- Sep 3, 2016
- 50 (0.02/day)
- Greece-Land
Well in genearal im looking into old recivers so i dont mind
Processor | AMD 3900X \ AMD 7700X |
Motherboard | ASRock AM4 X570 Pro 4 \ ASUS X670Xe TUF |
Cooling | D15 |
Memory | Patriot 2x16GB PVS432G320C6K \ G.Skill Flare X5 F5-6000J3238F 2x16GB |
Video Card(s) | eVga GTX1060 SSC \ XFX RX 6950XT RX-695XATBD9 |
Storage | Sammy 860, MX500, Sabrent Rocket 4 Sammy Evo 980 \ 1xSabrent Rocket 4+, Sammy 2x990 Pro |
Display(s) | Samsung 1080P \ LG 43UN700 |
Case | Fractal Design Pop Air 2x140mm fans from Torrent \ Fractal Design Torrent 2 SilverStone FHP141x2 |
Audio Device(s) | Yamaha RX-V677 \ Yamaha CX-830+Yamaha MX-630 \Paradigm 7se MKII, Paradigm 5SE MK1 , Blue Yeti |
Power Supply | Seasonic Prime TX-750 \ Corsair RM1000X Shift |
Mouse | Steelseries Sensei wireless \ Steelseries Sensei wireless |
Keyboard | Logitech K120 \ Wooting Two HE |
Benchmark Scores | Meh benchmarks. |
Then how important having blutooth \\HDMI are to you.
System Name | Senile |
Processor | I7-4790K@4.8 GHz 24/7 |
Motherboard | MSI Z97-G45 Gaming |
Cooling | Be Quiet Pure Rock Air |
Memory | 16GB 4x4 G.Skill CAS9 2133 Sniper |
Video Card(s) | GIGABYTE Vega 64 |
Storage | Samsung EVO 500GB / 8 Different WDs / QNAP TS-253 8GB NAS with 2x10Tb WD Blue |
Display(s) | 34" LG 34CB88-P 21:9 Curved UltraWide QHD (3440*1440) *FREE_SYNC* |
Case | Rosewill |
Audio Device(s) | Onboard + HD HDMI |
Power Supply | Corsair HX750 |
Mouse | Logitech G5 |
Keyboard | Corsair Strafe RGB & G610 Orion Red |
Software | Win 10 |
The bluetooth can be added with an external adapter see here (LOGITECH Bluetooth Audio Adapter)
If it's for music only, you won't regret it, nor your wallet
Cooling | D15 |
Like if i had the money my self i be bidding on this Rotel 1056
Cooling | D15 |
*Now looks for prices*....
*Dies right away at heaven*
Case | Rosewill |
Software | Win 10 |
bring it "grabs some pills just in case"
Where are you located?
System Name | Brightworks Systems BWS-6 E-IV |
Processor | Intel Core i5-6600 @ 3.9GHz |
Motherboard | Gigabyte GA-Z170-HD3 Rev 1.0 |
Cooling | Quality Fractal Design Define R4 case, 2 x FD 140mm fans, CM Hyper 212 EVO HSF |
Memory | 32GB (4 x 8GB) DDR4 3000 Corsair Vengeance |
Video Card(s) | EVGA GEForce GTX 1050Ti 4Gb GDDR5 |
Storage | Samsung 850 Pro 256GB SSD, Samsung 860 Evo 500GB SSD |
Display(s) | Samsung S24E650BW LED x 2 |
Case | Fractal Design Define R4 |
Power Supply | EVGA Supernova 550W G2 Gold |
Mouse | Logitech M190 |
Keyboard | Microsoft Wireless Comfort 5050 |
Software | W10 Pro 64-bit |
They should sound flat ?, no they should sound as intended as who ever made it
Yeah, see that makes no sense either - at least for your speakers. While speakers don't present a constant load on amps, they typically are rated with just one impedance value, normally 8Ω or 4Ω. Not 4 - 16Ω.my speakers say 4-16
Case | Rosewill |
Software | Win 10 |
Ehh Mr bill since you are here can you help me with one more thing i was talking about ohms
in my case my speakers say 4-16
so if the reciever says
4-16 ohms
8-16 ohms
means my speakers wont be good for that input of the reciever
or just the reciever will feed them more (sound-power) and damage them?
or in general what impact ohms have at my speakers or my listening
thank you >:I
Cooling | D15 |
You ignored my next two sentences.
I said, "That is, they should not introduce any enhancements on their own. They should just amplify what is inputted to them.". That can only happen if they have a flat, undistorted output. Now where the big differences come in is with the electromechanical part of the equation - the speakers, and environment (room) they are played in. But again, the electronics should be flat and only altered (with a frequency equalizer) to compensate for speaker deficiencies and room acoustics.
And FTR, while I own and like Onkyo. I am no fanboy for them. As I noted, I will probably look first at Denon when I buy again. And my very first real high end stereo system consisted of a dual monoblock Marantz power amp powered by a Dynaco PAT-4a preamp which I built!And they were used to drive a beautiful (sound wise) set of Acoustic Research AR-3a speaker systems - which I still have and hopefully will restore this year.
I have also owned an stereo Harman Kardon receiver back in the day which I really liked. My first 5.1 system was a Yamaha but it did not support HDMI. My current Onkyo does support HDMI.
One thing I really like about my Onkyo is the speaker calibration feature, Audyssey EQ. The receiver comes with a calibrated microphone you place where your head will be when listening. Start the process and the program calibrates the frequency response and output levels for each of the 6 or 8 (5.1 or 7.1) connected speakers. I have a nice SPL (sound pressure meter) I used for other sound system setups and I was surprised how accurate the Onkyo calibration was. It very effectively compensated for my living room which has heavy curtains on one side and opens into the dining room on the other. And the right rear is a solid wall while the left rear opens to a hallway. It really balanced the sound with the press of one button on the remote. Nice. I assume some of the better offerings from other makers offer a similar feature - but I will sure ensure the next receiver I buy does too.
For sure, Athens, as a big metropolitan city, will have high-end audio stores that sell better quality home entertainment electronics with trained people who can really tell you what's available.
Mr asrock can i ask...
what if i get a system like this...
throw the speakers that is has or use them somewhere else and use that...
im jumping into hifi systems now
If the amp is designed to operate at 4Ω, it should not affect quality. In fact, because current will increase, there will actually be more wattage available which may actually help quality, at least in the low end. But that depends on the efficiency of the speakers more than anything else.I do believe that it may affect sound quality to some degree, but not much.
Case | Rosewill |
Software | Win 10 |
Motherboard | AsRock X670E Phantom Gaming Lightning |
Cooling | Be Quiet! Dark Rock 4 |
Memory | G.SKILL Trident Z5 Neo DDR5-6000 32GB (2 x 16GB) |
Video Card(s) | Sapphire Radeon RX 7900 XTX |
Storage | Samsung 980 PRO Series 1TB, Samsung 980 PRO Series 1TB, Crucial P3 NVMe M.2 2TB |
Display(s) | LG OLED55G2PUA |
Case | Lian Li O11 Dynamic XL ROG Certified |
Audio Device(s) | Digital out to high end dac and amps. |
Power Supply | EVGA GQ 1000W |
Mouse | Logitech G600 |
Keyboard | Logitech G413 Carbon |
VR HMD | Oculus Rift CV1, Oculus Rift S, Quest 2, Quest 3 |
Software | Windows 10 Pro |
You can get some near \ top models with 300$, well i can here if you don't need the blutooth and HDMI for sure. I don't know the pricing were you are, you know some of the models to look for and it's about find and research.
Like if i had the money my self i be bidding on this Rotel 1056, well if i did not require HDMI that is. But you need one that's usable in your country so you can just plug it in.
System Name | Firebird |
Processor | Intel i7 2600K @5.0'ish 24/7 stock core Voltage {5.2 w/102 bCLK} |
Motherboard | Intel Extreme DZ68BC SkullTrail Z68 Cougerpoint, Excellent MCH ! |
Cooling | Scythe NINJA PLUS Rev.B[skt478] Modded to 1155 Scythe SH12 fan |
Memory | Samsung 32nm 16Gb 4x4 (@19xxmhz} low profile[ better than 2133 banwidth] |
Video Card(s) | Gigabyte Aurosus 1080Ti |
Storage | Intel 512 SSD,Samsung 9701Tb, Toshiba 3Tbx2,Hitachi 320,1TBx2,'Cuda 400 7200.10, WD1TBUSB,to SATA |
Display(s) | Acer K272HUL 1440 27" WQHD, Samsung 226W, Vizio M60C3 4K 60",Vizio XVT3D554SV |
Case | CoolerMaster HAF 932 |
Audio Device(s) | Intel 10ch[9+1] HD Audio X540> Pioneer VSX39TX[copper chasis,Rosewood sides 5x6LCD remote |
Power Supply | Seasonic X750 @ 24/7 |
Mouse | Logictech G300s |
Keyboard | Saitek Cyborg v7 |
Software | Windows 7 ROG E3 X64 by Neuropass/tweakscene |
Benchmark Scores | 4642@665/1600 220/GAT F1 4544 220/667strap 2.5/3/2/6 Bliss 650/1500 6490 Q6700 Bliss 690/1500 |
Very true as I experimentedIf the amp is designed to operate at 4Ω, it should not affect quality. In fact, because current will increase, there will actually be more wattage available which may actually help quality, at least in the low end. But that depends on the efficiency of the speakers more than anything else.
