theonedub
habe fidem
- Apr 30, 2009
- 8,026 (1.35/day)
- Northern CA, USA
System Name | Erakith || AsRock NUCS |
Processor | AMD ThreadRipper 2990WX ES (32c/64t 3.5ghz@1.02v) || Intel i7 1360P Raptor Lake-P |
Motherboard | MSI X399 MEG Creation || AsRock OE |
Cooling | EK Supremacy TR4 Full Nickel, D5 w/ EK Top, 2X EK-CoolStream XTX 360 & Photon 270 Res || OE |
Memory | 32GB (4x8GB) Corsair Vengeance PRO RGB DDR4 3000|| 2x16GB Corsair DDR4 |
Video Card(s) | Vega 64 EK FC|| Intel Iris Xe |
Storage | 250gb WD Black NVMe & (2) 2TB Intel 660p NVMe || 2TB Corsair MP600 Pro |
Display(s) | 34" Dell Ultrasharp U3415W |
Case | CaseLabs Merlin SM8 || Aluminum Unibody |
Power Supply | Corsair HX1000 |
Mouse | Corsair Harpoon Wireless RGB |
Keyboard | Corsair Strafe RGB w/ Cherry MX Silent |
Software | Windows 10 Pro x64 || WIndows 11 Pro x64 |
Benchmark Scores | WCG & F@H Only |
First, thank you in advance for taking the time to read through this entire post. Its long, but I wanted to be detailed and make sure to paint the entire picture as best I can
My PC has been running Mayhem's Pastel Coolant since November 2013. Mayhem's states this coolant should be good for as long as a 2 year cycle, but my coolant started having issues less than a month running in the loop- the coolant began changing color from bright yellow to orange juice orange. Since Mayhems has an online forum over @OCN, I decided to post and see what support they could offer.
Mayhems initial reply advised me that the color change must be because the radiator must have been contaminated and affected the pH of the system. They took the opportunity to pitch a new cleaning system they are selling to 'help' combat the problem.
The sensitivity to pH is news to me- nothing on the packaging mentioned pH levels. This PC was what I would call 'professionally' built and I made sure to flush the system multiple times according to the instructions on the bottle. So the contamination path really didn't seem to fit my particular case. So I let him know:
Now Mayhems gets a little condescending with his next reply:
I replied anyway, keeping it professional:
A week of silence ensued, so I repost my message and get a reply:
First off, I have no idea what he means by answering my own questions. I am answering the exact question he asked me. Second, he is really leaning towards blaming pH and pitching this new cleaning product, but again, pH is never mentioned as having such a significant impact on the fluid. I feel that if the coolant is that sensitive to pH, they should say so in their literature.
I lay out my position in full in my next reply as well as my request for a dye not as sensitive to pH:
Here is his 'professional' reply:
Passive aggressive? Check. Condescending? Double Check. Generally being an asshole? Absolutely.
So I ask you guys: Am I out of line here? Are the replies from Mayhems what you as potential customers would call fair and professional? Let me know.
Thanks!
TLDR-
-Used Mayhems Pastels Coolant which changed colors in less than a month
-Went to speak with Mayhem rep @OCN and was told either user error or someone else is at fault.
-Eventually the Mayhem rep denied me any support and told me to learn my hobby better.
Thanks!
TLDR-
