Would a aftermarket cooler keep your room cooler or not? *poll*
  • Total voters
    139
Mussels
Freshwater Moderator
58,413 (8.18/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
If an aftermarket cooler reduces the CPU's temp compared to a stock cooler, then it stands to reason the increase in room temperatures will also be lower.
I certainly feel the difference if my system is running at 80C or 65C.
i forgot to specifically reply to this part:
The way you describe that has two interpretations and i really want to clarify this with precision:
1. Your CPU load goes up so the heat goes up - this WILL make the room hotter
2. CPU temp goes up because of any other reason (dust in heatsink, fan slows down, etc) - can not make room hotter.
I feel like people confuse those two situations a lot, and/or think they're the same.
8,944 (3.35/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
In practical terms it's the amount of heat that is being exhausted is what makes the difference not the cooling itself, in other words if you have plenty case fans and the hot air is pushed out of the case very quickly it will increase the room temperature faster than compared to a scenario where you have little airflow in your case and most of the heat will remain trapped inside it.
In absolute terms the same amount of heat will be dumped in your room regardless of the scenario because of physics , but since it happens more slowly it's less noticeable and not as much of an issue.
372 (0.06/day)
Where the beer is good
System Name Karl Arsch v. u. z. Abgewischt
Processor i5 3770K @5GHz delided
Motherboard ASRock Z77 Professional
Cooling Arctic Liquid Freezer 240
Memory 4x 4GB 1866 MHz DDR3
Video Card(s) GTX 970
Storage Samsung 830 - 512GB; 2x 2TB WD Blue
Display(s) Samsung T240 1920x1200
Case Bitfenix Shinobie XL
Power Supply Cougar G600
Mouse Logitech G500
Keyboard CMStorm Ultimate QuickFire (CherryMX Brown)
Software Win7 Pro 64bit
Thermodynamics 101. If you plug an air conditioner into the wall in a sealed room, will it cool it down?
Sealed room, no exhaust. How could you measure the temperature change?
"Sealed" for my also implies no energy via an outlet. The moment the AC kicks in it get's even warmer because the AC is working but has no way to exaust. And that working AC is generating heat itself.
839 (0.26/day)
Romania
System Name Comet Lake
Processor Intel® Core™ i5-10600K CPU @ 5.0GHz
Cooling Arctic Freezer 34 eSports Duo
Memory CORSAIR LPX 32GB DDR4 3200 CL16 B-die
Video Card(s) GeForce® RTX 3060Ti™
Storage Samsung 970 Evo Plus M2 1TB & Seagate 2TB ST2000DM008-2UB102
Display(s) Dell 24 Gaming Monitor - S2422HG 165 Hz Curved
Case AQIRYS Arcturus
Audio Device(s) Realtek® ALC1200 Codec | Logitech Z533
Power Supply RMx White Series™ RM750x
Mouse Genesis Krypton 770
Keyboard Logitech G910
VR HMD N/A Skip
Software W10 Pro x64
Benchmark Scores XXX
If case is well ventilated it will make a sense...u will feel cool air to your feet and coming from pc
Mussels
58,413 (8.18/day)
Oystralia
... i am truly stunned how many people dont understand this. is there a simple youtube video or something we should be sharing on facebook lots "YOU WONT BELIEVE WHAT HAPPENS NEXT?"
20,789 (3.41/day)
System Name Pioneer
Processor Ryzen R9 7950X
Case Thermaltake Core X31
Software Gentoo Linux x64
I am too. Then again, I was a bitcoin miner. If I didn't have a good grasp of thermal dynamics, my house would've burned down years ago.
The way some people write here, they seem to think their pc can become an exaustless air conditioner.
Mussels
58,413 (8.18/day)
Oystralia
5,731 (1.12/day)
West Midlands. UK.
System Name Ryzen Reynolds
Cooling Raijintek Leto Pro
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
Regardless of what hsf youhave the processor is still creating/outputting the same amount of heat, the only difference is how efficient said heatsink is at drawing that heat away from the processor, so it won't make a difference to the room temp using one from the other hence 90℅ of the poll choosing same...
1,025 (0.36/day)
Croatistan
System Name 1.21 gigawatts!
Processor Intel Core i7 6700K
Motherboard MSI Z170A Krait Gaming 3X
Cooling Be Quiet! Shadow Rock Slim with Arctic MX-4
Memory 16GB G.Skill Ripjaws V DDR4 3000 MHz
Video Card(s) Palit GTX 1080 Game Rock
Storage Mushkin Triactor 240GB + Toshiba X300 4TB + Team L3 EVO 480GB
Display(s) Philips 237E7QDSB/00 23" FHD AH-IPS
Case Aerocool Aero-1000 white + 4 Arctic F12 PWM Rev.2 fans
Audio Device(s) Onboard Audio Boost 3 with Nahimic Audio Enhancer
Power Supply FSP Hydro G 650W
Mouse Cougar 700M eSports white
Keyboard E-Blue Cobra II
Software Windows 8.1 Pro x64
Benchmark Scores Cinebench R15: 948 (stock) / 1044 (4,7 GHz) FarCry 5 1080p Ultra: min 100, avg 116, max 133 FPS
There would be no difference. Processor will generate the same ammount of heat which will have to "escape" somwehere; meaning that cooler will "consume" that heat and fans will blow it out of the case. It doesn't matter whether it's water cooling or air cooling...
719 (0.15/day)
coventry UK
System Name Gwafwar
Processor Ryzen 5 3600
Motherboard Msi MPG X570 Gaming Plus
Memory 16Gb Adata Spectrix 3600 Cl18
Video Card(s) Palit GTX970 SLI
Storage Adata 512Gb SX8200 pro
Display(s) 3x 27" 1080p Lg's
Case Coolermaster 690 II pure black
Power Supply Coolermaster 750W Masterwatt
Mouse Saitek X65-f HOTAS
Software Win10 Pro
The same amount of energy is transferred.
Here is the problem.
The Stock heatsink runs at 90C. The After-market one 45C with more airflow as well.
So If you are near the PC the 90C + lower airflow will affect more of the air near you.
The after-market one will draw more air and only heat that air to 45C. So the same energy is spread into a greater volume of air, So the perceived temp change near to the PC will be smaller.
8,122 (2.27/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
Ima guess half didnt read or comprehend your explanation. Yep some pure LOL.
6,270 (0.94/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
Most already know this but a PC room may also need to be set up in the same way you would set up your PC cases! Inlets and out lets ( For the PC room ), normally the closer you set up the inlets and outlets for the room to the PC or PC's the better it is able to transfer any new heat the PC is creating. Same holds true on PC rooms hot air is rising and cold air is being pushed down..... So go GET ER DONE. :toast:
silentbogo
5,475 (1.44/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 3800X
Memory 4x8GB Samsung DDR4 ECC UDIMM
Video Card(s) Inno3D RTX 3070 Ti iChill
Storage ADATA Legend 2TB + ADATA SX8200 Pro 1TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Software Windows 11, Ubuntu 20.04 LTS
I think the only time I noticed something that OP debate is about, was about 9-10 years ago.
We rented an apartment, and I've decided to take a walk-in closet and make it into my mini-office.
It did not have windows or AC, but heating was there.
I ran my first quad-core Phenom rig with a moderate overclock (on an old M2N SLI Deluxe) and an HD2900XT. I also had a big-ass CNPS9900 LED with some additional fans inside the case, so my rig was not only hot, it was also loud and bright.
Overall the temperature never dropped below 35C in that room during gaming sessions.
The total area was somewhere in the ballpark of 6 sq. m.
Normal people with normal rigs should not worry about this problem.
40,435 (6.58/day)
just run an AC unit.
Solaris17
Super Dainty Moderator
25,899 (3.79/day)
Alabama
System Name Rocinante
Processor I9 14900KS
Motherboard EVGA z690 Dark KINGPIN (modded BIOS)
Cooling EK-AIO Elite 360 D-RGB
Memory 64GB Gskill Trident Z5 DDR5 6000 @6400
Storage 1x 500GB 980 Pro | 1x 1TB 980 Pro | 1x 8TB Corsair MP400
Display(s) Odyssey OLED G9 G95SC
Case Lian Li o11 Evo Dynamic White
Audio Device(s) Moondrop S8's on Schiit Hel 2e
Power Supply Bequiet! Power Pro 12 1500w
Keyboard Monsgeek M3 Lavender, Akko Crystal Blues
VR HMD Quest 3
the air temp should be ever so slightly higher.
No because you cant create more heat than is being created via the object.
The room temp would be the same.
I dont have time to draw something up maybe someone else will but lets put it like this.
everyone knows heat dissipation is measured in watts right? Lets just use that we wont go deep into thermal dynamics. We will keep it exclusive to PCs.
Lets say you have a CPU that is bleeding 200w.
Now dissipation is helped by coolers but not all the heat can be dissipated because then the CPU would be ambient right? Lets take a look.
You have a CPU dissipating 200W. With the computer running your room sits at 26C (78F).
Your cooler is capable of dissipating 150w of heat. Meaning your CPU is retaining 50W of heat.
Now we all know we dont live in space, so while the cooler cannot bleed 200W of heat the 50w of heat isnt staying with the CPU its just bleeding off the motherboard off the IHS etc etc.
now you buy a better cooler. This cooler can dissipate 180w of heat. Which means at the most your CPU is retaining 20w of heat and bleeding it off some other way.
Now since the CPU is retaining less heat the idle temp has now dropped. Which makes sense we went from 50 to 20w of retained heat.
However, 150 + 50 = 200w
Our new calculation is 180 + 20 = 200w
We changed how heat is dissipated but we are still dissipating the same 200w in total, the CPU did not generate any more or less heat. so our room stays at 26C (78F).
AsRock
TPU addict
18,876 (3.07/day)
UK\USA
Cooling D15
Audio Device(s) Yamaha RX-V677 \ Yamaha CX-830+Yamaha MX-630 Infinity RS4000\Paradigm P Studio 20, Blue Yeti
Hell yeah, i put best god dam cooler on my GPU toeject as much heat as possible now i can sit here in my shorts in winter
Not really!.
CAPSLOCKSTUCK
Spaced Out Lunar Tick
8,578 (2.10/day)
llaregguB...WALES
System Name Party On
Processor Xeon w 3520
Motherboard DFI Lanparty
Cooling Big tower thing
Memory 6 gb Ballistix Tracer
Video Card(s) HD 7970
Case a plank of wood
Audio Device(s) seperate amp and 6 big speakers
Mouse cheap
Keyboard under going restoration
Im just going to find a 6 year old and ask them.
110 (0.03/day)
Charleston, SC
System Name EchelonV
Processor AMD Ryzen 5 2600X
Motherboard Asus Prime X470-Pro
Cooling Corsair H115i
Memory G.Skill Flare X 2x8GB (F4-3200C16-8GFX)
Video Card(s) Sapphire Radeon 5700XT
Storage Intel 660P 2TB NVMe; 6xWD5000HHTZ RAID-0
Display(s) Dell U3415W
Case Corsair Carbide 678c
Audio Device(s) SteelSeries Siberia 800
Power Supply Corsair RM650X; CyberPower CP1500PFCLCD
Mouse SteelSeries Rival 100
Keyboard Cooler Master CK550
Software Windows 10 Professional 1903
Benchmark Scores Cinebench R15 3.9GHz = 1404
So many different answers... each one flawed in some way lol
407 (0.13/day)
UK
System Name it needs a name?
Processor Xeon E3-1241 v3 @3.5GHz- standard clock
Motherboard Asus Z97A 3.1
Cooling Bequiet! Dark Rock 3 CPU cooler, 2 x 140mm intake and 1 x 120mm exhaust PWM fans in the case
Memory 16 GB Crucial DDR3 1600MHz CL9 Ballistix Sport 2 x 8 GB
Video Card(s) Palit 980ti Super Jetscream
Storage Sandisk X110 256GB SSD, Sandisk Ultra II 960GB SSD, 640GB WD Blue, 12TB Ultrastar
Display(s) Acer XB270HU
Case Lian Li PC 7H
Audio Device(s) Focusrite Scarlett 6i6 USB interface
Power Supply Seasonic P660
Mouse cheapo logitech wireless
Keyboard some keyboard from the 90's
Software Win10pro 64bit
Thermodynamics. Ain't life a bitch?
Mussels
58,413 (8.18/day)
Oystralia
if your current understanding produces infinite heat or infinite cooling, rethink things.
110 (0.03/day)
Charleston, SC
We can all agree that a PC in a closed room will increase the ambient temperature of that room.
We can all agree that without the A/C system in your home, the ambient temperature of that room will continue to rise while the PC is powered on.
We can all agree that without a cooler, the CPU cannot efficiently dissipate it's heat into the air surrounding it. It will simply burn up.
We can all agree that it is then the sole job of the CPU cooler to exchange heat - hot processor exchanges with cold ambient air.
Why then can we not agree on what happens to the ambient air in the room? To me, it's quite simple. The more efficient the cooler, the warmer the room becomes. It's a simple heat exchanger thermo-101 problem. If the cooler didn't matter, then why not run the CPU without one?
That said, I still voted "same" simply because a couple watts here or there will not make a noticeable difference for all intents and purposes of this vote lol
Mussels
58,413 (8.18/day)
Oystralia
"The more efficient the cooler, the warmer the room becomes."
The more efficient the cooler, the quicker the room becomes warmer.
an example would be if your heatsink was at 100C when the PC was switched off - a 'terrible' cooler (because its off) - does that heat fail to get transferred? no, it just takes longer to reach the room. Still the same amount of heat, just gunna take a little longer to get out of the PC case.
at any point someone thinks trapping hot air in the case keeps the room colder, that will only work if the heat *never* leaves, which means your PC is going to overheat. throttle, and/or crash.
110 (0.03/day)
Charleston, SC
I agree 100% with 50% of your statement lol. The room will become warmer quicker. Since we aren't talking about saturating the room with heat to the point of equilibrium, then we've answered the OP's question. The more efficient the cooler, the quicker the room becomes warmer. Thus, at any given time interveral, the room is warmer with a better cooler than it would have been with a worse cooler.
edit
This is all assuming that the aftermarket cooler isn't a piece of crap that does a worse job than the factory unit lol
