problems with health when running a pc might be a psu
woprock
7 (0.00/day)
yo dude i have problem i feel i get electricity shock to my nerve and my health my nerves are suffering from it , i think its the cause of the power supply not working to health properly, but the power supply itself is working stable no problems in running pc but its bad for the health i heard u said unplug everything in psu and before that unplug and touch the inside (unplug psu, press power button, touch inside of case, feel good about self, remove mobo, do whatever, put back in, win. ) but i m scared to do that because of electricity what happened and it damaged my nerve in my hand now i have carpal tunnel syndrome so i dont know what to do .
( it was to some1 who i seemed to find the solutionbut i couldnt message him about him so i leave the same message behind because its the best i can describe ).
so is there alternative way to end electricity so u dont have any electricity to harm you ,
so alternative way to reset a power supply
is it possible ?
and when its possible how to do it
5,379 (1.03/day)
Gougeland (NZ)
System Name Cumquat 2021
sounds like it's lacking a good earth on the power socket you're plugging it into you really shouldn't be getting shocks from your PC's power supply
woprock
7 (0.00/day)
might be true
but its funny cz before the force restart i did there wasnt any electrical shock problems now there is after
if it isnt ?
107 (0.03/day)
CT USA
Curious, is your computer on a metal desk? Can you test to see if PS is actually grounding? This is interesting on the nerve damage.
woprock
7 (0.00/day)
nah its on television desk basic old carpet desk
or is it better off on floor ?
107 (0.03/day)
CT USA
Wood is better to insulate. Floor is better too. A huge desktop mouse pad too.
woprock
7 (0.00/day)
i dont know is it outlet what needs to be changed or is it power supply
107 (0.03/day)
CT USA
Does the outlet even have a ground? Two prong outlet, old wiring?
Worst comes to worst you could try to run a ground from the case to a radiator or water pipe, anything to ground.
woprock
7 (0.00/day)
nah its grounded but it seems that outlet was worst before, now i putted pc on the floor and old mousepad under the pc now it feels and seems alot better but its always good at the beginning when u boot ur computer
but it seems better
lets see
we ll see
159 (0.07/day)
Finland
Processor i7 4770K
Motherboard Asus Z87-Expert
Cooling Noctua NH-U12S, &case fans all controlled by Aquaero 6
Memory 2x8GB TeamGroup Xtreem LV 2133MHz
Video Card(s) Vega 64
Storage Samsung 840 Pro + 2x 5GB WD Red@RAID1
Display(s) Dell U3014
Case Lian Li PC-A71B
Audio Device(s) Sound Blaster ZxR, Objective2 (2x), AKG K702&712, Beyerdynamic DT990
Power Supply Seasonic Prime Titanium 650 (+Eaton 5P 1550 as "backup power")
Mouse Logitech G700
Keyboard Logitech G810
That doesn't have anything to do with any electricity, but only with bad ergonomics/too much repetitive stress of hand in that bad position.
(or some other hiding medical condition)
woprock
7 (0.00/day)
curioous, is it better for monitor to use basic outlet from the wall (w groundings) or with extension cable which is better? for monitor life
192 (0.10/day)
System Name Zen4
Processor Ryzen 9 7950x
Motherboard Asus Strix B650E-E Gaming WiFi
Cooling Some oem 240 AIO
Memory 2xKingston DDR5 2x16GB (Hynix M die)@6000 CL26-35-35-27
Video Card(s) Gainward Phantom 4090 (@2.82GHz .95V UV, 350W PL)
Storage WD Black SN850X
Display(s) LG OLED C1 48"
Case Phanteks P600S
Power Supply Corsair RM1000i
Mouse Logitech G Pro X Superlight
Keyboard Corsair K70
VR HMD HP Reverb G2
Software Win11
Ground might not be "true" ground if an appliance connected close to you is faulty, or you have faulty electrical wiring in your home (might even be outside your home). It can be dangerous, and you should have it checked. I would strongly recommend getting someone professional to check it out, but you can also buy AC Outlet Ground Tester equipment that you can try yourself, quick amazon search:
https://www.amazon.com/s?k=AC+Outlet+Ground+Tester&ref=nb_sb_noss
12,147 (1.87/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
^^^THIS^^^ You definitely need to check the wall outlet to make sure it is wired properly and grounded to Earth ground. If not wired properly, you need to have the outlet repaired by a qualified electrician.
Unplug it, wait 15 seconds or so and plug it back in. But having the outlet tested is your first priority. However, there typically is not a "reset" feature for computer power supplies. If there is, it is only to restore output - not to correct a ground fault or incorrect voltage scenario.
You don't say where you live, but most home improvement stores have outlet checkers for your local outlets - like the one above for 110VAC for here in the US, or this one for the UK.
Make sure the tester you get tests for Ground Faults, then use it to check all the outlets in the house, especially those near water like the kitchen and bathroom. If any fault, contact a qualified electrician (or the landlord - and be very serious and firm with a landlord that this is a top priority). If you live in an apartment complex, check your neighbor's outlets too. If theirs are bad also, more people complaining can make a lot more noise.
This type of electrical shock cannot cause carpal tunnel syndrome. That is typically due to a RSI. But getting zapped (or even tensing up out of fear of being zapped) could surely aggravate it.
More significantly, an electrical shock (that does not throw you across the room) could be deadly for someone with a heart condition, or a small child. So it must not be ignored.
192 (0.10/day)
System Name Zen4
Case Phanteks P600S
VR HMD HP Reverb G2
Software Win11
Oh, and just in case it is not obvious, a ground fault can make touching any electrical appliance in your home dangerous, as most metal chassis are connected to ground, even when turned off.
12,147 (1.87/day)
Nebraska, USA
Mouse Logitech M190
If the appliance uses a 3-prong plug, that is very true.
1,161 (0.73/day)
Loose in space
System Name "The black one in the dining room" / "The Latest One"
Processor Intel Xeon E5 2683 V4 16c/32t / i7 14700K @5.8GHz
Motherboard Asus X99 Deluxe / ASRock Z790 Steel Legend WiFi
Cooling Arctic Liquid Freezer II 240 w/4 Silverstone FM121 fans / Arctic LF II 280 w Silverstone FHP141's
Memory 64GB G.Skill Ripjaws V DDR4 2400 (8x8) / 96GB G.Skill Trident Z5 DDR5 6400
Video Card(s) EVGA RTX 1080 Ti FTW3 / Asus Tuff OC 4090 24GB
Storage Samsung 970 Evo Plus, 1TB Samsung 860, 4 Western Digital 2TB / 1tb, SK hynix P41 Platinum 2tb
Display(s) 43" Samsung 8000 series 4K / 50" Vizio M-series 4K
Case Modded Corsair Carbide 500R / Modded Corsair Graphite 780 T
Audio Device(s) Asus Xonar Essence STX II/ Asus Xonar Essence STX
Mouse Logitech Performance MX, Microsoft Intellimouse Optical 3.0
Keyboard Logitech K750 Solar, DiNovo Edge
Software Win 10 Enterprise LTSC 2021 IoT / Win 11 Pro for Workstations 22H2
Benchmark Scores https://www.passmark.com/baselines/V11/display.php?id=202122048229
woprock
7 (0.00/day)
yeah i fixed it , but how to ground your monitor i feel im getting zapped static to my hand
20,949 (5.97/day)
Case Fractal Design Define R5
Mouse XTRFY M42
Software W10 x64
This...
You're probably not feeling zapping, you are suffering from a medical condition; you shouldn't be using the PC or a mouse to begin with. Not a standard one anyway.
You probably will benefit from using something such as this instead - and rigorously limiting your number of consecutive hours doing the same motion:
Visit your doctor and get advice.
As for grounded sockets and quality of your house grid. Get a qualified electrician for that. If a socket wasn't properly grounded before you won't be making it so. Yes, you can ghetto it with running a metal wire somewhere someplace...but do you want to?
12,147 (1.87/day)
Nebraska, USA
Mouse Logitech M190
yeah i fixed it ,
How? Forums are places to learn and to share what we have learned. So how did you fix it so others may learn too.
Make sure your computer and your monitor (and everything else connected to your computer) are plugged into the same wall outlet. Other wise, there may be a slight "difference in potential" to Earth ground. This can result is feeling a slight shock. It also commonly is heard as a slight buzzing sound in speakers.
If you must power through different wall outlets, run a grounding wire from the monitor to the computer case. There is almost no current so you can use very thin (22-24 AWG), single conductor wire. Just connect one end to a mounting screw on the case for computer's power supply and the other end to a mounting screw on the monitor. Make sure the monitor screw screws into metal and not just plastic.
2,669 (0.50/day)
System Name Old Gateway / Steam Deck OLED LE
Processor i5 4440 3.1ghz / Jupiter 4c 8t
Motherboard Gateway / Valve
Cooling Eh it doesn't thermal throttle
Memory 2x 8GB JEDEC 1600mhz DDR3 / 16gb DDR5 6400
Video Card(s) RX 560D 4GB / Navi II 8CU
Storage 240gb 2.5 SSD / 1TB nvme
Display(s) Dell @ 1280*1024 75hz / 800p OLED
Case Gateway / Valve LE
Audio Device(s) Gateway Diamond Audio EMC2.0-USB 5375U ($15 a long ass time ago), Valve
Power Supply 380w oem / 65w valve USB-C
Mouse Purple Walmart special, 1600dpi. Black desk mat
Keyboard SteelSeries Apex 100 / virtual
VR HMD Lmao
Software Windows 10 / Steam OS
Benchmark Scores It can run Crysis (Original), Doom 2016, and Halo MCC. SD LE 45fps
Get a decent surge protector... A decent one will indicate a ground issue if there is one
And make sure it's a surge protector and not just a current tap
