System Name | Dell Inspiron 7375 |
Processor | AMD Ryzen™ 7 2700U Mobile Processor with Radeon™ RX Vega 10 Graphics |
Memory | 16GB (total) 2400MHz DDR4 SODIMM |
Video Card(s) | Radeon™ RX Vega 10 Graphics |
Storage | SanDisk X600 SATA SSD 512GB |
Display(s) | BOE NV13FHM |
Audio Device(s) | Realtek ALC3253 (Dell Labelling) ALC255 (Real name) |
Only has optical.Realtek direct Toslink compression and the decompression on the other side should be something like 40-60ms. As long as you dont use a creative soundblaster i think it might be ok.
By the way: Has your htib multichannel in?
Thanks for sharing buzzingbee.
Greate that you had a chance to test more avrs.
Everytime something gets converted (which affect 5.1 -> stereo or 192khz > ) produce latency - so two things seems to matter: get less things converted as possible, get things converted as fast as possible. As you said, the latter thing cant be known.
I am wondering how you exactly measured your results?
Hello, I was also interested with audio latency on AV receiver. I do not use AV receiver for main video connection, so video latency is not important for me. Throughout two years I've been gathering rough experiment results so I thought I would like to share here:
How'd you measure the delay?I feel bad, I get instant response, feels like 2ms or less, its faster than my internet @ 4ms, both on Realtek SPDIF, and GPU HDMI, even GPU HDMI to SPDIF.
I do know some some enhancers, spatial enhancers and even faulty settings either in the driver or registry, can cause audio delay.
Ah, I see, so in my case I'd probably have something like 45ms difference or so. If I use my onboard audio then I can get it to about 5-10ms difference, but I don't think I can feed that to my DAC, nor can I feed it to my TV.I cant say I really measure it, I do it based on screen and sound timings when a popup and sound alert play at the same time.
You see the popup, adding enough delay is then noticeable when the popup is in front of the sound.
I'll try that.No unfortunately, I can only recommend a different driver if there is that much of a difference, sorry.
Edit:
There is one thing you can try, and install E-APO, and set to pre-mix no post mix.
It can increase the response rate, see my post here to install it.
When I was building DTS DCH, at the start there was a lot of lag, E-APO fixed it.
It's not needed in that way now, only as a stereo upmixer.
Might work for you too.
Hold on, can you explain your setup in more detail? As far as I can tell, you've got a HDMI from your AMD GPU linked to your monitor/tv and you use the sound from your monitor/tv or do you have a line going from your monitor/tv to your sound system and that's how you use it?I Find SPDIF and HDMI is more responsive than analogue direct, I use my AMD GPU as my main sound device via HDMI extractor to SPDIF.
My Z906 doesn't have HDMI support, and SPDIF is always better than analogue direct, regardless of the programming.
With my extractor I can output 5.1 PCM to SPDIF, but my Z906 doesn't support more than 2 channel SPDIF PCM.
The strange part is, DTS Interactive is only 1.5mbps, and still sounds better than lossless analogue.
Is that the one that gives you low latency? What is this extractor you use?AMD GPU (HDMI) > Extractor > SPDIF > Z906 Receiver. SPDIF is what was before HDMI, its a digital interface.
Toslink vs Optical: What is The Difference? | Finddiffer.com (ignore the doesn't support lossless, it does)
Ah, I see, perhaps my problem then is my TV adding most of the latency, but hmm, I've got all sound enhancing stuff disabled.The HDMI portion passes through, here is the unit I have, ignore the typo 1GB its 18GB for video, HDMI audio is ~37mpbs, the older ARC is much lower.
I made my own driver for the unit, effectively overriding the EDID, I can send 5.1-7.1 down SPDIF, and also all formats.
You don't need an extractor to send lossless formats on SPDIF, just some settings in the media player.
That's possible, I have read ARC and eARC can be unstable, and you then require sync features. Never needed sync with Toslink, so, yes maybe its the TV.perhaps my problem then is my TV adding most of the latency
I have not no, I am not looking to upgrade my Z906 at this time, not unless I see proper SPDIF support, the current standard is 20-125mbps (modules).Have you dabbled in soundbars? Any recommendations or any of them that you know of that have low latency and good audio quality?
I have an eARC slot, that's my HDMI 2 slot, but I've got mine hooked up to my HDMI 1 slot as that's recommended for PC usage.That's possible, I have read ARC and eARC can be unstable, and you then require sync features. Never needed sync with Toslink, so, yes maybe its the TV.
