Guide to Radeon X800/X850 bios modding
Hi There
Have any One have succes doing a Hardmod on the Lazer cut
on a R481chip? in order to enable the extra 4 Pipe?
Tks in advance
Keep up the great Work Dolf ...
:cool:
In principle it is not problem to succeed with R481, R420 or R423 but it is very important the configuration of the other bridges (they are 11) and only 2 of them are situated on the front side of the core ;) . Only in the beggining of the production of R420 it was possible because the "good" 16 pipe cores were scanty and for the X800PRO ATI have used 16 pipe R420s. But it was over and just in the end of the "live cycle" of the X800/X850 Series the ATI partners started to sale the remaining 16 pipe cores like 12 pipe cards :) . But some cores are just deffective and should be installed on lower class cards.
Hey Dolf,
I have a Saphire X800GTO, AGP, VIVO, Blue PCB. I have already unlocked
my extra 4 pipes via your "800pro auto-flash utility". Flashed to
800XT :). Card OC's to 560/600 rock solid thanks to the GREATNESS
of the Zalman vf900-cu and some AS Ceramique...44C fully loaded :)
heres the rub...
....go to flash to X800XT PE via same utility...gives me the clock
speeds but WITH ONLY 4 PIPES?!?!?!
no clue.. have yet to try another X800xtpe bios, thought i would
ask you first...:)
heres pertinent info....
CORE: (420?) .............................. MEMORY: 1.6
215RADCGA12F ............................. Samsung 504
GG3528-1 ................................... K4J55323QF-GC16
0502AA
Taiwan .....................................PCB:
Radeon X800 ................................109A26130-01
FUSES:
0xEFF7FFFF
0xFFFFFF9F
0x20
...I thought only the R480 core could reach 560...??
Thx so much already....wouldnt of made it this far..:)
oooops...forgot to mention, flashed back to X800XT 16 pipes. OC'd 560/600
You have to reinstall the drivers after flashing to XT PE and probably the ATITool. If you still have 4 pipes ??? post the fuse values just to see why. But probably it is software problem than something else.
Allright, very interesting topic.
A friend of mine has an XpertVision X800GTO with Samsung 1.4ns memory. It also shows "X850" on the core. My guess is that it is an R481, but AtiTool shows it as R420. The extra pipes are laserlocked, but the point at the moment is to get a nice overclock out of it.
I'm seeing people with 1.6ns memory reach the same result as this card with 1.4ns memory, shouldn't 1.4ns have some advantage over 1.6ns memory?
Stock clocks were 400/490, and it now runs at 530/630 with a Zalman VF-700 on it plus ramsinks. I looked at some of the timings that people with 1.6ns memory had, and they are exactly the same as the timings for this card with 1.4ns. I have been thinking about raising the MEM_TRP from 6 to 7, would this be useful or would it have a negative effect?
Any other comments or questions are also welcome.
hmm, didnt try reinstalling AtiTool. will clean drivers and AtiTool reflash and try again.
FUSES:
CONFIG_DIE_FUSES 0xEFF7FFFF
CONFIG_SUBSTRATE_FUSES 0xFFFFFF9F
CONFIG_ROM_FUSES 0x80420
GB_PIPE_SELECT 0x3FE4
...need to search for original bios disk.
but the card loves its new X800XT status and its 4 new shiney pipes..
thx
huh....software problem...who would of thought...you would. i guess thats why i asked.
reinstalling atiTool did the trick...
thanks again...your info has been invaluable.
one last question if i could??
did i just luck out??? i thought for sure...(well was told everywhere) that a R420 core could not reach 560..let alone this stable.... any thoughts??
thnx agn
thnx agn
Maybe you got lucky and you have AtiTool reading it as R420 core, but it actually is a R481 core. I have some pictures here also to proof it, your card might be the same:
http://picasaweb.google.nl/andersdoggen/X800GTOMod
I'm still waiting for someone to answer me about the question above though. But I'll look at this topic tomorrow again.
looking at those pics i am pretty sure i have an R420 core ...just a good one.
thanks for the link, nice to know the R481 cores hae an X850 still stamped on the core...hmmm unless someone knows otherwise ill just accept my R420 .....lovingly.
as to yours dont know timmings just yet ...but id say your 630 is exceptional if it were 1.6ns ....maybe its just not great oc 1.4.
thnx agn
Definitely you have R420 (the fuses tell that). And it is not strange because R420 has almost the same clocks rate like R481 (my X800XT reached 570MHz while my X850XT PE only 560MHz). Practicaly they are one and the same thing but the yield of R481 is much better. The problem with the R420 was too small number of good 16 pipes cores.
So would you have any tips for me Dolf? It looks like you know what you are talking about :toast:
Raise MEM_TRP for higher memory oc? Might try that but I don't want the card to crash or something...
TRP could help for 10% more overclock but also couldn't in some cases. It deppends on the memory chips. If you don't have problem with the memory speed just leave it as it is.
Allright, going to try to look for the maximum core speed soon. Wonder where I can get from 530/630 with R481 core. I think it's safe to say that it will at least reach 570 core?
I' m new here and have a question concerning my Palit/Xpert Vision R X850XT 256MB DDR3 DVI/TV AGP.
(http://www.xpertvision.de/v2/index.php?option=com_content&task=view&id=53&Itemid=67)
Is it possible to flash this Card to 850XT PE?
With ATI Tool I can set it to 570/585 MHz - without Problems, but there are a few
things i would like to know before doing this.
At the moment I'm not able to get information about the temperature of my GPU! Isn't there a sensor on this card or
is this option only disabled in my BIOS? (I'm thinking about installing an other fan.)
When opening BIOSfile with rabit 2.2.1 (created with ATI-Tool 0.26) I get the following message:
"Warning: BIOS CRC is incorrect!"
I tried to save it a few times but always with the same result.
When clicking "OK" I get information about my card but I'm not sure whether i can work with this file or not.
When comparing my BIOS with other Cards from different manufacturers I noticed two differences:
Memorytimings and the entry "Multimedia Table" is missing (Rabit-> Logging)
The memorychips of my card are labeled with:
Samsung 616
K4J55323QG BC14
ELCO57AE
If it is possible to enable temperature monitoring and perhaps flashing to 850XT PE (any performance "boost"?)
could anyone edit my BIOS? I have no experience in this!
Thanks!
P.S.: English isn't my native language - sorry - Deutsche Antworten wären also auch i.O.! ;-)
http://rapidshare.com/files/17802723/BIOS_Xpert_Vision_ATI_Radeon_X850XT_256MB_DDR3_AGP.bin.html
X800 upgrade
@ shadowflare
Can you help me? Sorry, i don't understand anything about programming with a hex editor. I have a X800GTO, on the gpu read's:
Radeon X850
215RAGCGA11F
GH1696.1
9547AAY
Taiwan
The card should sold me as Palit/Xpertvision X800GTO, the bios has "Gammagraphx" as vendor.
I'm needing the additional 4 pipes, for "security" reason additional a little more speed at the gpu/mem (if possible), but nothing what will cause a damage to the card! And a "renaming" in the cards bios, that she is shown as X850...
Thx :toast:
@ shadowflare
Radeon X850
215RAGCGA11F
GH1696.1
9547AAY
Taiwan
Thx :toast:
If you need these 4 pipes where are your FUSE values and your BIOS image?
Here:
config_die_fuses: 0xFFFF7FFF
config_substrate_fuses:0xFFFFFF9E
config_rom_fuses: 0x61
gb_pipe_select:0x227A4
bios:
Unfortunately your card will remain with only 12 pipes. Flashing of the BIOS can't help. Just overclock it to the maximum.
FB, and i think i have bought a "golden sample".... This piece wont play Splinter Cell double agent... :mad: it miss PS & VS 3.0
Will flashing do any good?
I'm not even sure if this is the original firmware, or someone has tampered.. :-)
Device ID: 554F
Chip Name R430 (reports as X800GTO)
Active Pipelines: 12
CONFIG_DIE_FUSES: 0xFFFF7FFF
CONFIG_SUBSTRATE_FUSES: 0xFFFFFF9E
CONFIG_ROM_FUSES: 0xA61
GB_PIPE_SELECT: 0x227A4
Hello,please i need help.Is there methods to change vcore on my video by means of programs. I don't want to solder the resistors or do something like that,it has warranty and i'm not sure i can do that properly.But i hope there are some soft could help modify my bios with possibility to change vcore and (or) memory. If you know such soft please let me know. My video X800GTO DDR1 Palit 400/700 R420.
And if there are some hard procesess to do that (in drivers or registers) please gimme a link to faq
You can forget about software voltage control (core/memory) on X800/X850 series :mad: .
I have an X800GT ICEQ II Turbo from HIS
My problem:
I flashed my card with an Modded X800GT BIOS (16 pixelpipelines and R480)
Now is my card an X800GTO with 8 pixelpipelines :-(
Whats the problem of my card (I need 12 or better 16 pixelpipelines)?
Here are some facts (from Everest):
Informationsliste Wert
Grafikprozessor Eigenschaften
Grafikkarte ATI Radeon X850 Pro (R480)
GPU Codename R480
PCI-Geräte 1002 / 5D4F
Transistoren 160 Mio.
Fertigungstechnologie 0.13u
Bustyp PCI Express x16 @ x16
Speichergröße 256 MB
GPU Takt 472 MHz (Original: 475 MHz)
RAMDAC Takt 400 MHz
Pixel Pipelines 8
Textureinheiten (TMU) / Pipeline 1
Vertex Shaders 6 (v2.0)
Pixel Shaders 1 (v2.0)
DirectX Hardwareunterstützung DirectX v9.0
Pixel Fillrate 3776 MPixel/s
Texel Fillrate 3776 MTexel/s
Speicherbus-Eigenschaften
Bustyp GDDR3
Busbreite 256 Bit
Tatsächlicher Takt 493 MHz (DDR) (Original: 490 MHz)
Effektiver Takt 986 MHz
Bandbreite 30.8 GB/s
Speicher Timings
CAS Latency (CL) 7T
RAS To CAS Delay (tRCD) 7T
RAS Precharge (tRP) 6T
RAS Active Time (tRAS) 14T
Row Refresh Cycle Time (tRFC) 27T
RAS To RAS Delay (tRRD) 5T
Write Recovery Time (tWR) 7T
Grafikprozessorhersteller
Firmenname ATI Technologies Inc.
Produktinformation http://www.ati.com/products/gamer.html
Treiberdownload http://www.ati.com/support/driver.html
ATI GPU Registers
ati-00F8 10000000
ati-0140 00000062
ati-0144 69668334
ati-0148 CFFFC000
ati-0154 F0000000
ati-0158 10430000
ati-0178 0000723B
ati-01C0 01FF0000
ati-4018 00000017
ati-CLKIND-0A 00464904
ati-CLKIND-0B 00001A00
ati-CLKIND-0C 0400BC30
ati-CLKIND-0D 00807FFA
ati-CLKIND-0E 0400BC00
ati-CLKIND-0F 00000000
ati-CLKIND-12 00031212
ati-MCIND-6C 00104040
And here from ATITool:
Device ID: 5D4F
Chip Name: R480
Active Pixelpipelines: 8
Config_DIE_Fuses: 0xFFFF6FFF
Config_Substrate_Fuses: 0xFFFFFF9D
Config_ROM_Fuses: 0x262
GB_Pipe_Select: 0x25659
So ^^ the facts are all after the flash, I can't remember the old facts...
What can I do to unlock the pixelpipelines?
Sorry for my worse English!!!
@nabaf 7
Pass bloss auf mit dieser flasherei...!! Hab vor n paar Wochen meine Karte gekillt! Das bringt absolut nichts.:o
