What are YOUR temps? (45nm+GPU)
shevanel
3,464 (0.60/day)
Leesburg, FL
I'm curious to know what people are using to cool their GPU and 45nm cpu and the temps they get from said hardware. If you feel so inclined to share with the world please post..
template for copy/paste
ambient:
45nm cpu:
Mobo:
Cooling:
Temps I/L:
Max temp using Intel Burn (optional):
GPU:
GPU cooling:
Gpu I/L:
ambient: 78f
45nm cpu: q9550 @ 3.825 1.35vcore
Mobo: evga 780i ftw
Cooling: apogee gt, black ice 240 radiator
Temps I/L: 33/48c
Max temp using Intel Burn (optional): 59c
GPU: bfg gtx 275 oc
GPU cooling: stock
Gpu I/L: 34/65c
That ambient is rediculously high! :eek:
yeah it sucks. I can sometimes manage 76f
My ambient is 65F and thats only during the summer. I keep my apartment really cool temps though. :D
ambient: 27 C
45nm cpu: QX 9650 (1.2V @3,33 GHz, 24/7)
Mobo: ASUS MAXIMUS FORMULA (Bitspower NB/SB waterblock)
Cooling: Enzotech LUNA wc rev.A
Temps I/L: 32 C / 41 C
Max temp using Intel Burn (optional):52 C
GPU1:Sapphire toxic (800/1000)
GPU cooling:EK Waterblocks EK-FC4870 CF VGA Waterblock (top card)
Gpu I/L: 33 / 41
GPU2:Sapphire toxic (800/1000)
GPU cooling:DANGER DEN GPU-6890 DD-4870 WATER BLOCK (bottom card)
Gpu I/L: 39 / 46
all waterblocks are cooled by 2x 240 rads, 1x 120 rad and 1x 360 rad....:p
all fans minimum, practically silent!:rockout:
ambient: 27 C
Gpu I/L: 33 / 41
Gpu I/L: 39 / 46
very nice!! thats a sweet PC!
yeah my roomate keeps the thermostat on 78... sometimes 77
ambient: 20C or so
45nm cpu: Xeon E3120 3.8Ghz 1.18v
Mobo: DFI x48
Cooling: TRUE 120 lapped
Temps I/L: ambient (45nm have shit idle sensors) load <50C
GPU: 2x 4870
GPU cooling: accelero S1's with fan
Gpu I/L: 40C/60C,. give or take
it seems weird you're asking this information mainly for idle and load of 45nm CPU's, when 45nm intels are known to have useless temp sensors at idle.
ambient: 25*c
45nm cpu: Core i7 920 @ 4.2
Mobo: Gigabyte UD4p
Cooling: Water, sig
Temps I/L: 60*c load
Max temp using Intel Burn (optional): 63*c
GPU: 4890
GPU cooling: water, sig
Gpu I/L: 29*c, 33*c
ambient: 28*c
45nm cpu: C2D 8400 @4GHz
Mobo: Dfi x48
Cooling:XIG 1283
Temps I/L: 68*c load
GPU: 4850 CROSSFIRE X
GPU cooling: 2*MUSASHI
Gpu I/L: 40/68-37-62
ambient: 18c approx
45nm cpu: Intel E5200 @3ghz
Mobo: Asus P5Q3
Cooling: Artic Freezer 7 pro
Temps I/L: ( core temp) 32c/46c
GPU: ATI HD 3850
GPU cooling: Akasa Neo
Gpu I/L:30c/42c
ambient: 23c
45nm cpu: Q9400
Mobo: Zotac Geforce 9300
Cooling: Cooler Master GeminII (passive)
Temps I/L: ( core temp) 39c/51c
GPU: Geforce 9300
GPU cooling: Stock tiny alu heatsink (passive)
Gpu I/L:63c/79c
those Dfi x48 boards are good for oc'n huh
Sure but you can get the same results with much less money rather easily. ;)
A nice P35/P45 can take an E8400 to 4Ghz and beyond easily. It matters much more what chip you choose really.
I noticed no 45nm AMDs listed yet...
How about these:
ambient: 28c
45nm cpu: AMD Phenom II 940 @ 3800Mhz/1.487v
Mobo: Asus M4A79 Deluxe
Cooling: CPU-Mugen II w/ 1900rpm Slipsteams Push/Pull
Temps I/L: Idle 34c, Load 49c
Max temp using OCCT (optional): 53c
GPU: 2 x Radeon HD4850
GPU cooling: 2 x Zalman VF1000
Gpu I/L: Idle 38c, Load 54c
Oh yeah here's another although not complete set of info.
ambient: 18c approx
45nm cpu: AMD 905e (stock settings)
Mobo: asus m4a79t deluxe
Cooling: Artic Freezer 64
Temps I/L: 21c
Can't remember load temps at stock settings, but at 3.375ghz load temps were 40c
my x48 was cheaper than a P45.
ambient: 22/23c avr.
45nm cpu:Q9450 (1,36c 3.8 max.) (3,2 1,25v 24/7)
Mobo:Gigabyte ga-x48-dq6
Cooling:Zalman 9700 led
Temps I/L: 25/ load 65/65/65/65c
Max temp using Intel Burn (optional):65/65/65/65c
GPU:Sapphire 4850
GPU cooling:Zalman vf1000
Gpu I/L: 33/55c
ambient: 80f
45nm cpu: Phenom II 940 @ 3.5 Ghz
Mobo: Asus M3A
Cooling: Thermaltake Big Typhoon VX
Temps I/L: 36c/50c
Max temp using Intel Burn (optional):50c
GPU: Sapphire radeon 4870 512mb
GPU cooling: Stock non-refference
Gpu I/L: 25c/80c
ambient: 60F (16C~)
45nm cpu: Phenom II x4 940 @ 3.6ghz
Mobo: Biostar 790gx
Cooling: Sunbeam Core Contact
Temps I/L: 35/50 C (95/112 F)
GPU: x2 HD 4870 512
GPU cooling: stock
Gpu I/L: 45-65C
ambient: 65F
45nm cpu: 90nm cpu AMD Opteron 170 @ 2.95 Ghz
Mobo: DFI LanParty LP UT nF4 Expert
Cooling: Thermaltake V1, shitload of fans.
Temps I/L: 39C/~50C
Max temp using Intel Burn (optional): 51C
GPU: PNY 8800GTS 320MB
GPU cooling: Zalman VF1000, ZM-RHS88, loads of fans
GPU I/L: ~39C/~50C
ambient: 78-79F (Tucson AZ, you pay my eletric bill I'll turn the AC temp down. :) )
45nm cpu: i7 920 @ 4.0GHz (1.05v idle, 1.31v (actual) full load) HT on, C1E on
Mobo: DFI LANParty UT X58-T3EH8
Cooling: Noctua NH-U12P with 86CFM Scythe 120x25, 125x38 push|pull
Temps I/L: 30-33C Idle - 79-81C Load (Linpack)
Max temp using Intel Burn (optional): 79-81C (bout same as Prime95)
GPU: XFX 4870X2
GPU cooling: Default - Fan at 40%
Gpu I/L: 40-45C Idle - 75-77C Load (Folding @ Home)
Keep in mind, I use a tech station so my temps are pretty good for being 78F
Picture of the setup:
Proof pic of temps:
ambient: 15-20c ....No ac or heating turned on
45nm cpu: Athlon II 240 3.6GHz 1.4v
Mobo: Asus M3A32-MVP Deluxe
Cooling: Lapped CPU and Xigmatek HDT-1283
Temps I/L: 27c/34c (Temp sensor bad? :confused:)
Mine too!
Bought dfi p45 t2rs plus 132 euros and dfi x48 t2rs 109:toast:(for free actually ,RMAed something:toast:)
Yap they OC well but not like the p45 i must admit...Hard from 500 and above but they have 32 pcix lanes so its worth it!
