X99 System Lag Spikes
4,520 (0.69/day)
Perth AU
Processor Intel Core i9 10980XE @ 4.7Ghz 1.2v
Motherboard ASUS Rampage VI Extreme Omega
Cooling EK-Velocity D-RGB, EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
Memory G.Skill Trident Z RGB F4-3000C14D 64GB
Video Card(s) Asus ROG Strix GeForce RTX 4090 OC WC
Storage M.2 990 Pro 1TB / 10TB WD RED Helium / 3x 860 2TB Evos
Display(s) Samsung Odyssey G7 28"
Case Corsair Obsidian 500D SE Modded
Power Supply Cooler Master V Series 1300W
I wonder if any one else running a X99 system can relate to this issue or is it one of my components? when my systems under heavy load or even when its loading after a reboot, it will lag spike were it will lock the desktop so no mouse movement and rain meter stalls, after a second it will resume like normal? any one have any idea what this could be is it normal or is it related to something else.
Ebo
778 (0.18/day)
Nykoebing Mors, Denmark
System Name the little fart
Processor AMD Ryzen 2600X
Motherboard MSI x470 gaming plus
Cooling Noctua NH-C14S
Memory 16 GB G.Skill Ripjaw 2400Mhz DDR 4
Video Card(s) Sapphire RX Vega 56 Pulse
Storage 1 Crucial MX100 512GB SSD,1 Crucial MX500 2TB SSD, 1 1,5TB WD Black Caviar, 1 4TB WD RED HD
Display(s) IIyama XUB2792QSU IPS 2560x1440
Case White Lian-Li PC-011 Dynamic
Audio Device(s) Asus Xonar SE pci-e card
Power Supply Thermaltake DPS G 1050 watt Digital PSU
Mouse Steelseries Sensei
Keyboard Corsair K70
Software windows 10 64 pro bit
Nope I cant recongnize that, my X99 system just runs.
49 (0.02/day)
Stockholm
Have tried to disable HPET?
4,520 (0.69/day)
Perth AU
I never got it on my old R5E ether from memory but i can't tell if its the CPU,Board or Memory as all of them have been changed out lol, I'm pretty sure its not the memory but can't rule it out.
No i haven't but it wasn't a issue before.
Guess i need to find what creates the issue so i can problem fix it.
Deleted member 50521
Now you mentioned this. Before my last X99 board went belly up it was showing signs of lagging from time to time in not so heavy system loads.
Can you elaborate on your system spec, as well as your overclocking? Specifically have you been overclocking your cache/ring?
cdawall
where the hell are my stars
27,683 (4.04/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
I haven't seen those issues on any of my half dozen or so X99 boxes. Those are anything from a 5820k to a 2683V4.
1,010 (0.22/day)
Belgrade, Serbia
Memory CMD16GX4M4A2666C15
Display(s) Samsung P2450H
Case Lian Li PC-O11 WXC
Mouse Logitech G900 / SS QCK
Keyboard Deck 87 Francium Pro
I didn't had that. My motherboard didn't listen me first 2-3 days, OC Issue with BSOD after any change in BIOS connected with CPU Clock or voltage, even downclock recognized in few situations in early days of X99 on different motherboards.
But I was patient and after that she become one of best mobo I ever had.
Probably bug with BIOS Chip fixed after ASUS BIOS Flashback.
10 EZ Update didn't change nothing except BIOS Number and model.
One Flashback with powered off fix everything.
Users who constantly push edges can't expect from any hardware to behave normal and do everything you set.
X99 is pretty nice platform for longer usage, despite to early DDR4 kits and optimization. I missed first bugs because I bought 5-6 months after launch.
Only reviews decide to spare enthusiasts from comparison between i7-6900K 4.3GHz vs i7-7820X 4.3GHz and i7-6950X 4.3GHz vs i9-7900X 4.3GHz...
That would be nice review for gaming and multi threaded applications and only valid comparison for user of X99.
When computer behave weird I used to first check motherboard, special if completely different weird problems happen one by one.
If you don't know what is problem you need to remove everything out and start with CPU, mobo, simple GPU and memory on default value.
First install system and check if everything is OK. Than you change one by one thing every 3-4 days. In mean time you use computer as normal, play games, look movies, etc...
OC first CPU, than memory manual, than timmings, between every change 3-4 days. If everything work than you can try XMP. Maybe something do that on different way, but I have time, I'm not impatient to system need to be pushed to the edges instantly.
I don't like to push system to the edges because for something like that I always need to have money to replace everything.
I like more to used space Intel or NVIDIA or AMD left to people OC. Every hardware is launched with some space... i7-5960X have
1000MHz free to be overclocked, Intel give you Turbo and you have few hundreds MHz over that, they planned that. But not 1500MHz even if good part of them could work like that.
Now with new generations OC is much lower because AMD surpised them and they didn't had other options than to push clock 500MHz more.
For Z chipset is not problem, for X chipset motherboards need new VRM. To be be honest and after Ivy Bridge they didn't left nothing special for Z chipset over Turbo. 300-400MHz maybe.
4,520 (0.69/day)
Perth AU
My specs are off to the side, and seems to do this when its even on stock settings, its the same type of lag you get when testing your memory speeds in AIDA64, but i get this issue loading some programs.
107 (0.03/day)
CT USA
I'm thinking if your O/C ing that may be the problem. My Asus sabortooth X99 and i7 5930K @ 4.4 Ghz runs fine.
4,520 (0.69/day)
Perth AU
Like i said i get the issue on stock speeds, my CPU can do 4.6 on 2.27v.
1,013 (0.14/day)
Processor 2500K @ 4.5GHz 1.28V
Motherboard ASUS P8P67 Deluxe
Cooling Corsair A70
Memory 8GB (2x4GB) Corsair Vengeance 1600 9-9-9-24 1T
Video Card(s) eVGA GTX 470
Storage Crucial m4 128GB + Seagate RAID 1 (1TB x 2)
Display(s) Dell 22" 1680x1050 nothing special
Case Antec 300
Power Supply PC Power & Cooling 750W
Software Windows 7 64bit Pro
Perhaps try running in safe mode and see if you get the same lags. Could at least help determine if it is a hardware or software issue.
1,610 (0.34/day)
Northamptonshire, UK
System Name Main / HTPC
Processor Ryzen 7 7800X3D / Ryzen 7 2700
Motherboard Aorus B650M Elite AX/ B450i Aorus Pro Wifi
Cooling Thermalright Phantom Spirit 120 EVO / Wraith Spire
Memory Corsair Vengeance 2x16 6000MHz CL30 / HyperX Predator 2x8GB 3200MHz
Video Card(s) MSI RTX 4080 Super Gaming X Slim / ARC A380
Storage WD Black SN770 1TB / Sabrent Rocket 256GB
Display(s) Aorus FO32U2P / 39" Panasonic HDTV
Case Asus AP201 / Cougar QBX
Audio Device(s) Denon AVR-X2800H / Realtek ALC1220
Power Supply Corsair RM1000e / BeQuiet SFX Power 2 450W
Mouse Logitech G903
Keyboard Drop Sense75 with WQ Studio Morandi's
VR HMD Rift S
Software Win 11 Pro 64Bit
Try running your RAM at the default JEDEC speeds and see if it improves at all.
4,520 (0.69/day)
Perth AU
System is already running at stock speed, just updated windows so will see how that goes.
107 (0.03/day)
CT USA
Yes, Windows update has done terrible things to me and my rigs in the past. Last creative update took my Asus sound card away. Had to load in another PCIe slot and also messed with my O/C.
1,909 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
@OP
You have had this system for a while? If so did it ever not lag, try another set of memory?
Can you borrow some off a friend? Also power off and unplug your system them reseat each stick.
I cant see your specs but are you using a HDD or SSD?
While powered off reseat all molex plugs. Try a full CMOS reset, then set default.
opojare
25 (0.01/day)
Was this happened continuously?
My pc (Z77) having this continuous lag spike in last few days. System not responding/locked for every +- 5 seconds. Reboot will fix it only to happen again when there is heavy load.
Sometimes the whole system just freeze nothing i could do except unplug the power :(
Tried to scan OS, disk, memory, hardware inspection. It's all okay.
I said screw this and load my last month system image.
Now it's all running smooth again :rockout:
Still don't know whats wrong though :D
6,881 (1.42/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
I bet your using a beta of rainmeter. I'm guessing that its the issue. Have you tested not using it for a bit ?
4,520 (0.69/day)
Perth AU
I do run rainmeter but its not the beta version its 4.0, i have another RVE10 i just got back from RMA should i swap the boards out, i can't remember the lag on my old RVE but it could of been there who knows.
Should running these AIDA64 benchmarks lag your system or not?
6,881 (1.42/day)
Florida
Storage Various
Swap them and see how system acts.
Aida64 benches will lag system for a few seconds it even tells you not to move the mouse.
4,520 (0.69/day)
Perth AU
Its a few hour job to swap boards, i don't really want to do it then find out it wasn't the board lol.
6,881 (1.42/day)
Florida
Storage Various
I just thought maybe your Samsung 950 Pro NVME is overheating under stress and causing this.
aim a spare fan at it perhaps
7,607 (1.44/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
Did you try toss out the Xonar?
4,520 (0.69/day)
Perth AU
I've had the 950 since it come out and its always been behind a fan.
Yeah i took that out some time ago man.
6,881 (1.42/day)
Florida
Storage Various
7,607 (1.44/day)
Rīga, Latvia
Software FEDORA 41
Any other thing that comes to my mind would be SATA related. Tried only with NVME drive, disabling RAID and WD disk? Next issues come with USB3. And yes it has Asmedia, on my previous board putting Asmedia lastest ar*e driver put system to stall. It happens on Asus boards only btw. Try cutting them off.
