- Dec 30, 2007
- 1,207 (0.19/day)
- Bitola, Macedonia
System Name | Brutus |
Processor | AMD Ryzen 5600X PBO |
Motherboard | Asus Prime X570-P |
Cooling | EKWB AIO 240MM Push-Pull fans |
Memory | Patriot Viper Steel DDR4 4000 32GB (4x8) @4066 CL16, Custom Timings |
Video Card(s) | MSI RTX 3080 SuprimX 10GB |
Storage | Kingston A2000 500GB + Toshiba 1TB HDD |
Display(s) | Samsung 24" S24D300 + 2x LG LED 24" |
Case | Cooler Master H500 |
Audio Device(s) | SB X-Fi Titanium Fatality Professional |
Power Supply | Sama Forza Modular 750W 80+ Gold |
Mouse | Cooler Master Master Keys Lite |
Keyboard | Cooler Master Master Keys Lite |
Software | Windows 10 Pro 64-Bit |
Right, buying new components :
Gigabyte EX-38 DS4
E8400
4GB of some RAM
Gigabyte 9800GTX.
Will my current one be ok? Check system specs for info, it has 24A on the 12V rail and only one 12V rail.
Or what about these:
http://www.giga-byte.com/Products/P...aspx?ProductID=2495&ProductName=ODIN Pro 550W
or
http://www.giga-byte.com/Products/P...aspx?ProductID=2493&ProductName=ODIN Pro 800W
or
http://www.giga-byte.com/Products/P...ec.aspx?ProductID=2793&ProductName=Superb 720
or
http://www.chieftec.com/super-power.html - the CFT-500-A12S and the CFT-620-A12S
And do not recommend me any others, cos this is the choice.
Gigabyte EX-38 DS4
E8400
4GB of some RAM
Gigabyte 9800GTX.
or
or
or
