- May 30, 2018
- 1,890 (0.72/day)
- Cusp Of Mania, FL
Processor | Ryzen 9 3900X |
Motherboard | Asus ROG Strix X370-F |
Cooling | Dark Rock 4, 3x Corsair ML140 front intake, 1x rear exhaust |
Memory | 2x8GB TridentZ RGB [3600Mhz CL16] |
Video Card(s) | EVGA 3060ti FTW3 Ultra Gaming |
Storage | 970 EVO 500GB nvme, 860 EVO 250GB SATA, Seagate Barracuda 1TB + 4TB HDDs |
Display(s) | 27" MSI G27C4 FHD 165hz |
Case | NZXT H710 |
Audio Device(s) | Modi Multibit, Vali 2, Shortest Way 51+ - LSR 305's, Focal Clear, HD6xx, HE5xx, LCD-2 Classic |
Power Supply | Corsair RM650x v2 |
Mouse | iunno whatever cheap crap logitech *clutches Xbox 360 controller security blanket* |
Keyboard | HyperX Alloy Pro |
Software | Windows 10 Pro |
Benchmark Scores | ask your mother |
See, that's the thing. I don't think the USB actually is faulty. I think it's a design weakness. I think the choice in components/layout will probably make any of this particular model have the same problem. And you know? The ports do function just fine otherwise. I can't fully say they're bad just because one specific type of device doesn't work with them. For your typical range of common USB devices, they work perfectly fine with no power or throughput related issues. I've gathered/borrowed almost every different kind of USB device looking for one that suffers from this. I don't know if its out there. For 99% of people, they'd never know how dirty the ports on this board are. Most applications will not suffer from this. Not even all audio devices suffer from this. So to me, the more commonsense assumption is to blame the device for not working with the computer, not the other way around. Obviously it's not that simple but it's like you have one device that doesn't work with something and a whole pile that do... ...logical thing is to look at that device.To be fair, if there is an issue with the usb on your motherboard, that isn't the fault of the usb standard itself.
I've been using a focusrite usb interface for 2 or 3 years without any problem (mine is powered from its own brick from the wall, not from usb though).
Initially I was a bit sceptical about using usb but it works fine IME.
Well done for figuring out the source of the problem anyway.
Any decent mobo should be fine, if the usb isn't faulty.
USB's just generally not good for timing or noise sensitive applications. And most of the time it doesn't have to be. Pick any other random USB device and chances are it doesn't care. Why would mobo manufacturers spend the money improving something that they think most people won't benefit from or be willing to pay more for? I think coincidentally many do throw down where it counts for USB audio without even realizing they're preventing problems there. Maybe it's not even cheapness, but a simple unforseen design vulnerability? USB audio's not really a consideration, outside of it being expected to work like any other device that can plug into that port. I don't even know that they could predict it if they wanted to. Sure, USB audio is huge now, but USB isn't really seen as an audio port in the same way that say, SPDIF variants are because truly, it isn't. It often works for that, but not because it was meant to. USB is kinda weak and unreliable for audio. When it works, it works. But when it doesn't, it just won't. Digital audio is a specialized application. USB is a general solution. What would typically be considered acceptable for USB standards doesn't always line up with what audio demands. I think it's too complex to be expected to work like other things do with USB.
That's why I go easy on mobo manufacturers for this. I don't see it as their job to know that USB can be finicky for audio - that's just audio in general. The developers on the audio side of things should know this perfectly well, though. So to me, it is on them to find a way to mitigate the noise vulnerability and still make their devices accessible. Interface manufacturers aren't on this, though. And I've let them know. I mean... I know it's possible. I'm sitting here with a Schiit Modi 2 Uber USB dac that is whisper quiet taking that same crummy USB signal that the Focusrite and Behringer barfed out into my speakers. If it doesn't work on every USB port that is up to the generally accepted quality standards for USB, that's a problem. It's long been known that USB can be noisy and have real-time throughput issues. And that's why most of the devices designed to interface that way don't demand clean, consistent throughput. They're perfectly content to drop packets and deal with noise because to them data is still just data. At the end of the day it'll eventually get constructed 1 to 1. Doesn't work so well with a continuous, but fluctuating data stream that needs to be shot through and built-up accurately in real-time. Minor interference that would normally get discarded becomes a real problem.
I'm not saying it's right to make motherboards with crappy USB ports... ...it's just when the flaws generally do not affect the intended use and only appear when you're going off of the beaten path (such as with audio,) it's hard not to blame the choice to use USB in the first place. It just so happens that what has generally floated by with USB standards for years isn't necessarily good enough for audio. And you can't expect USB to change for audio when there are other options that are better. The audio devices can change, though.
FWIW I don't think USB audio sounds shitty or anything. In my limited use of the 2i2 I actually really like it and can't wait to use it. The headphone out is powerful and sounds good. I've used USB audio for years on other machines with few complaints. Like I said, it's fine when it works. It's just that chance that it just wont work, for reasons you can't know, but are predictable, that makes it hard to defend for me. You know what I mean? There is nothing worse than having to replace a major component that actually works as it was made to, just because it won't work for one specific thing that you'd usually expect it would, even if it's not explicitly meant to. By going with USB as a standard I feel like we're kind of putting an expectation on it that it was never actually meant to handle. And not surprisingly, it doesn't always. Which sucks because when that happens you're pretty much out of options. And because of that I'm now out $120 on a mobo that works as advertised. If I'm lucky Asus will take it back with 7 months on it.
Just my opinion on it. At the end of the day I AM getting a new mobo
Yepyep. My first thought was power. Any time there's noise, it's an issue with either power, isolation, or both. Fortunately I have two completely unique builds to test with or I'd never know.The PSU is very important too, but it sounds like you've isolated the mobo as the culprit.
Quality of power is always going to be critical for audio, if you feed it dirty power it will be hard for it to make clean sounds.
