*UPDATE*
Bonehead Alert! Bonehead Alert!
One MAJOR screw-up was the fact that I didn't check the contact between the CPU and the block. There was about 1/4" of contact along the right edge and that was it! Come to find that the reason for the bad contact was the copper block was resting on one of the aluminum caps around the socket! Double
I haven't had a chance to reseat and check because I'm at work now. Looks like my layout is about to change a little since the block has be be aligned vertically now.
I spent the good part of this afternoon with my bottle of lab-grade acetone and a bazillion q-tips cleaning up my video card. Think I discovered a couple chunks of Arctic Silver adhesive (that I had mixed 50/50 with AS5 for the ramsinks) that had wedged themselves under the ram chips and up against capacitors on the card.
@ Wile E & intel igent,
Yes, these new DD blocks are a sight to behold. I don't think there is room for another nozzle (ala RBX, did you mean?). They refer to the CPU block as the MC-TDX (MC for multi-core) though I'm not sure I'm clear on how these are "optimised" for multi-core. The chipset is the new design applied to the 975 Maze4. The thing I like most about them is the non-tarnishing finish they have applied. Man, my Tyee block develops tarnish if I even look at it!
Does anyone know if the CPU block touching a cap would actually short something to the point of it not booting? I mean, I know it can't be a positive thing!
I am going to take the advice of having my ram cooling plugged into the CPU header
when I put it back together.
(Boy, am I glad I pre-ordered Crysis and picked it up the evening of the 15th! It's been sitting here, mocking me....constantly!)
Thanks again to everyone for their helpful suggestions and comments! Don't stop giving me ideas, cuz this probably won't work....
