PC
Processor PII 925 x4 @3.724GHz (266x14) 1.525v NB 2660 1.425v
Motherboard Gigabyte AM3 GA-890XA-UD3 (790x+SB850)
Cooling Scythe Mugen 2 rev.B
Memory Hyperx 8GB (2x4) 1600@1418 8-7-7-20-27-1t
Video Card(s) GTX 680
Storage 256GB SSD / 2TB HDD
Display(s) LCD Samsung 24" 16:9
Case Cooler Master HAF 912
Audio Device(s) On-Board HD
Power Supply CM 750w GX |3.3v@25a|5v@25a|12v@60a
Software Kubuntu dual boot /Windows 7 Ultimate 64bit
Benchmark Scores later...
You are overclock?
My guess is that your ram is higher then 1066 right now...
Mussels
58,412 (7.78/day)
Oystralia
You are overclock?
we'll know when he provides us a screenshot of CPU-Z
blackbird307
106 (0.02/day)
System Name Idk
Case Antec 902
Software Windows 7
CPU:
Memory:
Also the only reason I raised the voltage was because I read that the ram is at 1.8 when using 800mhz. Either way it didn't make a difference in my case so I changed it back.
1,539 (0.27/day)
System Name Main PC
Your ram are not much overclock lol!
Try 6-5-5-18-32 at 2.1v or 2.2v
BTW: Your ram are rated for 2.1v then don't under volt the ram
Mussels
58,412 (7.78/day)
Oystralia
could you also show us a screenshot of the SPD tab?
1,539 (0.27/day)
System Name Main PC
Right! forgot about that , that could will give you/us what all the timings of your ram should be at
blackbird307
106 (0.02/day)
System Name Idk
Case Antec 902
Software Windows 7
I changed the timings 6-5-5-18-32 at 2.1V.
2,313 (0.36/day)
If I told u.. I'd have to kill u
System Name Hogan's Crap
Processor Intel i3-2120 Crap!
Motherboard Dell POS Crap!
Cooling Stock Crap!
Memory 4 GB Kingston DDR3 10600 Crap!
Video Card(s) Stock Crap!
Storage 500 GB 5400 rpm Crap!
Software Windows 10 64bit
2.2v OCZ are very touchy when it comes to voltage, they need what they are rated at. Manually set your clocks to exactly what they are rated, youll be fine. If they act up after setting them, maybe RMA time.
blackbird307
106 (0.02/day)
System Name Idk
Case Antec 902
Software Windows 7
I turned off cool and quiet, didn't know it was enabled. Is it possible that cool and quiet causes problems like this? Also it says 2.1-2.2V my board only lets me get up to 2.1 is this good? I also had these sticks for quite a while so I think it may be too late to rma lol.
Ill test to see if anything goes wrong.
2,313 (0.36/day)
Cooling Stock Crap!
memtest them. Hope they are ok. The price off DDR2 is crazy right now. :shadedshu Have you checked for a new BIOS for your mobo? Maybe a fix to the 2,1v limit.
5,678 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
I had a similar problem with my Corsair Dominator Twin2x2048 ran fine with just two dimms but 4 would make it crash was told to up the IMC (CPU north bridge) voltage from 1.2V to 1.4V now it's fine i also see your timing are the same as mine 5-5-5-15 CL2
Field Value
North Bridge Properties
North Bridge AMD K10 IMC
Supported Memory Types DDR2-400 SDRAM, DDR2-533 SDRAM, DDR2-667 SDRAM, DDR2-800 SDRAM, DDR3-800 SDRAM
Revision 00
Probe Filter Not Supported
Memory Controller
Type Dual Channel (128-bit)
Active Mode Dual Channel (128-bit) - Ganged
Memory Timings
CAS Latency (CL) 5T
RAS To CAS Delay (tRCD) 5T
RAS Precharge (tRP) 5T
RAS Active Time (tRAS) 15T
Row Cycle Time (tRC) 22T
Command Rate (CR) 2T
RAS To RAS Delay (tRRD) 4T
Write Recovery Time (tWR) 10T
Write To Read Delay (tWTR) 4T
Read To Precharge Delay (tRTP) 6T
Four Activate Window Delay (tFAW) 18T
Write CAS Latency (tWCL) 5T
Refresh Period (tREF) 7.8 us
DRAM Drive Strength 1.25x
DRAM Data Drive Strength 1.5x
Clock Drive Strength 1.5x
CKE Drive Strength 1.5x
Idle Cycle Limit 16
Error Correction
ECC Supported, Disabled
ChipKill ECC Supported, Disabled
RAID Not Supported
DRAM Scrub Rate Disabled
L1 Data Cache Scrub Rate Disabled
L2 Cache Scrub Rate Disabled
L3 Cache Scrub Rate Disabled
Memory Slots
DRAM Slot #1 1 GB (DDR2-1066 DDR2 SDRAM)
DRAM Slot #2 1 GB (DDR2-1066 DDR2 SDRAM)
DRAM Slot #3 1 GB (DDR2-1066 DDR2 SDRAM)
DRAM Slot #4 1 GB (DDR2-1066 DDR2 SDRAM)
1,539 (0.27/day)
System Name Main PC
I turned off cool and quiet, didn't know it was enabled. Is it possible that cool and quiet causes problems like this? Also it says 2.1-2.2V my board only lets me get up to 2.1 is this good?.
It's a gigabyte board did you press CTRL+F1 in Bios?
It will let you see all hidden features/options in the bios
Yes! disable cool & quiet always when OC
Mussels
58,412 (7.78/day)
Oystralia
if your board has a limit of 2.1v and the ram wants 2.2v, that may well be a problem. Its nots guaranteed to be a problem, but its definitely possible.
5,678 (1.02/day)
Gougeland (NZ)
yup i forgot to say that press ctrl + F1 you beat me to it... if all you can get out of your bord is 2.1v try lowering the timings to 6-6-6-18 CL2
blackbird307
106 (0.02/day)
System Name Idk
Case Antec 902
Software Windows 7
My bios is the latest version F7, I tried the ctrl+f1 thing still 2.1V however. As for memtest I tried putting it on a floppy but I couldn't open rawrite because I am using a 64-bit os. I had a linux install disc Fedora-9 it had memtest86 on it but it thought my cpu was an opteron and my ram was 433mhz ddr2 still passed though lol :). I am also using 6-6-6-18 CL2 now, i will test it out in bit.
Edit: crashed still lol. It doesn't just crash in gta 4, I was downloading something i came back to check and computer froze.
Corduroy_Jr
1,102 (0.19/day)
barrie ont
Processor Phenom II 965
Motherboard Biostar TA870+
Cooling Zalman CNPS10X Performa
Memory Kingston hyperx 1600mhz 2x8gb
Video Card(s) ASUS Radeon HD 6870 DirectCU II 990/1250 stock volts
Storage Seagate 500gb, Wd 1tb black
Display(s) SAMSUNG 2433BW 24
Case Thermaltake v3 black edition
Audio Device(s) onboard, Logitech x540
Power Supply Antec true power modular 650 watt
Software Windows 7 x64 ultimate
for hes board vdimm max is v2.1750 set your mem to max, raise north bridge voltage to 1.35v, put memory timings back to 5.5.5.15 2t, take my word for it, i own the same memory and owned a few am2/am3 gigabyte boards, another thing i noticed your cpu is at 1.456v that's to high for stock clocks, lower vcore to 1.35v
blackbird307
106 (0.02/day)
System Name Idk
Case Antec 902
Software Windows 7
Well, I kinda still crashed. Maybe it's not the voltage? If it is there is not really much that can be done about it. The only other reason I can think of is overheating but everything is in the safe range below 40c/104f-50c/122f at max otherwise under 40c.
5,678 (1.02/day)
Gougeland (NZ)
Corduroy_Jr
1,102 (0.19/day)
barrie ont
blackbird while in bios press Ctrl+f1 set memory to 2.175v, nb 1.30v, cpu vcore to 1.35v, set ram timing's to 5.5.5.15
Wrigleyvillain
PTFO or GTFO
7,702 (1.20/day)
Chicago
System Name DarkStar
Processor i5 3570K 4.4Ghz
Motherboard Asrock Z77 Extreme 3
Cooling Apogee HD White/XSPC Razer blocks
Memory 8GB Samsung Green 1600
Video Card(s) 2 x GTX 670 4GB
Storage 2 x 120GB Samsung 830
Display(s) 27" QNIX
Case Enthoo Pro
Power Supply Seasonic Platinum 760
Mouse Steelseries Sensei
Keyboard Ducky Pro MX Black
Software Windows 8.1 x64
Please note a Memtest86 boot disc is an invaluable tool for testing RAM. Makes it more efficient and easier to check stability and you don't run the risk of crashing in game or, worst case, corrupting data or hosing your Windows install. The latter isn't exactly likely but possible.
2,190 (0.36/day)
Minnesota, USA
System Name TaichiTig
Processor i7 6800K
Motherboard ASRock X99 Taichi
Memory 32GB DDR4 3200
Video Card(s) RTX 4070
Storage SSD + Misc. HDDs in DrivePool
Display(s) BenQ PD3200U, Samsung C32HG70
Case Antec Twelve Hundred
Audio Device(s) Behringer UMC404HD, LSR308, Shure SRH840, AKG K612, Etymotic HF5
Power Supply Corsair 750TX
Keyboard Deck Legend Ice Tactile
Software Win10
But also, as others have mentioned, 1066 can be trickier, and giving these modules the max voltage your board are capable of is a good idea. For the extra performance you'll get out of 1066 vs 800, it's not a big loss to be stuck running them at a lower speed.
