- Nov 10, 2006
- 4,667 (0.68/day)
- Washington, US
System Name | Rainbow |
Processor | Intel Core i7 8700k |
Motherboard | MSI MPG Z390M GAMING EDGE AC |
Cooling | Corsair H115i, 2x Noctua NF-A14 industrialPPC-3000 PWM |
Memory | G. Skill TridentZ RGB 4x8GB (F4-3600C16Q-32GTZR) |
Video Card(s) | ZOTAC GeForce RTX 3090 Trinity |
Storage | 2x Samsung 950 Pro 256GB | 2xHGST Deskstar 4TB 7.2K |
Display(s) | Samsung C27HG70 |
Case | Xigmatek Aquila |
Power Supply | Seasonic 760W SS-760XP |
Mouse | Razer Deathadder 2013 |
Keyboard | Corsair Vengeance K95 |
Software | Windows 10 Pro |
Benchmark Scores | 4 trillion points in GmailMark, over 144 FPS 2K Facebook Scrolling (Extreme Quality preset) |
Flash successful on ati radeon x800gto, AGP enabled 16 pipes... But the darn thing isn't very overclockable especially with the stock fan even with additional fans blowing directly onto the card. Original clocks were 405 core, and 986 memory... max I can get to with stabe image is 430 core and 1080 memory. Guys, is it pointless to look into aftermarket cooling? I mean the temperature of the core at these settings while gaming is about 55 degrees celcius... Any one suggest some good cooling, thats not going to break the bank? One last thing what should I really expect from a system upgrade while keeping this card?
It depends what's failing.
If it's your GPU, there could be two reasons. One, the cooler you have now can't keep your GPU cool. Two, the clock is just too high for the quality of the core. If you can overclock your card higher for a few seconds before it crashes, then it's probably heat and an aftermarket cooler would help. If your card just dies the instant you apply the overclock, then it's the quality of the core and not much can be done.
If it's your memory, you'll probably just get a bunch of artifacts. You can try cooling, but I haven't found it to help too much.
Stock cooling is going to be somewhat loud. Buying an aftermarket cooler will almost always quiet your system. It will also help prolong the life of your card. In this sense, it might be worth it to buy a cooler.
