jonomaia
- Aug 23, 2018
- 23 (0.01/day)
System Name | Jon-pc |
Processor | AMD FX 8370E 4.5GHz oc |
Motherboard | Gigabyte 970a UD3p Rev 2 |
Cooling | Corsair H45 |
Memory | Corsair vengeance 2x8 Gb 1600 cl10 |
Video Card(s) | Galax GTX970 4gb OC edition |
Storage | WD Blue 7200rpm 1tb HDD + seagate 5400rpm 1.5tb HDD |
Display(s) | Samsung SyncMaster TA550 |
Power Supply | GX650 Cooler master CM edition PSU |
Mouse | Logitech G Pro |
Software | Win 10 |
Hello folks. I know that the first thing that comes to mind is: "if it is stable, it wont stutter". but i will try to explain:
i'm have a weird issue in my pc about quite sometime now and i don't know what to do anymore to try to fix it...
Basically all games that requires texture loading causes stuttering every time that it is loading them. in open worlds it happens the most. but even on games like Rocket League, when you open the game or change cars in the MENU, the stutters occurs (independent of graphic options and gpu/cpu usage). I noticed that it diminishes after playing and loading them for the first time. In my mind, it could be caused by the load from the HDD, that was the slowest part in my pc. with that in mind, I have bought a new HD, 7200rpm, that sped up considerably, at least 2x faster than my 7 year old 5400rpm green seagate all other operations, but the problem still persists identically...
The prime examples are: PUBG (texture pop + stutter), GTA (same), ROCKET LEAGUE (always when a new player/car joins match, when changing cars in menu), F1 2017 (just in the begining of race, when loading some txtres).
Other examples like ASSETTO CORSA, even in max settings and with 20 cars on the track, with gpu and cpu usage very high, it basically never occurs. in my mind, that is because after the first load, the game doesn't need to load any other texture.
I have done one more test and noticed one more thing:
Running the games that have the issue in windowed mode + videos in background, I could notice that the stutter don't freeze the entire system, neither the mouse. while playing PUBG and ROCKET LEAGUE, the stutters occured in game but the background video continued to play nice and smooth. Doing an 8 shape with the mouse movement in background I could notice that it did not stutter aswell.
these are the prints that i took in the exact stutter moments:
(in pubg while walking through the map and in ROCKET LEAGUE while selecting cars in the Menu. ps: after the car is loaded one time, the stutter do not happen again)
https://prnt.sc/k9b7n4
https://snag.gy/CW5Fpm.jpg
My setup:
16 Gb RAM Corsair Vengeance 1600 cl10
Gigabyte 970a UD3P rev. 2 motherboard
FX8370E AMD 8core.
Corsair H45 water cooler
1Tb Western Digital Blue 7200 HDD
Windows 10 pro OS
So:
here are the list of everything that i have already tried to do:
-reset/remove overclock from cpu, tried underclocking it too
(system is 100% stable in Prime95 and IBT AVX both defaut clocked, overclocked or underclocked)
-reinstall games
-check no to "fullscreen optimizations" in windows 10 options
-set energy options to maximum performance and set cpu to always 100%
-chkdsk - ok
-memtest - ok
-HPET on and off – in BIOS and System
-uninstalling msi afterburner and VFX audio enhancer.
-disabling superfetch, telemetry and other system stuff
-disable and enable nvidia cache shader
-fresh installed win10.
-underclocked and overclocked GPU and CPU. no good
-tried RAM in single and dual channel, both sticks alone, higher timmings, xmp on and off.
-reconnected the cables and gpu. no good.
-switched PCI slots
-tried various setting and power options of nvidia control panel and NV-inspector, like computing mode, changing physics processor, disabling audio, setting everything to performance, quality and all the other options available.
-tried uninstalling the Video drivers, tried with various older drivers.
-disabling HDD caching
-tried HDD in AHCI and IDE modes
-tried all SATA ports
-unplugging my PS4 controller
-disabling OS paging file and setting it to system managed.
-updated BIOS to latest version
-converted HDD from gdp to MBR
-unplugged mouse, headset and keyboard.
-increased resolution to 4K, and decreased to Below FullHD
-tested with HDMI and VGA cable.
-reseted BIOS CMOS
-tried 2400, 2200, 2000 HT link in bios.
-overclocked GPU +50Mhz (stable 1442Mhz clock with +12.5mV overvolt, Max temperature reached 82)
-Bought New HDD.
-disconected the older HDD
-tried disabling windows defender, firewall etc
-disconnected net cable
-locking it to 60 and 59 fps, as well tried to change monitor refresh rate to 59.
-disabled 4 cores of 8 cpu.
-disabled unused mobo and case features - serial port, usb 3.0 and case audio port.
-reconnected all PSU cables and used a specific one for each component, including 2 diferent pci to the GPU.
-set processor power management in advanced power options to 50%, 95%, 99% and 100% min and max.
-Tried HPC and APM in cpu.
-pci Express link state power management in power options to Off, moderate power savings and maximum power savings.
-tried secondary PCI port.
-unplugged internet cable.
-gamemode on and off
-nb speed 1800, 2000, 2200, 2400(which bugs the entire system)
-HT link 1800, 2000, 2200, 2400, 2600
-cpu clock 3.6, 3.9, 4.0, 4.1, 4.2, 4.3, 4.5 - boost and all performance/power saving options on and off
-XMP on and off, channel and rank interleaving on and off, timings on auto and manually setted.
-ram speed 1333 and 1600, timings 10-10-10-27, 9-9-9-24 in 1333, 11-11-11-30.
-vcore auto, 1.33, 1.35, 1.375
-all sata ports
-boot mode uefi and legacy, uefy only, legacy only. other pci - uefi oprom and legacy oprom
-HD audio azalia On, Off. serial port on and off
-sata hot plug on and off
-hpet On, Off
-TESTED ANOTHER GPU and CPU (PNY Gtx970 and FX8300) - same results
CPU temps were at least 10 degrees below the thermal throttle margin
MOBO temps are ok as well, all staying below 61 degrees
GPU mobo is setted at max 80 degrees.
(stutters occurs even in low usage gpu moments like menus and other stuff, even when is under 50 percent memory and buffer usage. It happens too when very much below the thermal margin set, like 55 - 65 degrees)
cellphone video demonstration:
here are the EXACT times that is cleary noticeable:
0;40 to 0;45 - loading stutters
1:00 to 1;03 - texture popping + stutter
1;06 to 1:09 - texture popping + stutter
1;31 to 1;37 - Big texture popping + Big stutter!
PS: Running benchmarks like 3dmark Firestrike I don't get a single stutter
My setup:
FX8370E AMD 8core.
Windows 10 pro OS
So:
-reinstall games
-chkdsk - ok
-memtest - ok
-switched PCI slots
-reseted BIOS CMOS
-Bought New HDD.
-all sata ports
-hpet On, Off
