No Undervolting Options for Intel 10710U?
Drackyr
13 (0.01/day)
Been trying to install both XTU and Throttlestop, got the ''unsupported CPU'' error with both. My CPU is hitting the 80s while gaming, no bueno. The CPU is -conveniently- placed inside the chassis of a Prestige 14.
Any ideas? Thank you all in advance.
4,907 (1.48/day)
Processor Intel Core i7-13700 PL2 150W
Cooling Cooler Master RGB Tower cooler
Memory Crucial Pro DDR5-5600 32GB Kit OC 6600
Video Card(s) Gigabyte Radeon RX 9070 GAMING OC 16G
Storage 970 EVO NVMe 500GB, WD850N 2TB
Case Corsair iCUE 4000D RGB AIRFLOW
Audio Device(s) EVGA NU Audio, Edifier Bookshelf Speakers R1280
Power Supply TT TOUGHPOWER GF A3 Gold 1050W
Software Windows 11 Professional v24H2
Your issue might be related to this or not? I'm going to guess that Throttlestop doesn't recognize the CPUID.
@unclewebb
Drackyr
13 (0.01/day)
What? ... sigh.
Might be. I can't believe I'm not going to be able to undervolt the CPU. Mine is an MSI Prestige 14, but from the looks of it, who knows. I read XTU doesn't work with the U series, didn't think it'd be that bad though. This means I can't even use the BIOS in order to get it done.
4,907 (1.48/day)
What? ... sigh.
Unfortunately undervolting a Intel mobile CPU is dead after the SGX exploit aka Plundervolt.
  • Like
Reactions: ppn
4,907 (1.48/day)
Should be okay, it's under the thermal throttle limit (100°C) for the die.
Drackyr
13 (0.01/day)
I'm updating the thread with pics I took from the advanced bios, that I finally managed to access. Let's see if anyone can provide some insight as to what I'm looking at, and how to undervolt this. Thank you all in advance
4,907 (1.48/day)
@unclewebb, maybe you can help OP with the available BIOS options? I have no idea what the options are for voltage control.
unclewebb
8,347 (1.35/day)
I was looking for some updated documentation from Intel but they have not publicly released anything that covers these new CPUs. I will send an updated version of ThrottleStop to you later today. Without documentation, how it will work for you is anyone's guess.
44,267 (6.80/day)
Wow a non UEFI based laptop bios...
4,907 (1.48/day)
its-my-right
8 (0.00/day)
Hello, I have a MSI Prestige 15 with Intel 10710U and I am currently able to tweak this CPU with Throttlestop 8.70.6.
@unclewebb, what exactly the new version of Throttlestop you are talking about will do better for this cpu ?
If the support of this cpu is better, could you please send me that new version too ?
Thank you :)
unclewebb
8,347 (1.35/day)
That is odd because Drackyr told me that ThrottleStop did not work on his Core i7-10710U. I had a look at the ThrottleStop code and it looked like TS 8.70.6 should work on that CPU. Intel might not ever release a version of XTU that supports these processors but ThrottleStop works fine.
I sent Drackyr an updated version of ThrottleStop so I could get some feedback. He asked me several questions and I replied to all of them. Then I asked to see some screenshots but he never bothered to send me anything. After that he turned into a ghost and disappeared. Pretty sad when you go out of your way to help someone and they cannot be bothered to help you with development.
The new and improved version of ThrottleStop that I sent him should work exactly the same as ThrottleStop 8.70.6 that you are using. It is possible that the BCLK is reported incorrectly. Intel might have changed the frequency of one of the internal timers that I have been using. I think the multipliers are 100% accurate but without seeing any screenshots, hard to say what works and what needs fixing. Without access to hardware, I have no plans on trying to make ThrottleStop perfect. Too frustrating. Voltage control should work OK until Intel releases a microcode update to try and block this feature. I think Drackyr saw a huge drop in temps on this CPU but I am not sure if it was stable or not.
I will release an updated version of ThrottleStop, probably later today. Thanks for confirming that ThrottleStop really does work OK on the Core i7-10710U.
its-my-right
8 (0.00/day)
Hello,
Too bad you didn't get answers after being working on a specific version of the program for this need.
I can confirm, I am using Throttlestop on my i7 10710u to lower the voltage by 100mv, and I also blocked the multiplier on a fixed value (34) to keep acceptable temperatures on my special profile "encoding", and that works perfectly, the cpu is colder and it is stable.
However, I cannot use the "Limits" button (it is grayed out). But it may not have anything to do with the cpu, this is the first time I am using Throttlestop so maybe it is for another reason that the button is grayed out.
I can send you screenshots if you want, just tell me in which configuration you want them.
(Sorry for the google trading !)
unclewebb
8,347 (1.35/day)
No worries. That has already been fixed in the updated version. Thanks for the feedback.
Some time today or tomorrow, I will be working on adding a new iGPU feature for an unrelated CPU. When that is done, I will post a download link in this forum. Just post a screenshot of the new version when it is done so other users that end up in this forum will be able to see that ThrottleStop really does work on the Core i7-10710U.
its-my-right
8 (0.00/day)
Ok, I will do that ;)
Edit : Added a screenshot from 8.70.6
Drackyr
13 (0.01/day)
I dropped this case eversince I got the parameters set, the temps lowered - and still got throttled. Sorry, I used to have patience with tech devices and now I seem to have lost it.
The monitoring works well as the snaps indicate. It's just quite -not going to curse- useless, you could very well be ingame and all of a sudden the framerates fall by 70%. Couldn't get Riva to monitor ingame, so I'm walking blind.
And that's pretty much it, thank you a bunch unclewebb for your efforts, at this point in my life I'm just so -I'm still not going to curse- over wrestling with -almost there- W10 devices just to get them to do what they're supposed to.
I'll try to reset the BIOS to factory defaults, I might have touched something at some point.
tl;dr: unclewebb's fix works; I might have screwed up by messing with the bios.
If you own a 10th gen U processor and are experiencing throttling / "incompatible CPU ERROR" issues, you might be interested in contacting him.
its-my-right
8 (0.00/day)
Thank you for your feedback !
Still, I don't understand hy you had to use an updated version in order to be able to tweak the CPU becase unclewebb said "The new and improved version of ThrottleStop that I sent him should work exactly the same as ThrottleStop 8.70.6 that you are using.".
@unclewebb, do you have an idea when you will have time to release the new version you where talking about ? (I know it will be ready when it will be ready :D ).
Thank you !
Drackyr
13 (0.01/day)
Thank you !
I don't understand either, I swear by the nine divines. All I know is I'd get the "unsupported GPU" error from both XTU and THRSTP.
On a side note, using the "clock modulation" option by lowering it seems to be another useful tool. Leaving it at 93.75% eradicated all overheating. There seems to be much to learn from this program.
unclewebb
8,347 (1.35/day)
ThrottleStop 8.74
New Features
- enabled Limit Reasons access for Comet Lake Core i7-10710U.
- added IGPU INI file option to set and lock the iGPU power limit.
Guess what? It is ready. Always takes me a little longer when I do not have access to hardware.
This version unlocks the Limits button so you should have access to the Limit Reasons window. This will let you see why your CPU is throttling when stress testing.
@Drackyr - Did you try using the FIVR - Disable and Lock Turbo Power Limits option? That can make a big difference on some laptops, depending on what a manufacturer leaves unlocked.
When under volting the Intel GPU, you usually have to under volt the iGPU Unslice equally or else this part of your under volt will be ignored.
22,160 (3.43/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
You do know a rich GUI isn't required for UEFI?
Yep, it certainly is UEFI.
You could try turning on XTU support OP. It's listed in your screenshots.
unclewebb
8,347 (1.35/day)
The Advanced BIOS might have an option for Intel XTU but I do not think that XTU supports the 10th Gen CPUs with their 15 Watt TDP rating.
XTU is only supported on Desktop, High End Mobile, and High End Desktop (HEDT) platforms. XTU is not supported on server, Celeron®, or Intel Atom® Processors.
Drackyr
13 (0.01/day)
ThrottleStop 8.74
New Features
I'll try it, although I should state that I do make use of the laptop's juice. I'm not sure of whether disabling the turbo will further maim its performance.
