XFX Amd Radeon VII, No Display, vBios flash doesn't work and Code 43...
Status
Not open for further replies.
mlladen996
12 (0.01/day)
Hi guys, this is my first thread here. I could not find anything that is connected to my problem.
I bought a used XFX AMD Radeon VII, installed it but the display didn't turn on even though the pc did.
Flashed the vBios with success, installed the old driver, tried DDU-ing, re-installing windows 10 but it still wont post an image and it gives the Code 43 in the device manager.
Is there any way i can maybe fix it? To send it to someone to fix it?
8,246 (2.09/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
which BIOS did you flash it with? where did you get it?
44,274 (6.80/day)
What are your complete system specs?
I need the white sticker info from the back of the card please
Close up of the stickers please
This guy does gpu repairs
Or this guy
mlladen996
12 (0.01/day)
MB: Asrock Z370 pro4
CPU: Intel i7-8700
RAM: Patriot Viper 3000mhz cl16 2×16GB
PSU: EVGA 500W 80+ bronze ( i know its low for radeon vii, but i tested the card with my friends 1200W 80+ psu)
SSD: Samsung 970 evo 250gb
44,274 (6.80/day)
Yeah 1200 and 500 are way different, when you had tested the card with 1200 psu was it in your friends rig?
mlladen996
12 (0.01/day)
Yes i know, it was in his system. And it was the same outcome.
And do you think that those videos about the rx480 and eli's videos are aplicable to my radeon vii ? Because if that is the case i might try it with my uncle considering he has all of the equipment for it. It would just require us to shop for parts.
44,274 (6.80/day)
Its a matter of troubleshooting.
First thing pull all gpu drivers, update motherboard chipset drivers, pull the gpu from the system, clean the pcie slot carefully with a duster, clean the gpu pins using electronic grade contact cleaner or 70+% isopropyl alcohol.
Update the motherboard bios too.
Fully and squarely insert gpu, try different monitor cable, have 2 separate power supply 8pin pcie connectors going to the gpu.
Get this tool and download 1 of several files above.
Follow my F7GOS Easy AMD Flash video link in my signature.
Other option
You may need to do a force flash in an administrator privileged command prompt. (Find cmd in start menu right click and open as administrator)
If that is not performed you may receive the stupid 0FL error.
Then follow this command
Enter this command first
Amdvbflash.exe -unlockrom 0
Then enter this command
amdvbflash -f -p 0 XXXX .rom
Note: XXXX is the name of the VBIOS file you downloaded. You can also change the downloaded file name to a simple name.
Otherwise you do it this way:
Create a new text file in your ATIFlash directory, name it FLASH.bat, and place this code into it:
@Echo off
cls
echo Flashing card 0 with BIOS.rom...
echo.
amdvbflash -p 0 -f BIOS.rom
echo.
pause
Assuming the new BIOS you want to flash onto your card is named BIOS.rom, this is the BIOS it will use for flashing.
Save your changes, then run the batch file by double-clicking on it.
Once you've received a success message, reboot your computer for the new BIOS to come into effect. If you can boot into Windows successfully, then that's good! (Note: your screen may flicker for a bit, because you basically have a new card, and Windows is trying to recognize it. If you want to be thorough, go ahead and do a clean re-install of your graphics drivers.)
mlladen996
12 (0.01/day)
Well i have tried all of the above, i DDU-ed all graphics drivers, updated my MB bios a month ago to the newest version, cleaned the pins and the slots. I don't believe its any of those things because i have my GTX 1050 ti working just fine and displaying the image. I even tried to flash the bios through win flash, and also through command prompt. At this point i really do believe it is hardware related, as i said the flash worked and the older driver installed just fine.
44,274 (6.80/day)
Try the 2 above from youtube.
Sounds like card may have had abuse to it.
mlladen996
12 (0.01/day)
Yes, i think i will try to contact eli. After reading some more,i think it is probably related to power delivery on the card, which i think i might be able to fix with some help. But thank you for the advice and tips. :)
trickson
OH, I have such a headache
7,595 (1.02/day)
Planet Earth.
System Name Ryzen TUF.
Processor AMD Ryzen7 3700X
Motherboard Asus TUF X570 Gaming Plus
Cooling Noctua
Memory Gskill RipJaws 3466MHz
Video Card(s) Asus TUF 1650 Super Clocked.
Storage CB 1T M.2 Drive.
Display(s) 73" Soney 4K.
Case Antech LanAir Pro.
Audio Device(s) Denon AVR-S750H
Power Supply Corsair TX750
Mouse Optical
Keyboard K120 Logitech
Software Windows 10 64 bit Home OEM
I just want to ask one question here , Why on EARTH do you people feel the need to flash the video cards bios? It NEVER ends well and the gains are just NOT worth it. IMHO.
I would say flash it back or buy a new card.
44,274 (6.80/day)
There is only 1 sku and universal bios for the VII, there are no others, his card was messed up from the beginning.
If you follow what I do I help users restore cards that have been bricked/mined with
trickson
7,595 (1.02/day)
Planet Earth.
Cooling Noctua
Mouse Optical
No I saw that where his card was messed from the gate, But then at that point I would try to RMA the thing for sure.
44,274 (6.80/day)
He bought it used.
He may Try to message @XFXSupport for help on that if possible
mlladen996
12 (0.01/day)
I bought it used from an auction site in serbia. I do not have te abillity to RMA it, if i did i would of done it.
Durvelle27
6,823 (1.46/day)
Memphis, TN
System Name Black Prometheus
Processor Ryzen 7 3700X
Cooling Thermalright PA120 SE
Display(s) ACER AOPEN 34" 3440x1440 144Hz
Power Supply EVGA 600W
Mouse Logitech Trackman
Keyboard Logitech K350
Software Windows 10 EDU x64
Just my 2 cents
Alright so you went through the steps outlined by @eidairaman1, was that using the GTx 1050 as the primary GPU and did you correctly select the secondary GPU in ATIFlash
Also if using the GTX 1050 while trying to flash the VII you maybe exceeding the capabilities of the PSU as well being only 500W
Try to using your friends 1200W PSU and go through the outlined specs again
mlladen996
12 (0.01/day)
Well the 1050 Ti is my card that is used for 3 years. I know that everything in the system works as intended with it. With that said, i flashed the bios with the display connected to the i7s onboard gpu. And i did uninstall the drivers for the onboard gpu, as well as the Nvidia drivers, stoped the updates, and disconnected the network cable. And it said that the flash was successful.
44,274 (6.80/day)
mlladen996
12 (0.01/day)
@XFXSupport
Hello, thank you for checking out the thread.
Do you have any idea what could have caused these problems i am facing, and if so do you know how can i resolve them?
22,182 (3.43/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
Not at this time. We will be looking into it. Thank you
Can I just state as a member and recent buyer of one of your Radeon 5700 XTs that your forum presence greatly improved my image of your brand?
It's good to know local forum help is here, should I need it. That being said... used auction in Serbia... not sure what your policies say on that, heh.
Good luck OP. I wish you the best regardless.
iosengineer
3 (0.00/day)
Hi all,
Interestingly, I have the exact same issue with my XFX Radeon VII. I'm very lucky to say that I bought mine new from Amazon during their pre-Christmas sale ($499, super happy with the card). I've babied the thing, and absolutely did NOT flash it -- as others have mentioned, there is no point in flashing a Radeon VII anyway.
This card is a marvel of technology, although being re-binned compute silicon, there are probably some risks of hardware issues.
@XFXSupport I want to second the comment that your presence on this forum is a fantastic investment in the community. Whether or not you're able to help each user who reaches out, the fact that you've invested a real person (or few) to monitor the account is truly commendable. In my case, I'm now considering an RMA for the card and am wondering if you have any other advice.
Things I've tried:
  • Card was working without issue for a couple weeks. The failure happened after I left the machine turned off for several days (it was switched off from power physically).
  • Behavior in different machines:
    • Intel systems (tried both a Xeon E-2288g / C246 and an i7-4790K / Z87): Recognized as a Radeon VII under both Windows / GPU-Z and Linux (Ubuntu). Neither OS can flash the card. Card shows up as "No vBIOS".
    • AMD Threadripper 3960X: System refuses to POST with code 97 on a Gigabyte board (this is one of the later stages of PCIe initialization). This issue applies using multiple different slots.
  • Specific details on relevant steps:
    • Gentle but detailed cleaning of contacts with 99% IPA. Duster can on the PCIe slots. Other cards work perfectly in the slots.
    • Using strong power supplies. Titanium 750W Seasonic Prime, Corsair 1000W (also a Titanium model), and even tried a Rosewill Gold 750W.
    • Completely reset the system BIOS on each machine (CMOS clear). Running latest OS / kernel versions in every case. Latest AMD driver clean-installed after DDU.
    • In using atiflash, I did use the -unlockbios option (card number 1 in my case, running on a 5700XT while trying to do this). Also used -f -p when flashing. In every case, I get
      • Failed to read ROM
        ERROR: 0FL01
Feel free to ask more questions if I left out some relevant details. I love this card - it's something greater than just its performance, which is a worthy replacement daily-driver for my RTX 2080. I want to revive it, and would be very sad if it got junked after an RMA! (Although I'm pretty sure XFX could fix it, still, the thought alone is painful lol).
Status
