ShadowFlare
- Sep 20, 2005
- 542 (0.07/day)
Processor | Athlon 64 Venice 3200+ 2.0 GHz, max 2.6 GHz with Zalman CNPS7000B-AlCu |
Motherboard | EpoX 9NPA+Ultra nForce4 Ultra with Zalman ZM-NB47J |
Cooling | All Zalman heatsinks (CNPS7000B-AlCu, ZM-NB47J, VF700-Cu) |
Memory | 1 GB (2x512 MB) DDR400 Corsair XMS C2 series, max 233 MHz @ 2-3-2-9 1T |
Video Card(s) | Sapphire Radeon X800GTO2 256 MB PCIe max 540/600, modded to 16 pipes |
Storage | Seagate 80GB SATA, Maxtor 160GB PATA, Maxtor 200GB PATA |
Display(s) | Dell 17" Trinitron CRT |
Case | Lian Li PC-60B Plus |
Audio Device(s) | Built-in Realtek chip |
Power Supply | Enermax Noisetaker EG495AX-VE, 485 watts, active PFC |
Software | Windows XP Pro SP2, Windows XP Pro x64, Windows Vista RC1 32-bit |
Looking at the writing on the core is only one of the ways of determining what core a card has. For cards with R423, R430, or R480; there is another way of determining which it has. I posted this in the first post for the topic:infrared said:The only sure way to find out is the remove the cooler and look at the writing on the core, being careful to recycle as much thermal grease as possible.
I haven't seen any exceptions for that method so far. BTW, I didn't mention that if none of the conditions there are met and that the card does at least have one of the three PCI Express GPUs, that the card has R423, but that's kind of implied.Another way is to look at the fuses data in ATITool that shows up when you hold shift and click on settings. If it is R480 or R430 then CONFIG_DIE_FUSES will look like 0xFFFF?FFF and CONFIG_SUBSTRATE_FUSES will look like 0xFFFFFF9? where the "?" can be any digit. After you determine that it is R480 or R430, to distinguish between the two you can check how high the GPU can be safely overclocked. Many (or most) R430 chips cannot reach 450 MHz and all (as far as I know) cannot reach 470 or above. If your's exceeds what the R430 is capable of and matches the pattern above, then your card very likely has the R480 GPU.
